a1706 smc program
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    a1706 smc program
    I have a1706 820-00923-a, the smc in this board is bad (980 yfe tm4ea231) I have a new smc but the problem is how to program this smc, does anyone know about it pls help
  • reformatt
    • Feb 2020
    • 1488
    No publicly available means to program a blank SMC. Any replacements have to come from a donor board.
    You can use some SMC's from other models and reprogram using Muerto's SMCtool, but the board has to be able to boot to do that.
    • Arshad alam4659
      • Aug 2020
      • 157
      • India
      i have a muerto's tool but this model is not listed in this tool how to program pls guide me
      • reformatt
        • Feb 2020
        • 1488
        BTW, SMCtool is deprecated and now replaced with SMCFT. This model is not supported currently. It may be that he doesn't have a board to test with.
        Apple use different naming schemes for boards. 820-00923 --> Macbook Pro 14,2 --> Mac-CAD6701F7CEA0921
        This is not currently listed in his tool, so ask if he can add it.
        Maybe contact him in this thread:
        https://www.badcaps.net/forum/troubl...efi-toolkit​
        • shamsudeen
          Epson M3170 Monochrome inkjet printer adjustment program tool
          by shamsudeen
          Epson M3170 Monochrome inkjet printer adjustment program tool.
          Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
          anyone having it, please share
          Thank you
          07-08-2025, 06:42 AM
        • Danielreinaa
          HELP need password bios Macbook A1706
          by Danielreinaa
          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
          09-07-2024, 03:47 PM
        • Nikan.e
          How to program a specific flash region of a Nations N32G455RE MCU?
          by Nikan.e
          Greetings and salutations!
          I have a device that uses an N32G455RE. Unfortunately, its flash got corrupted. I have a dump of a working chip.
          How can I program a specific region of the flash or the whole flash without touching the RAM, option registers, etc.?
          I do not have a J-Link debugger and won't buy one, as I am not rich.
          I have flashed a Nucleo board with an ST-Link to a J-Link just to find out that the ST-J-Link only supports ST chips.
          What would be the cheapest and easiest option to program the Nations chip's flash without touching registers etc.?...
          05-23-2024, 11:51 PM
        • moderator
          A1706 - emc 3107 bios
          by moderator
          a1706 Bios file i am uploading , need cleaned, its not password locked..macbook is booting ..getthing chime also.but stuck on apple logo..in target mode disk is recognised and i was able to copy data...it happened while changing the touchbar
          Serial number is C02STA7EHF1P
          its A1706 - emc 3107...
          05-17-2024, 07:00 AM
        • krkr_20033d
          I need this program name its for boardveiw
          by krkr_20033d
          Can any one name this program or send an url for it...
          08-29-2025, 04:50 PM
