Macbook Air M1 A2337 Stuck At 5V
  • BMCappelletti
    • Nov 2021
    • 152
    • Brasil
    Hi everyone.
    Found some topics here for the same issue, on the same board, but none with all the same values I have or same steps to correct it. And I could not get usefull information from it.
    So... M1, board 820-02016-A, stuck at 5V. Current is 0.08A and from time to time it jumps to 0.13A and back.
    I measured:
    L5230 - 5.1V
    LC320 - 0V (no short)
    LP800 - 0V (no short)
    L5840/5820/5800 - 3.8V
    F5200 - 12.29V (according to an entry on repair.wiki "If the voltage is approximately 12.28-12.35V, it may indicate a communication issue between the SOC and PMICs, or corrupt firmware")
    When connected, the only thing that seems to get hot (not to touch, though) is U1970.
    Checking CD3217... I don´t have 5V on CC334 or CC335 (comes from LC320, maybe?), but I do have 3.3V on CF400 and 1.25V on SWV011.
    Any help on what I should check or try next is much appreciated.
    Thanx!
  • mon2
    • Dec 2019
    • 14742
    What is the voltage to ground of P5VS2_PWR_EN? What about P5VS2_EN (other side of resistor RC333)? Is it stable?
    • BMCappelletti
      • Nov 2021
      • 152
      • Brasil
      P5VS2_PWR_EN is 0V
      RC333 has 0.019V (stable, if that counts) on P5VS2_EN and 0V on P5VS2_PWR_EN.
      • mon2
        • Dec 2019
        • 14742
        Ok, without an enable, the output rail for this leg will remain OFF. As long as there is no short, this regulator is not a suspect.
        Review the PD controllers (CD3217) and confirm each of their LDO rails. Only the active port will have the BMC power rail active but other power rails on the CD3217 must be present.
        Review the following voltage to ground measurements:
        (use UF400)
        * measure with care as the parts are SMALL!!!!
        PPVBUS_USBC0 @ CF401
        PP3V3_S2_UPC @ CF400
        PP3V3_UPC0_LDO @ CF408
        USBC0_3V3LDO_EN
        Click image for larger version  Name:	power1.png Views:	0 Size:	180.5 KB ID:	3603941
        • BMCappelletti
          • Nov 2021
          • 152
          • Brasil
          (use UF400)
          USBC0_3V3LDO_EN
          Charger conneced to the top port.
          PPVBUS_USBC0 - 0V
          PP3V3_UPC0_LDO - 3.3V
          USBC1_CC1 - 1.6V
          USBC1_CC2 - 0V
          PPVBUS_USBC1 - 5.1V
          PPDCIN_AONSW - 5.1V
          PP3V3_UPC1_LDO - 3.3V
          I2C_SMC_UPC_SCL - 1.2V
          I2C_SMC_UPC_SDA - 1.2V
          I2C_UPC_SCL - 1.2v
          I2C_UPC_SDA - 1.2v
          I2C_SMC_PWR_SDA - 1.2v
          I2C_SMC_PWR_SCL - 1.2v​
          • mon2
            • Dec 2019
            • 14742
            Looks good. Next, test the other port for similar measurements.
            This will confirm that PPVBUS_USBC0 = UF400 is ok (or not).
            • BMCappelletti
              • Nov 2021
              • 152
              • Brasil
              Yes, everything the same. Ecxpt for the USBC1_CC1 is now zero and CC2 is now 1.6V.
              PPVBUS_USBC0 still zero.
              • BMCappelletti
                • Nov 2021
                • 152
                • Brasil
                Any other idea on what I could try next?
                Is it worth trying to rewrite UF260 with the bin files that one can find here? If so, I need to buy an adapter to my EZ2019, cause that seems to be a USON 2x3 chip.
                Thank you.
                • mon2
                  • Dec 2019
                  • 14742
                  The socket adapter is not a bad investment. We recently did the same - purchased the purple breakout board on Aliexpress and also the zero force socket for the same odd physical size. The dump of the flash rom should be available here but if not, ping back and we may have it in our database. According to Master Liu, this is a common point of failure when you do not reach 20v if all else checks out ok.
                  • BMCappelletti
                    • Nov 2021
                    • 152
                    • Brasil
                    Yes, I've seen his video, using the U301 device.
                    Could you link me the Aliexpress one you are mentioning? I have a couple of tabs open here but want to make sure I get the correct one. I have the 1.8V adapter to use on my EZ2019, so I guess I just need the adapter.
                    • mon2
                      • Dec 2019
                      • 14742
                      Our Aliexpress order history shows the following purchases for the same:
                      USON8-4X3-XG
                      https://www.aliexpress.com/item/1005...283f1802ikcT9F
                      * confirmed working with our T56 programming tool (with the aid of tweezers)
                      * purple one with all the different footprints
                      * 25 in 1 - you will need to solder in the male header pins to mate with your programming socket and solder the chip to program on this board to R/W
                      Personally prefer the zero force socket that does not require programming. I know that we spent hours searching and could not locate any vendor for the flash nor the sockets / pcbs to repair our imac / macbooks so had to order through Aliexpress. Suggest highly to order a few of the original flash chips from Asia as well.
