[help]820-01700 "mistery problem"
  • phantomEVO
    • Mar 2013
    • 488
    I repeat: macbook switching after chaning all 4 usb controller and flashing only one tbt rom . u7650 changed before by another technician with a wrong one. re changed by me with the right one. from that moment, macbook works like this
    Dropbox
    www.dropbox.com
    then i've tried to reflash t2 rom and from that moment only 5v and direclty to dfu mode Click image for larger version  Name:	dataurl506483.gif Views:	0 Size:	43 Bytes ID:	3574559 even with original backup
    • phantomEVO
      • Mar 2013
      • 488
      i've discovered something (maybe) interesting... PP2V5_NAND_SSD1 and PP2V5_NAND_SSD10 have good diode values, but if i connect the power supply, and i disconnect it, diode values go down to 0,060...is it normal?
      • phantomEVO
        • Mar 2013
        • 488
        i',m going crazy
        • phantomEVO
          • Mar 2013
          • 488
          ppbus g3h and pp3v3 g3h sns ssd0/1 present (12,3 and 3,3)
          1,8slprs present
          • reformatt
            • Feb 2020
            • 1406
            Review https://logi.wiki/index.php/CD3217_a...er_on_Sequence
            If you have 12.3V for PPBUS, this means the T2 isn't starting (this chip replaces the SMC in previous versions - it's much more complex but performs the same basic functions). As per the Wiki page, you need to have all 4 CD3217's communicating AND have the correct I2C programming for the left side CD3217's (as they have one time programmable I2C address burnt in). Best is to source from a donor board that has not been reworked.
            T2 also has it's own PMU IC, so the Wiki page also resistances for each power rail. The T2 has to boot from it's own internal ROM, before switching on SSD power rails and loading BridgeOS. DFU revive or restore or messing with T2 ROM is a bad idea if you have a pre-existing hardware fault as it will not complete and now you have 2 faults. If you have restored the original T2 ROM and it's still in DFU, review your programming setup or your soldering. The original boot rom should at least allow the T2 to internally start before proceeding to switch on SSD's and load BridgeOS.
            As the board has been reworked, and you have also done your own rework, the likelihood is additional faults have been introduced, further muddying the waters. My experience is to review every bit of rework on the board, and I'd start by comparing diode values for each reworked section against openboardview data. Do you trust the previous tech's work? I had once a 'repair' where a tech had replaced a cap only to find what he fitted was wrong or defective. You end up going around in circles if you don't check their work.
            The bulk of the issues on these 16" MAC's are corrosion on either wing of the board where the fan intakes are, or shorted NAND's from a shorted TPS62180. Unfortunately, most people dive straight into replacing CD3217's, use the wrong ones, or a defective one from a donor board, adding an additional layer of issues.
            • phantomEVO
              • Mar 2013
              • 488
              thank you for your awesome reply!
              like i said before, at the beginning i had only 5 v.
              so i have installed 2 controller from an identical donor board (same place), then the other two.
              then i flashed ONLY one tbt rom and i had had 20v! so i'm pretty sure that controller and t2 was ok! but no boot! no short around each nand and no short around its power supply.
              after t2 rom flash, it goes DIRECTLY in dfu mode and obviously i have only 5v.
              i have used my minipro to read t2 eeprom.. schematic says it is "MX25U3235F" so i have select it... but i have had some warning about "DEVICE ID" (like different from what expected). i've done the backup and tried to write it with error! so i have seen this video
              https://www.youtube.com/watch?v=8x15Ye406uY
              he select model "at25sl321: this is not present on my progrm....so searching on the website i've found that the programmer ch431 support this eeprom
              bought the programmer and used the sofwtare to write a dump from internet and my backup without luck!!! always in dfu directly
              are you 100% sure that erasing eeprom and reprogramming it, it will work without problem?
              because if it is like this, i'm 100% sure that the eeprom is solder good and i have 50% of change of a writing problem 50% of backup problem.
              in the meantime i've bough a new programmer (t48) that native supports this eeprom...
