MacBook - 2021 A2485 - 16 inch - 820-02100-A - No Boot / No Power
  • applejuice95
    • May 2023
    • 49
    If you're asking me to stick one lead on the top of 667 and the other lead on the top of 707.. Theres anywhere from 5M Ohms to 7K Ohms of resistance. Jumps all over the place
    • applejuice95
      • May 2023
      • 49
      You saw the message about L5800 glowing under thermal when power is plugged in right? Via MagSafe or USB-C either way. ??
      • applejuice95
        • May 2023
        • 49
        • mon2
          • 14753
          Then there is a trace break between CR707 and CR667 (and equivalent). At your discretion, mate a piece of wire to create a common power rail, which it is not at this time.
          As an example, use a piece of wire to join CR667 to CR707 (or similar). Be 100% sure the netname is the same on the source and destination of the wire. Most likely the liquid damage and ultrasonic bath ate away at the trace(s) that mated these on the PCB.
          • applejuice95
            • May 2023
            • 49
            There is no component on the board that these two meet at?
            • applejuice95
              • May 2023
              • 49
              Sorry, I'm an idiot..
              Was reading the ground side of the damn caps CR667 637 and 607.
              Resistance to ground all the way around for this rail is 2.5K Ohms
              • applejuice95
                • May 2023
                • 49
                How can we test Inductor L5800? Since its glowing under thermal when board has power?
                • mon2
                  • 14753
                  I have not seen this board on my bench so you are my eyes.
                  Are there parts @ UR700? UR730? UR600? UR630? UR660? If yes, check what the resistance is from this region's PP3V8_AON to L5800.
                  ** IGNORE the above - not relevant **
                  Why is L5800 heating up and powering off? Someone is consuming too much current and exceeding the current draw and forcing this regulator to power OFF. Then the cycle repeats.
                  Study who consumes this power rail. Test the resistance to ground on each such rail and you will find your bad boy (not Will Smith).
                  Hunt for the CPU rail and check it first.
                  • applejuice95
                    • May 2023
                    • 49
                    Just for giggles heres a photo of it..
                    Hard to measure this because the Inductor is on the other side of the board.
                    BUT - this measurement of Res to Ground, is a whopping 1-0.8 ohms across all of those parts
                    • mon2
                      • 14753
                      Ok - this is literally a dead short. To confirm, you are measuring the resistance from L5800 to ground and the resistance is ~1R = 1 ohms?
                      Next, repeat but with one probe at L5800 and the other probe @ PPVDD_DCS_S1. What is the resistance?
                      Internally inside the U7700 device are mosfets that take the higher voltage of PP3V8_AON and lower it to the required CPU voltage. If the mosfet has leaked, the target low voltage device is likely to be dead and then it is game over.
                      Do you have an adjustable power supply? You can use that power supply to dial up 0v8 to max of 1v0 and inject this voltage onto the shorted PP3V8_AON rail. Then test which part on the part heats up. If it is the CPU, game over. You will have to remove the heatsink to observe if it is heating up.
                      • applejuice95
                        • May 2023
                        • 49
                        No L5800 to ground is 4.5K Ohms both sides..
                        You asked to measure L5800 resistance to UR600/700 regions PP3V8_AON local rail (which by the way is CR667 , CR607, CR637 orCR737, CR767, CR707)
                        That measurement is .8 Ohms.. Nothing there..
                        UPDATE - Resistance of L5800 to PPVDD_DCS_S1 is 3K Ohms
                        • mon2
                          • 14753
                          Aside from L5800, someone else must be heating up. Search around with your thermal camera. Someone is consuming this heavy current and causing LF5800 to heat up.
                          • applejuice95
                            • May 2023
                            • 49
                            R6809 gets hot first then goes down before L5800 heats up. How do you test resistors like this to see if they are good or not?
                            Thank you for all of your help.
                            • mon2
                              • 14753
                              Unable to find R6809.
                              • applejuice95
                                • May 2023
                                • 49
                                R5809 - My apologies.
                                When I plug power into board: And look under thermal
                                R5809 flashes for a second, then Q5800 flashes for just a second, then L5800 starts glowing steady ..
                                As fast as 123.. Very fast.. flash, flash, steady glow.
                                Should I inject voltage on this 3V8 rail that includes both this glowing inductor and the resistor?
                                • applejuice95
                                  • May 2023
                                  • 49
                                  Voltages of Q5800 pins
                                  Pin 1 - 12V
                                  Pin 3 - 3.8V
                                  Pin 4 - 0.8V
                                  Pin 5 - 3.8V
                                  Pin 6 & 7 - 3.8V
                                  C5811 coming from pin 4 has 9V on pin 1 and 3.8V on pin 2
                                  Voltage on L5800 is 3.8V on both sides
                                  • mon2
                                    • 14753
                                    Do you see the same on Q5820 and Q5840? Also thermally throbbing?
                                    • applejuice95
                                      • May 2023
                                      • 49
                                      Only L5800 glows. Q5800 glows for less than a second when the computer cycles.
                                      U2000 gets some glow.
                                      and UG900 flashes for less than a second every 8 seconds or so.
                                      • mon2
                                        • 14753
                                        Remove all power. Measure the resistance across the capacitor @ C5810. What is the measurement?
                                        • applejuice95
                                          • May 2023
                                          • 49
                                          Found a short at CN983. Put it back together. Got it to get to DFU finally. Restored OS.
                                          Machine so far works. but has no backlight. And when HDMI is plugged in, the screen is fuzzy. So no external display, and no internal backlight. Cannot confirm if the display assembly is bad or not, very odd that external display gives white fuzzy screen and no display
                                          • No Lan
                                            [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                            by No Lan
                                            Hey everyone,
                                            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                            05-24-2025, 03:09 PM
                                          • twonk9098
                                            Macbook Pro mid 2015 battery required to boot?
                                            by twonk9098
                                            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                                            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                                            This model has the newer trackpad which is not clickable when turned off.
                                            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                                            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                                            12-10-2024, 06:51 PM
                                          • veedo
                                            Macbook A2442 820-02098 boot and display issue
                                            by veedo
                                            Hi All
                                            I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                                            Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                                            I found component UD290 ( SF0101-I2C) little...
                                            04-01-2024, 06:06 AM
                                          • PITERPENY
                                            Macbook A2251 no boot
                                            by PITERPENY
                                            The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
                                            01-05-2025, 03:11 PM
                                          • spwoof
                                            Seeking LCD Schematic for MacBook Pro M1 A2485 - Aiming to Repair, Not Replace
                                            by spwoof
                                            I'm currently working on a MacBook Pro A2485 and have encountered an issue with the LCD. Instead of opting for a full replacement, I'm interested in performing an in-depth repair on the LCD itself. I'm hoping to find the schematic for the LCD in order to understand its architecture and troubleshoot more effectively.
                                            If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook...
                                            10-05-2024, 08:02 AM
