bios post cards or other fault diagnostic methods
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    I buy two post cards for diagnostic boards when all voltages and pwsignals is working but have blacck screen. One 5$ shit and Debug king post card, but they uset to be nearly unusefull. Have anybody some better cards or other diagnostic methods when board is starting but no video??
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: bios post cards or other fault diagnostic methods
    Debug cards only work when the mainboard has routed the LPC bus thru to the wifi card slot. This is not a requirement, it is optional in the specs, so it's up to the manufacturer to do it. Generally i've noticed that HPs all seem to have it, other manufacturers, less so. The bus is always exposed somewhere on the motherboard but you'll have to solder wires.
    In most cases it still boils down to voltage measurements. Or if you have a fancy digital scope...
    A working TV? How boring!
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      U ROCK MAN!!!!
      i was sad about not working cards and now i look to the schematic for laptop and found debug connector. Im gonna make some wiring and wish me luck :-)
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        this work sucks. no connector on board and sooo tiny 14 pins that must have soldered connector and attach flex with stripped wires. lot of work.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          LPC bus is only 7 wires.
            • 31250
            use kynar wire.
            if you need REALLY small wire, use enamel covered copper wire by unwinding a small transformer.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5072
              • New Zealand
              I bought one of those PCI tester cards for desktops years ago, it worked in only one board (Pentium 1)
              The next time I tried it in another board, the ICs got hot and the motherboard was killed. Cheap Chinese trash!
              -David VanHorn
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                1 image - asus f5z - no connector
                2 image - dr4ag soldering works good
                3 image - attached flax and strip wires
                4 image - schematic of LPC connector
                5 image - Anybody know where i can find connector to this slot?
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Steal a mini-PCIE from a dead board.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    i mean the LPC port/picture edited/
                    went to the best local parts store but they will have it about week
                    • pcbmaniac
                      • May 2014
                      • 81
                      • Greece
                      It seams we have the same POST card. I used mine connected to LPC debug points but i get it working only when i press power on button, then i get only clk and 3,3V signals. This card works OK when connected to PCI slot only.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3627
                        • slovakia
                        but mini pci slots have VERRY LITTLE support.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3627
                          • slovakia
                          damn my card missing just the elpc conector.
                          • pcbmaniac
                            • May 2014
                            • 81
                            • Greece
                            Telling the truth, i didn't manage to see any difference. Why don't you put it to wifi slot for testing? It has mini pci-e port on every laptop.
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3627
                              • slovakia
                              ofcourse i put it to minipcie port but it seems that noone board is supported.
                              ELPC port have only asus
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                I have the same card too. Like i said, it works well on HP laptops, hit and miss with all others.
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3627
                                  • slovakia
                                  no luck with LPC on other board? my card work only on ddr1 but never on ddr2/3
                                  • pcbmaniac
                                    • May 2014
                                    • 81
                                    • Greece
                                    Don't you manage to test it? No lights? Show us a photo of the card already connected to mobo on mini pci-e slot when you press power on button.
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3627
                                      • slovakia
                                      just CLK light up and have 0 on code
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        It means it simply doesn't put out any codes... There are boards which give LPC clock but don't put out codes. For the POST card to report anything, the KBC and soutbhridge have to be good.
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • claws77
                                          lenovo flex 5 14ITL05 bios and motherboard fault
                                          by claws77
                                          my laptop is lenovo flex 5 14ITL05
                                          recently my power supply for this laptop developed a fault.
                                          which caused a short in my usb c port -- verified with a new charger.
                                          rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
                                          I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
                                          07-05-2024, 04:33 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