                      We bought the following (confirm if it is the same as yours and also if it is supported by your programmer):
                      MX25U3235F
                      https://www.aliexpress.com/item/3305...283f1802ikcT9F
                      * confirm the proper footprint / size of the flash before ordering
                      • BMCappelletti
                        • Nov 2021
                        • 152
                        • Brasil
                        USON8-4X3-XG
                        MX25U3235F
                        Awesome. Thanx a lot.
                        Will buy and test it. Will post a reply on about three weeks.
                        • mon2
                          • Dec 2019
                          • 14742
                          Err..meant to say soldering. Long day..​
                          • BMCappelletti
                            • Nov 2021
                            • 152
                            • Brasil
                            I figured it out
                            • BMCappelletti
                              • Nov 2021
                              • 152
                              • Brasil
                              As for the chip, the one on the schematic is W25Q80DVUXIE.
                              On the chip itself the markings are:
                              X-5H727
                              500A1
                              MX25
                              U6472F
                              So I guess this is the correct one? https://pt.aliexpress.com/item/1005008148911606.html
                              • mon2
                                • Dec 2019
                                • 14742
                                Actually it is this one:
                                https://www.macronix.com/Lists/Datas...Mb,%20v1.1.pdf
                                • BMCappelletti
                                  • Nov 2021
                                  • 152
                                  • Brasil
                                  Well, now I'm lost on which one I need to buy. Searching for that last one on Ali shows me nothing.
                                  • mon2
                                    • Dec 2019
                                    • 14742
                                    Check the file size of the dump for this part.
                                    If the dump size is 8Mbits then your replacement part is ok to use. The part that is 64Mbits is onboard and is 8x the density you are about to purchase from your shared link. Working on my beauty sleep so will check my database of images in the morning to confirm.
                                    • BMCappelletti
                                      • Nov 2021
                                      • 152
                                      • Brasil
                                      Hi. Got a time to check your sources?
                                      As I said, schematic for 820-02016 shows W25Q80DVUXIE and chip itself has
                                      X-5H727
                                      500A1
                                      MX25
                                      U6472F​
                                      I guess the chip is fine and maybe I can get around it with just a reflash, but I don't mind buying a couple other ones to have spares.
                                      • mon2
                                        • Dec 2019
                                        • 14742
                                        The flash tools I linked earlier are for 4*3mm. This footprint is present on some current iMAC units and perhaps also on macbooks.
                                        Your UF260 is a 2*3mm footprint. The purple board I am fairly confident also supports this footprint but you must solder the flash to R/W the device. Suggest to purchase both zero force sockets as they will be useful. Purchase the 4*3mm and also the 2*3mm and some good tweezers to use the socket.
                                        The schematic is showing indeed a Winbond part @ UF260:
                                        So Winbond W25Q80DVUXIE will be suitable to use for your case + zeroforce or the purple solder type board to work with your programmer. The VCC for this flash is @ 3v3 so no issue to use with almost any programmer.
                                        Be sure to use the full part # before ordering.
                                        If you do not have a proper dump for this chip, post back and should be able to assist from my database of dumps. I believe they are also posted inside the dedicated bios forum.
                                        • duwane
                                          MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                                          by duwane
                                          Hi All.
                                          I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                                          Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                                          After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                                          Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                                          10-17-2023, 07:48 PM
                                        • erickirchey
                                          Macbook a2337 820-02016 stuck on 5v fluctuating voltage
                                          by erickirchey
                                          I am learning any help is appreciated I have a macbook 820-02016 that is stuck on 5v
                                          I tested voltage on PPBUS_AON i get 12.6v and it drops to 11.3v I removed fuse f5200 pin 1 PPVBAT_AON_CHGR_REG Becomes stable and no longer fluctuates
                                          Pin 1 on f5200 is .51 in diode mode
                                          pin 2 is .46
                                          Im not sure where to go from here any guidance would be appreciated!...
                                          08-26-2024, 02:04 PM
                                        • Jonnx
                                          Macbook Air A2337, 820-02016-A stuck at 5V
                                          by Jonnx
                                          Hello everybody,
                                          I have seen a lot of posts about the A2237/A2338 about the 5V not boosting up to 20V issue, but none of them seem to have the exact problem as my board does.
                                          My PPBUS_AON was measuring ~9.32V and the board kept power cycling, so I removed the fuse F5200 to measure PPVBAT_AON_CHGR_REG and indeed it was still 9.32V, but the board stopped power cycling. Then I measured U5200 values and got this:
                                          U5200:
                                          PPDCIN_AON_CHGR_R = 5.144V
                                          AUX_DET = 1.287V
                                          VDD = 2.767V
                                          VDDP = 2.767V
                                          AUX_OK = 0.848V
                                          AMON = 0V
                                          BMON...
                                          05-25-2024, 12:00 PM
                                        • Bmet
                                          MacBook Pro 13 inch A2238 M2 stuck on 5V
                                          by Bmet
                                          I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                          04-02-2025, 05:02 PM
                                        • conghuyms
                                          MacBook Air A2179 stuck logo , pls help me !
                                          by conghuyms
                                          Hey everyone,
                                          I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                          When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                          I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                          11-05-2025, 08:30 AM
