820-00850 that is stuck on 5V at 0.294A
  • ronaldopdias
    • Jul 2015
    • 100
    • United Kingdon
    Hi everyone. I need a help with this Mac, please.
    T
    he logic board shows no signs of life , is clean with no liquid damage, and is stuck at 5V and 0.294A on all ports.
    DFU attempted, but it stalled halfway through the system installation.
    Mac turns on with a working battery, but doesn't charge it.
    With a Working battery the voltages are 20V at 0.0300a
    PPBUS_G3H - 12.28V
    XB, XA, TA, TB are all measuring same voltage.
    PP20V_USBC_XB_VBUS - 5V
    PP3V3_UPC_XB_LDO - 3V
    PP1V8_UPC_XB_LDOA - 1.8V
    PP1V8_UPC_XB_LDOD -1.8V
    PP1V1_UPC_XB_LDO_BMC - 1.11V
    With working battery it goes to 20V 0.02A.
    PP2V7_NAND_SSD0 - 0V
    PP0V9_SSD0 - 0V
    PP1V8_SSD0 - 0V
    PP3V3_G3S - 0V
    PP5V_G3S - 0V
    PP5V_G3S - 0V
    PMU_ONOFF_L - 3.38V
    U7000 replaced and still same.
    UB090 and U2890 replaced from a donor board and still same.
    On battery.
    P_IN - 0V
    AUX_DET - 0V
    SMC_RST_IN - 0V
    VDDA/P - 5.11V
    A/BMON - 0V
    R7020 not getting any voltage.
    PPDCIN_G3H is missing when the charger switches to 20V. Without the battery it gets 5V on the PPDCIN_G3H.
    all ports have the same behaviour, flipping the cable too.
    D6950 replaced and same.
    Without battery.
    SMBUS_3V3_BATT_SCL - 3.36V
    SMBUS_3V3_BATT_SDA - 3.36V
    With the battery it goes to 0V
  • mon2
    • 14868
    Select the USB port linked to U3200.
    Power up with the external power adapter. Measure the voltage to ground of PP20V_USBC_XB_VBUS_F @ Q3200 dual mosfet. Does this same voltage pass onto PPDCIN_G3H?
    When the adapter is in 20v, same power path voltages?
    What is the voltage to ground of the following power pins on U7000?
    CHGR_VDDA ; measure @ C7075 (pin 1)
    CHGR_VDDP ; measure @ C7077 (pin 1)
    • ronaldopdias
      • Jul 2015
      • 100
      • United Kingdon
      The Q3200 gets 20V on pin 7 - PP20V_USBC_XB_VBUS_F.​
      20V is not present on the PPDCIN_G3H pin 8 when the charges is 20V.
      • mon2
        • 14868
        Review the G1 and G2 voltages to ground on Q3200 under the same conditions.
        • ronaldopdias
          • Jul 2015
          • 100
          • United Kingdon
          G1 - 0V
          G2 - 20V
          • mon2
            • 14868
            Remove all power. Measure the resistance between S2 / G2. Also S1 / G1.
            • ronaldopdias
              • Jul 2015
              • 100
              • United Kingdon
              No resistence.
              S2 / G2 - OL
              S1 / G1 - OL
              Diode measurement.
              Q3200 pins:
              1 - 0.660
              2 - 0.650
              4 - 0.650
              5 - 0.192
              8 - 0.566
              • mon2
                • 14868
                Test the resistance of:
                G2 / D2 (pin 3)
                S2 / D2 (pin 3)
                G1 / D2 (pin 3)
                S1 / D2 (pin 3)
                • ronaldopdias
                  • Jul 2015
                  • 100
                  • United Kingdon
                  All those options are OL
                  D2 is pin 2, but they are connected together pin 2 and 3.
                  • ronaldopdias
                    • Jul 2015
                    • 100
                    • United Kingdon
                    CHGR_VDDA ; measure @ C7075 (pin 1) 0.465
                    CHGR_VDDP ; measure @ C7077 (pin 1)​ 0.465
                    • mon2
                      • 14868
                      What voltage do you see with the adapter on:
                      What are the resistance to ground of each of the following?
                      PP2V7_NAND_SSD0
                      PP0V9_SSD0
                      PP1V8_SSD0
                      PP3V3_G3S
                      PP5V_G3S
                      • ronaldopdias
                        • Jul 2015
                        • 100
                        • United Kingdon
                        CHGR_VDDA ; measure @ C7075 (pin 1) 5.10V
                        CHGR_VDDP ; measure @ C7077 (pin 1) 5.10V
                        PP2V7_NAND_SSD0 2.52V
                        PP0V9_SSD0 0.90V
                        PP1V8_SSD0 1.80
                        PP3V3_G3S 3.38V
                        PP5V_G3S 5.14V
                        • mon2
                          • 14868
                          Review this flowchat for the CD3215. Appears that HV_GATE1 is not working.
                          https://logi.wiki/index.php/CD3215_Bootup_Sequence
                          • ronaldopdias
                            • Jul 2015
                            • 100
                            • United Kingdon
                            Do you know if CD3215C00Z is compatible with CD3215C00?
                            • mon2
                              • 14868
                              Someone on Rossmann forum did this and believe it worked.
                              • ronaldopdias
                                • Jul 2015
                                • 100
                                • United Kingdon
                                U3200 replaced and fixed the problem
                                Battery is now charging and working fine.
                                Thanks for your help.​
                                • mon2
                                  • 14868
                                  Well done!
