Macbook Air M1 A2337 Stuck At 5V
  • BMCappelletti
    • Nov 2021
    • 152
    • Brasil
    Originally posted by mon2
    The flash tools I linked earlier are for 4*3mm. This footprint is present on some current iMAC units and perhaps also on macbooks.
    Your UF260 is a 2*3mm footprint. The purple board I am fairly confident also supports this footprint but you must solder the flash to R/W the device. Suggest to purchase both zero force sockets as they will be useful. Purchase the 4*3mm and also the 2*3mm and some good tweezers to use the socket.
    The schematic is showing indeed a Winbond part @ UF260:
    So Winbond W25Q80DVUXIE will be suitable to use for your case + zeroforce or the purple solder type board to work with your programmer. The VCC for this flash is @ 3v3 so no issue to use with almost any programmer.
    Be sure to use the full part # before ordering.
    If you do not have a proper dump for this chip, post back and should be able to assist from my database of dumps. I believe they are also posted inside the dedicated bios forum.
    Yes, all the dumps from that U301 device are also here. That would not be an issue.
    I'll get both the 2x3 and 4x3 adapters. And the purple board. Along with a couple chips.
    Thanx a lot.
    • BMCappelletti
      • Nov 2021
      • 152
      • Brasil
      Got the zero force socket yesterday. The pruple board, for some reason, is stuck on customs.
      Opened the Mac again and... my chip is 4x3.
      Also Winbond W25Q80DVUXIE, even though that's what's on the schematic, is smaller than the one on the board, with those marks mentioned.
      Oh boy.
      • mon2
        • 14742
        We ordered 1 of everything. Your purple board will work for you (has all of the footprints) but also suggest to purchase the zero force socket for the 4x3. Apple has used both footprints across different models so sooner or later, it will be used.
        • BMCappelletti
          • Nov 2021
          • 152
          • Brasil
          Yes. Waiting on the purple board. No idea why it got stuck and the adapter didn't.
          Will order the other adapter later.
          Was hoping to make it work today. lol
          Shit happens.
          • BMCappelletti
            • Nov 2021
            • 152
            • Brasil
            Hi again,
            Well, finaly got the adapter. Took the chip from the board but... neither my EZP2019 or CH341B reads it.
            Tried different softwares and different settings. No luck.
            Oh boy. Do I have to buy a new reader to me able to this MX25U64 eprom?
            • fraser34
              • Jan 2019
              • 11
              Originally posted by BMCappelletti
              Hi again,
              I'm wondering if you were able to read the chip.
              I'm facing the same issue with CH341A and EZP2023+
              • BMCappelletti
                • Nov 2021
                • 152
                • Brasil
                #27
                To tell the truth... I can't remember.
                I ended up buying a new programmer and also a faulty board, to get the chip from, assuming mine could be faulty.
                I did the procedure and... nothing. Board still stuck on 5V. So I thought it have not worked. Because, according to what I found, it should be 19V even when on DFU mode. As I didn't have a newer Mac here to test this, I left alone.
                Just past month I tried it, on a friend's MacBook Pro. And... even at 5V it was fund on his Mac. And I was able to get it back to life.
                I bought a T48 programmer, but I don't remember exactly what I did, in terms of using the chip I had or using the one from the donnor board. Sorry.
                • fraser34
                  • Jan 2019
                  • 11
                  Thank you for sharing this information.
                  • duwane
                    MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                    by duwane
                    Hi All.
                    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                    10-17-2023, 07:48 PM
                  • erickirchey
                    Macbook a2337 820-02016 stuck on 5v fluctuating voltage
                    by erickirchey
                    I am learning any help is appreciated I have a macbook 820-02016 that is stuck on 5v
                    I tested voltage on PPBUS_AON i get 12.6v and it drops to 11.3v I removed fuse f5200 pin 1 PPVBAT_AON_CHGR_REG Becomes stable and no longer fluctuates
                    Pin 1 on f5200 is .51 in diode mode
                    pin 2 is .46
                    Im not sure where to go from here any guidance would be appreciated!...
                    08-26-2024, 02:04 PM
                  • Jonnx
                    Macbook Air A2337, 820-02016-A stuck at 5V
                    by Jonnx
                    Hello everybody,
                    I have seen a lot of posts about the A2237/A2338 about the 5V not boosting up to 20V issue, but none of them seem to have the exact problem as my board does.
                    My PPBUS_AON was measuring ~9.32V and the board kept power cycling, so I removed the fuse F5200 to measure PPVBAT_AON_CHGR_REG and indeed it was still 9.32V, but the board stopped power cycling. Then I measured U5200 values and got this:
                    U5200:
                    PPDCIN_AON_CHGR_R = 5.144V
                    AUX_DET = 1.287V
                    VDD = 2.767V
                    VDDP = 2.767V
                    AUX_OK = 0.848V
                    AMON = 0V
                    BMON...
                    05-25-2024, 12:00 PM
                  • Bmet
                    MacBook Pro 13 inch A2238 M2 stuck on 5V
                    by Bmet
                    I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                    04-02-2025, 05:02 PM
                  • conghuyms
                    MacBook Air A2179 stuck logo , pls help me !
                    by conghuyms
                    Hey everyone,
                    I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                    When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                    I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                    11-05-2025, 08:30 AM
