Multiple A2442 MacBook Pros 14" with the same charging issues
This topic has been answered.
+ More Options
Posts
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Same problem on all 14" MBP A2442 models we have in stock, all customers had liquid damage, All boards turn on, boards were cleaned professionally as well. Boards hold charge but batteries not charging, all show the same issue. All boards show the ORANGE AMBER light but no charge sound or any charge going in. One customer stated that the battery will charge if the lid is closed and the battery will reach 100%. USB C ports work for DATA and recognize the externals but do not recognize any charge. I have checked PPBUS_AON and we are getting 12 volts without battery, but when battery is connected it drops to 11volts and some are 10.5volts. I would rule it a battery issue but what's odd is they are holding a charge and do not state they are ABNORMAL. Checked resistors in question and all check out. I have ordered a good amount of chips in question for this board just to see if it fixes it, but nothing is showing any shorts at this time. Any idea if someone has experienced this issue, I have experience it one time with another customer and fixed it but that was a more intense separate issue. Thanks in advance.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Answer selected by Stephen at 04-24-2025, 01:26 PM.
    Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    So I discovered some new knowledge or maybe its not new who knows. These computers seem to boot when the USB C chip is somewhat faulty, even if the resistors are good, replacing a faulty CD3217B12 chip will result in the voltage to jump back up to 20Volts and proper amps for charging the battery. I noticed this with each board yet all of them had the same issue, some had different chips to pinpoint. But most of them all resulted in a CD3217B12 chip being swapped out from a donor. I solved two boards and both had faulty CD3217B12 chips. I. had to source a donor board since I know that the 14" those chips need to come from the correct side just like A2251 boards. One board had a faulty CD3217B12 chip but was still registering so the computer turned on, With this knowledge I was able to solved the second one, I am waiting on another donor for the third. The other board had heavy liquid damage near the HDMI port which hit the CD3217B12 chip. Replacing these more than likely solves the charging issue even though it turns on with a battery....
    Update: my assumption was correct. CD3217B12 chips are the culprit in this type of issue. ONE thing I did notice and I want to give knowledge about is when all CD3217B12 is working you would get 5volts but what I discovered is if you plug up the meter and test PPBUS_AON you will get 12volts on most chips, but one board in particular would give you a different reading if you plug it into different ports. Example: USB C port UF500 would result in 12volts on PPBUS_AON but had 5 volts as usual, plugged up the meter to UF400 same result, Plugged up the meter to UG400 5 volts per usual HOWEVER, PPBUS_AON would result in voltage reading under 10 volts. I was suspicious so I replaced it and voila the board turned on and started getting amps again, plugged up battery and then the battery finally charged.
    Hopefully this helps someone in the future.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Bumping thread, waiting for chips that may be the issue, but would like a second opinion as I have three with the same identical issue.
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        So I am kind of lost here. Any help would be greatly appreciated as this is a common issue that I am seeing and cannot seem to pinpoint the issue on the board.
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          Replaced U5200 still no solution, replaced faulty resistors, etc. replaced L5230 since it wasn't getting voltage but now it is...but still no charging. I get 20volts 0amps when plugged in, battery holds a charge but will not charge, Replaced Q5230 and Q5240 since I had those brand new in stock...still no charge. Went down the schematics and still nothing to find out why it won't charge. Replaced the battery with 3 good known batteries and all are the same result, NO CHARGING. I am confused on what is going on, I have tried to pin point the issue, looked for shorts but nothing is coming up. Any help would really greatly be appreciated.
          Another weird thing is when plugged into the battery the voltage on PPBUS_AON drops to 11.11 volts. Without it plugged in its at a steady 12volts.
          sigpic
          • mon2
            • Dec 2019
            • 13949
            Attach the power adapter and battery; meter in DC volts mode of 30v or higher.
            Carefully measure the voltage to ground on each side of C5220. Post each measurement.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 667
              C5220: 4.97 Volts (both sides)
              sigpic
              • mon2
                • Dec 2019
                • 13949
                Repeat the same test for C5260.
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 667
                  C5260 11volts. That cap at C5220 went down to 0volts when the meter went to 20volts 0amps. but C5260 has 11.17 volts
                  Corrections C5220 is getting 0.20volts on both sides now. very low voltage
                  sigpic
                  • mon2
                    • Dec 2019
                    • 13949
                    Where are you measuring 20v on the board? This must be from the power adapter which then leads to C5260, yet C5260 is 0v?
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 667
                      I am getting 20volts reading on the USB C meter and 0 amps. I was getting 11volts on C5260 and now I am getting 0 volts at C5220 or like 0.20volts DC
                      sigpic
                      • mon2
                        • Dec 2019
                        • 13949
                        Ok. Read your update. Remove all power / no battery. Meter in resistance mode. Measure the resistance across C5220.
