820-01521 ,a1932 stuck on 5.18v 0.22v
  • layad
    • Nov 2011
    • 250
    hi there
    one of the ports not showing anything on the meter , dead ( one next to screen)
    othe port shows 5v , 0.22a
    PP3V3_UPC_XB_LDO was shorted on u3200 , changed u3200 . now meter shows the same reading on both ports (5v , 0.22a)
    all ldos are present apart of PP1V1_UPC_XB_LDO_BMC , its 0v on both no short
    no dfu mode
    PP1V8_G3S missing no short
    u7650 enable signal is 0v no shorts
    any suggestion?
  • mon2
    • 14085
    Re: 820-01521 ,a1932 stuck on 5.18v 0.22v
    Both CD3215 will need to be working before you can dial up the 20V power delivery contract.
    Your case will be similar to this one:
    https://boards.rossmanngroup.com/thr...an-spin.60765/
    Inspect the USBC connector that does not show anything on the meter -> likely you will have USB C connector damage or contact faults. Review to clean with IPA and/or replace the paddle board and test again.
    Check the LDO rail of each local CD3215 to see if the voltages are correct from each.
    Are your CD3215 from a reliable vendor or are from a donor board ?
    You can study this document as a general guide on when 20V is selected:
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    • mferna14
      820-01521-A (MacBook Air A1932 2019) stuck on 5V
      by mferna14
      Hi all dear friend., today I am working on 820-01521-A logic board (MacBook Air A1932 2019) stuck on 5V .19 milliamps. The history of this logic board was liquid spill on major components. First gave a good cleanup & both CD3215C00Z were getting very hot, so I replaced both. Now on the 12V coil, there is only 5v present & 3.3V is perfect. In some area like PPVIN_G3H_P3V3G3HRTC , PPBUS_G3H_TPAD etc., 12V is perfect. On the 5v coil .2 volts only. I checked the enable signal on the regulator chip, enable is NOT present. The logic board is very clean, I do not see any signs of spill anymore....
      03-27-2025, 04:52 PM
    • Junior†
      Macbook Pro A1932 (820-01521-A) Stuck at 4.95V 30mA
      by Junior†
      I have a customer that mailed me his a1932 (820-01521-A), all i know is that it is completely dead.
      here are my measurements/observations
      with battery/fan connected (connected to 65W charger):
      top USBC port: 4.950V (starts at ~75ma, then settles at 30ma) note: sometimes this port has the same behavior as bottom port with battery connected (so 20v 0ma)
      bottom USBC port: 20V (80ma for a split second then goes to zero)
      without battery, fan is still connected:
      top USBC port: 4.950V (starts at ~75ma, then settles at 30ma)...
      01-18-2024, 03:43 PM
    • mitchw
      MacBook Air 2018 A1932 820-01521 stuck at 5V, but succesfully does the DFU and boots into OS installer
      by mitchw
      I have a 820-01521 that is stuck at 5V, and drawing just 230mA.
      I did some troubleshooting, and managed to charge the battery up (was at 0%) using a different logic board.
      Also I ran DFU and it did it successfully. Had to use a PMU_FORCE_DFU jumper to do it.
      At this point the laptop started up and it successfully boots into the OS Install.
      The charger is now at 20V, but drawing 0mA, so the laptop is essentially running off the battery. It doesn't detect the charger...
      I think there could be a problem with one of the CD3215s, but all the LDOs are the...
      01-04-2024, 01:47 PM
    • Instafixx
      Macbook A1932 One Port stuck at 5v.
      by Instafixx
      I have a Macbook A1932 820-01521.
      One port was drawing 20V and another port was drawing 5V. Machine did turn on.
      Found corrosion near U3100 the CD3215 .
      2 Resistors were missing. Cleaned and replaced them but still the same.
      Reflow a few nearby components in that area in which i suspected corossion.
      Is it a CD3215 fault. Is there any way i can check?
      08-22-2023, 06:00 AM
    • stormanimal83
      Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
      by stormanimal83
      Hey....
      Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
      my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
      01-18-2024, 02:15 PM
