MacBook - 2021 A2485 - 16 inch - 820-02100-A - No Boot / No Power
  • mon2
    • 14753
    Do you see the Apple logo? Do you see the normal graphics on the LCD display using a torch / phone light? Does the keycaps key light toggle?
    • No Lan
      [Macbook pro A1708] [Boot loop] [Trackpad ?]
      by No Lan
      Hey everyone,
      Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
      Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
      Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
      05-24-2025, 03:09 PM
    • twonk9098
      Macbook Pro mid 2015 battery required to boot?
      by twonk9098
      I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
      The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
      This model has the newer trackpad which is not clickable when turned off.
      At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
      If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
      12-10-2024, 06:51 PM
    • veedo
      Macbook A2442 820-02098 boot and display issue
      by veedo
      Hi All
      I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
      Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
      I found component UD290 ( SF0101-I2C) little...
      04-01-2024, 06:06 AM
    • PITERPENY
      Macbook A2251 no boot
      by PITERPENY
      The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
      01-05-2025, 03:11 PM
    • spwoof
      Seeking LCD Schematic for MacBook Pro M1 A2485 - Aiming to Repair, Not Replace
      by spwoof
      I'm currently working on a MacBook Pro A2485 and have encountered an issue with the LCD. Instead of opting for a full replacement, I'm interested in performing an in-depth repair on the LCD itself. I'm hoping to find the schematic for the LCD in order to understand its architecture and troubleshoot more effectively.
      If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook...
      10-05-2024, 08:02 AM