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 667
                          I removed that cap since it looked a little beat up, replaced it. So this is the replacement cap resistance for C5220 3.4Ohms
                          sigpic
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 667
                            Here I am going down all the measurements with Power connected (USB C Meter)
                            C5240 Pin 1- 7.5V Pin 2- 2.6V
                            R5240 Pin 1- 7.5V Pin 2- 7.5V
                            R5230 Pin 1- 7.5v Pin 2- 7.5v
                            C5230 Pin 1- 2.6volts Pin 2- 7.5Volts
                            C5277 Pin 1 -5V
                            R5275 Pin 1 - 5v Pin -2 5v
                            R5215 Pin 1- 1.3v Pin 2- 5v
                            R5216 Pin 1- 1.3v Pin 2 GND
                            C5216 Pin 1- 1.3Volts (No stuff present)
                            C5280 Pin 1- 1.5volts
                            C5221 Pin 1- 5volts
                            C5271 Pin 1- 1.5v
                            C5270 Pin 1- 1.5v
                            C5222 Pin 1- 5volts
                            C5278 Pin 1 - 11.99 Volts (W/O Battery attached)
                            C5262 Pin 1 - 11.99 Volts (w/o battery attached)
                            C5261 Pin 1- 11.99volts
                            C5275 Pin 1- 5volts
                            sigpic
                            • mon2
                              • Dec 2019
                              • 13949
                              Touch your meter probes together. What is the resistance?
                              The resistance across C5220 should be ~2 ohms. It is possible that R5260 is defective.
                              This one is critical and is a point of failure. Suggest to flux and replace it.
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 667
                                My meter probes are 1 ohm touching each other currently using FLUKE 15B+ Digital MM
                                sigpic
                                • mon2
                                  • Dec 2019
                                  • 13949
                                  Then the 3 ohms makes sense = 1 ohms (meter) + R5221 + R5222.
                                  Remove all power. Meter in DIODE mode. Red meter probe to ground. Black meter probe to one side of C5220. What is the voltage? Repeat with the other side of the capacitor.
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 667
                                    Voltage Reading is 0.48volts in diode mode. Both sides. Yeah I failed to mention my probes need a little love. It may be time to get some new ones.
                                    sigpic
                                    • Stephen
                                      Meow Meow MEOW!
                                      • Apr 2020
                                      • 667
                                      Replaced R5260, tested for other problems but cannot seem to find any result, put board in and nothing is charging still. Kind of want to throw this computer out the door lol
                                      sigpic
                                      • mon2
                                        • Dec 2019
                                        • 13949
                                        The diode readings confirm that the ISL chip is soldered and not floating.
                                        Confirm the voltage to ground @
                                        PPCHGR_VDDA
                                        PPCHGR_VDDP
                                        CHGR_AUX_DET
                                        PPVBAT_AON_CHGR_REG
                                        • Stephen
                                          Meow Meow MEOW!
                                          • Apr 2020
                                          • 667
                                          PPCHGR_VDDA = Voltage dropping. went down from 5volts down to 1 volt and still dropping.
                                          PPCHGR_VDDP = 5volts and dropping..
                                          CHGR_AUX_DET
                                          PPVBAT_AON_CHGR_REG =1.5volts and not dropping any further
                                          I tested these on the other ports... and this is the readings.
                                          Something odd is happening what I just noticed. The port I am using shows the voltage dropping (JG600) when connected to the other two ports the voltage stays consistent. and is higher.
                                          I do recall seeing tons of liquid damage in this area, but doesn't seem to explain why the computer is working but not charging. I am assuming if this chip is faulty would it result in a no charge?
                                          sigpic
                                          • dbuergi
                                            Macbook A2442 no display board 820-02098
                                            by dbuergi
                                            i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                                            So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                                            05-25-2025, 10:58 AM
                                          • TechSplendid
                                            MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                                            by TechSplendid
                                            Hi All,
                                            I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                                            Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                                            04-09-2025, 02:13 AM
                                          • Constantinos
                                            Macbook Pro A2442 820-02098 No image but has backlight
                                            by Constantinos
                                            Hi all
                                            I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                            He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                            Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                            Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                            From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                            08-24-2024, 09:48 AM
                                          • Enzo150i
                                            MacBook A2442 exclamation mark after oxydation
                                            by Enzo150i
                                            I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
                                            The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
                                            Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
                                            We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to....
                                            06-29-2025, 01:26 PM
                                          • veedo
                                            Macbook A2442 820-02098 boot and display issue
                                            by veedo
                                            Hi All
                                            I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                                            Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                                            I found component UD290 ( SF0101-I2C) little...
                                            04-01-2024, 06:06 AM
