MacBook Pro 16" A2141 820-01700 T2 SOC ROM DUMP
Tags: None
my old bin not working properly
0.60 amp no display and off and onAttached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
by soflesHi there.
I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
Now situation looks like this, If... -
by PITERPENYHi. I've encountered this problem for the first time. I need help. Has anyone encountered it before and how did you solve it? Only MacOS Catalina can be installed on a MacBook via online recovery, and the Mac works fine (although it's also running slowly). But when I try to update the MacBook, it constantly crashes, and nothing else works except Catalina. Attempts to install Venture or Monterey Jack from an external drive are also impossible. I tried DFU recovery, but I can still only install Catalina and can't update, even though the system offers to update to Tahoe. It's impossible to run any...
I HAVE A MACBOOK PRO A2141 820-01700 THIS BOARD IS PP2V5_NAND_SSD1 SHORT TO GROUND THEN I CHECK ONE SIDE U8600 IS SHORT THIS SIDE IS ONLY ONE CHIP U8600 OTHER SIDE
PP2V5_NAND_SSD1 IS OK AND U9100 U9200 U9300 U9400 IS ALSO OK Will removing the U8600 fix the board or will I have to install a new one
Link to boardview --> https://www.badcaps.net/forum/troubl...91#post1449091 -
by resistor83Hi everyone, I have a 2019 MacBook Pro A2141 and I bought a motherboard on AliExpress because mine wasn't repairable. I installed it and everything worked fine for a few days, but after a few more days the keyboard barely worked. Sometimes if I reset the SMC, it seemed to restart, but it only worked for a few seconds. I noticed that when I pressed on the keyboard connector area, the keyboard restarts, but I don't think it's a connector issue. Have you ever had a similar problem? I've included a video below where I press on the external chassis.
The seller wrote...04-19-2026, 12:14 PM -
MacBook Pro A2141 EMC 3347
I need a competent person to unlock/bypass iCloud during installation, thank you. - Loading...
God Bless You Bro!!!