              • mon2
                • Dec 2019
                • 14140
                It is normal to expect the DFU mode after the T2 reflashing.
                Watch this video:
                https://youtu.be/n164YwaI4cQ
                • phantomEVO
                  • Mar 2013
                  • 488
                  yes i know, but is it normale that flashing my ioriginal backup is still in dfu?
                  • mon2
                    • Dec 2019
                    • 14140
                    Can you confirm if you had a valid known good T2 flash dump at the start of this repair? Perhaps consider to test a T2 rom from a donor board onto your target board. Do not do anything but remove and replace as-is.
                    • phantomEVO
                      • Mar 2013
                      • 488
                      i repeat! is it sure that erasing and reflashing MY T2 ROM BACKUP, IT WILL GO TO DFU? MAYBE I'VE FOUND THE PROBLEM
                      i have used a dump from the tool t2 unlock mina
                      https://www.youtube.com/watch?v=EMnkSZSDb8c
                      in this video, as soon as you flash the file, it goes directly in dfu mode .
                      but in this video, when he flash is own t2 rom backup simply changing serial number
                      https://www.youtube.com/watch?v=-6ndWqQ7PW0&t=177s
                      it doesnt go directly to dfu!!
                      even in this video!
                      https://www.youtube.com/watch?v=-lYn5gnK_Es&t=139s
                      so just because i'm not sure about the health of my t2 rom backup, what do you think if i flash one of this?
                      https://www.badcaps.net/forum/troubl...2-soc-rom-dump
                      • phantomEVO
                        • Mar 2013
                        • 488
                        other question: is it sure that ppbus_g3h MUST be @12,6? because i have 12,3v since the beginning
                        • mon2
                          • Dec 2019
                          • 14140
                          When T2 boots, you will have 12v6.
                          • phantomEVO
                            • Mar 2013
                            • 488
                            i think it would be better to assure that main voltages (for example) are all presents!
                            i have no short anywhere diodes readings are all good, but at the same time, main vltages for nand ar not present. i dont think that both pm for nands are dead TOGETHER.
                            Maybe i miss something that power on them????
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • layad
                              820-01521 ,a1932 stuck on 5.18v 0.22v
                              by layad
                              hi there
                              one of the ports not showing anything on the meter , dead ( one next to screen)
                              othe port shows 5v , 0.22a
                              PP3V3_UPC_XB_LDO was shorted on u3200 , changed u3200 . now meter shows the same reading on both ports (5v , 0.22a)
                              all ldos are present apart of PP1V1_UPC_XB_LDO_BMC , its 0v on both no short
                              no dfu mode
                              PP1V8_G3S missing no short
                              u7650 enable signal is 0v no shorts
                              any suggestion?
                              11-12-2022, 10:23 AM
                            • gleniu
                              Acer Nitro 5 AN517-52-56A5 - won't charge, shorts the AC adapter
                              by gleniu
                              I have a problem with Acer Nitro 5 AN517-52-56A5 (motherboard: GH51M LA-K862P Rev: 1A). I was playing TLoU2, which is a rather demanding game, for a few hours, unless the notebook turned off (my guess is that the battery drained to 0%). Now, when I connect the AC adapter, the LEDs are not coming on and the laptop doesn't charge.
                              It also shorts the AC adapter - I've checked two of them from different manufacturers. Though the AC adapter gives 19,5V as expected, the voltage drops to 0V when I connect it and disconnect from laptop - it comes back to 19,5V when I reset...
                              05-02-2025, 06:48 AM
                            • flusher
                              Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
                              by flusher
                              Bought myself a project thing. Apple MBP16" A2141 820-01700
                              No shorts, no visible waterdamage.
                              Dead. no history.
                              All USBC ports do 20V and charging battery.
                              If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
                              But what PMIC does is that it power cycles(dropping to...
                              02-21-2025, 03:12 PM
                            • HTR-Informatique
                              by HTR-Informatique
                              02-09-2025, 06:51 AM
