820-00840 no boot!! A BIG MISTERY
  • phantomEVO
    • Mar 2013
    • 509
    according to openboard data
    l7900 should be 290 and i have 150 (resistence 150ohm)
    l8060 should be 260 and i have 180 (resistence 190ohm)
    • phantomEVO
      • Mar 2013
      • 509
      in smc bypass i have apple logo with bar loading, then error. this process is in loop
      • mon2
        • Dec 2019
        • 14679
        Which error? What is connected during this boot process?
        • phantomEVO
          • Mar 2013
          • 509
          "YOUR COMPUTER RESTAR BECAUSE OF A PROBLEM" PRESS A KEY OR WAIT A FEW SECONDS TO CONTINUE STARTING UP.
          all things connected
          • mon2
            • Dec 2019
            • 14679
            Try to boot in safe mode or internet boot.
            Sounds like a software fault:
            https://support.apple.com/en-ca/102382
            • phantomEVO
              • Mar 2013
              • 509
              like i said, i can boot only in bypass mode. in this mode, i can't arrive to desktop...i have the loading bar with apple logo, then when it's starting os, the logo disappears and i have the error (even disconnecting everything)
              simply press power button doesn't do anything
              • mon2
                • Dec 2019
                • 14679
                Your OS sounds to be corrupt. This is a software fault from the shared details. Boot from the internet. Report your status from that mode of boot.
                • phantomEVO
                  • Mar 2013
                  • 509
                  how can i boot from the internet if the notebook is totally dead???? it doesn't respond to any key unless i boot in smc bypass...like i have already said, if i push the power button, nothing happen
                  • phantomEVO
                    • Mar 2013
                    • 509
                    ps the apple logo has an half darker then the other
                    i repeat: I HAVE NO CHIME IN SMC BYPASS: COULD IT BE IMPORTANT?​
                    • phantomEVO
                      • Mar 2013
                      • 509
                      LID_OPEN and SMC_LID_LEFT are 3,4v;
                      smc_lid_right 0,4 this line is ok in resistence and diode mode
                      replaced u5255 no luck
                      ​, all tracks are ok
                      • phantomEVO
                        • Mar 2013
                        • 509
                        i've Removed R5257 and joined pins 1 & 2 of U5255....still same problem
                        • phantomEVO
                          • Mar 2013
                          • 509
                          its' like something is missing or not correct...i'm going crazy! please help!
                          • mon2
                            • Dec 2019
                            • 14679
                            Sounds like a local display backlight fault. Test with an external display over USB Type C dongle to HDMI.
                            • phantomEVO
                              • Mar 2013
                              • 509
                              edit
                              • phantomEVO
                                • Mar 2013
                                • 509
                                I'm going crazy.
                                I wonder why trigger button don't work at all. Maybe because of a Dead battery?
                                And what the hell happen as soon as the os is booting????? Something that miss​
                                • mon2
                                  • Dec 2019
                                  • 14679
                                  Trigger button = on/off button?
                                  See attached. Locate the shorting PCB pads that are present on all macbook models. One pair of pads on one side of the board; another pair of pads on the other side.
                                  In the absence of a keyboard, you can use metal tweezers to emulate the power button. If you (carefully) use tweezers on these pcb pads, can you power the board on/off?
                                  Have you tested with an external screen as per suggesting in post #33? What was the result?
                                  • phantomEVO
                                    • Mar 2013
                                    • 509
                                    yes trigger button is working....but i cant try to boot with battery only, because it is dead. i've ordered another one just in case.
                                    i can't see anything on external monitor.
                                    this is a small recap of the problem
                                    https://www.youtube.com/watch?v=k19kir4aAWE
                                    0
                                    • phantomEVO
                                      • Mar 2013
                                      • 509
                                      i have even pp5v_s0 (that goes to 0)......so why it doesn't boot!!
                                      • phantomEVO
                                        • Mar 2013
                                        • 509
                                        help....
                                        • mon2
                                          • Dec 2019
                                          • 14679
                                          Have you attempted with a known good bios?
                                          https://www.badcaps.net/forum/troubl...e2#post3540281
                                          * see post # 30
                                          You have a lot working on this unit - including video so the bios is not likely to be the fault.
                                          Have you attempted to boot from internet?
                                          To boot an A1708 (a MacBook Pro model) from the internet into macOS Recovery, press and hold the Option (Alt) + Command + R keys immediately after turning on the computer.
                                          Here's a more detailed explanation:
                                          • Shut down your Mac:
                                            Ensure your MacBook Pro is completely shut down.
                                          • Turn it on and press the keys:
                                            Press the power button to start the Mac, then immediately press and hold the Option (Alt) + Command + R keys.
                                          • Wait for the Recovery screen:
                                            Continue holding the keys until you see the macOS Recovery screen, which will prompt you to connect to the internet.
                                          • Connect to Wi-Fi:
                                            If you are not already connected to a Wi-Fi network, you will need to connect to one from the Recovery screen.
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • blaster_
                                            Samsung UE49MU6105K - boot loop, horizontal lines
                                            by blaster_
                                            Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                            Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                            06-22-2022, 05:19 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • No Lan
                                            [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                            by No Lan
                                            Hey everyone,
                                            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                            05-24-2025, 03:09 PM
