Also have a known working A2442 820-02098-A UG260 BIN file.
Original Bin Files for Many Macbooks Chips U2890, UB090, U3060, UB260, UF260
820-00138 U2890 tested
this is usb c firmware bios NOT main bios. if u dont understand please do not download those files!
many thanks for PAChAttached Filesif you find these attachements useful please consider making a small donation to the site
useful dump..maybe will need this later.. 👍🏻Hi everybody, here are the Original BIN Files for the following Macbooks Chips, I hope it helps somebody
A1706 820-00239-A UB090
A1706 820-00923-A U2890
A1706 820-00923-A UB090
A1707 820-00281-A U2890
A1707 820-00281-A UB090
A1707 820-00928-A U2890
A1707 820-00928-A UB090
A1708 820-00840-A U2890
A1708 820-00875-A U2890
A1932 820-01521-02 U2890
A1989 820-00850-A U2890
A1989 820-00850-A UB090
A1990 820-01041-A U2890
A1990 820-01041-A UB090
A1990 820-01814-01 U2890
A1990 820-01814-01 UB090
A2141 820-01700-A U2890
A2141 820-01700-A UB090
A2159 820-01598-A U2890
A2179 820-01958-A U3060
A2251 820-01949-07 U3060
A2251 820-01949-07 UB260
A2289 820-01987-06 U2890
A2337 820-02016-A UF260
A2338 820-02020-A UF260Comment
Adding another bios for A1708 820-00840.
Here is the UF260 bin file for the M2 Macbook Pro A2338 (for the cd3217b13 chips)
by samolo75Hi,
Here it is the original rom from this macbook mother board with a very strange behavior. I included the A1990 UB090 file that I found here in the forum, thanks for that. I can see that the content of the files is different, probably too different for just being than mine got a bit corrupted.
The behavior is that al four USB C ports negotiate the 20V completely fine and the computer boots. Connecting a USB hub, the sd card reader works, the Ethernet port works, HDMI works, but connecting a simple mouse does not work. The working functions of the USB Hub mentioned only work on the...-
Channel: BIOS Requests ONLY!
by ronaldopdiasBoard Model: 820-00923
Issue: Board takes 5V @ 0.694A on all ports. No signs liquid.
Customer stated: Died during an update whilst battery was at 10%. Tried plugging in but it died.
Board takes 5V at 0.06A on all USB-C ports..
Board is clean with no visible corrosion or liquid damage.
PP1V8_UPC_TA_LDOA - 1.8V
PP3V3_UPC_TA_LDO - 3.32V
PP1V8_UPC_TA_LDOD - 1.8V
PP1V1_UPC_TA_LDO_BMC - 0V
PP1V8_UPC_TB_LDOA - 1.8V
PP1V1_UPC_TB_LDO_BMC - 0V
PP1V8_UPC_TB_LDOD - 1.8V
PP3V3_UPC_TB_LDO - 3.28V
by ronaldopdiasHi everyone. I need a help with this Mac, please.
The logic board shows no signs of life , is clean with no liquid damage, and is stuck at 5V and 0.294A on all ports.
DFU attempted, but it stalled halfway through the system installation.
Mac turns on with a working battery, but doesn't charge it.
With a Working battery the voltages are 20V at 0.0300a
PPBUS_G3H - 12.28V
XB, XA, TA, TB are all measuring same voltage.
PP20V_USBC_XB_VBUS - 5V
PP3V3_UPC_XB_LDO - 3V
PP1V8_UPC_XB_LDOA - 1.8V
PP1V8_UPC_XB_LDOD -1.8V... -
by JoyoungjaeHello friends, it's been a while.
Model A2141 came to me for repair.
I confirmed that there was a short in the ppdcin line and that the capacitor was blown.
All the short line capacitors seemed to be in bad condition, so I replaced all c7043, c7024, c7026, c7027, c7029, and c7042.
The short is caught and the power is turned on.
However, when the power is turned on with the battery installed, only one charging port works and the other three display 20V but 0 amps.
If you plug in the charger when the battery is not installed... -
by msnessayi need dump type c Rom A1707 touchbar 15 inch
U2890 W25Q80 1mo
820-00281-A-
- Loading...
