MB no turn on, apparent damage but voltage, but none from voltage reg IC - ThinkPad P17 MB NM-C651 - what next?
  • wraster
    • Jan 2025
    • 18
    Hi, I have a ThinkPad P17 motherboard with intel chipset, NM-C651 that appears to not power on.
    - No light with DC plugged in, no signal to external monitor connected directly to HDMI on motherboard (no GPU module attached).
    - There appears to be damage on a ferrite bead chip (pic here) on the main power rail (20 V), but there is a 20V reading to the in-side, and 15V reading on the out-side. After this chip, the power goes to an IC that I think regulates voltage (NCP81210MNTXG_QFN40, PU1301 in the boardview screenshot here), but I read no voltage on pin 7, nor 11-13.
    - After this IC in the circuit is the inductor just physically below it (down in the boardview screenshot here - PL1302) which also reads no voltage on either side.
    My questions are:
    Does this suggest that this IC is bunk? Or could the problem be with how the ferrite bead chip is changing the power signal?
    What do you recommend next to diagnose, or move on to try replacing one or both of these components?
    Much thanks
    Click image for larger version  Name:	image.png Views:	0 Size:	2.14 MB ID:	3568244
    Click image for larger version  Name:	image.png Views:	0 Size:	242.9 KB ID:	3568243
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    First step is to remove the coiland then measure resistance to GND on both ends. One end is very likely shorted. If indeed shorted, then remove components on that line one by one to remove shorting or u can inject 1V/5A on the shorted side of coil.
    • wraster
      • Jan 2025
      • 18
      Thanks -The coil you mean is the burned-looking chip, right? PL1301? or PL1302, the bigger one?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PL1301
        • wraster
          • Jan 2025
          • 18
          mcplslg123 can you explain a little about the logic behind your proposal? I am very new to this but understand the basics of electronic circuits and components. What physically could likely be causing a short here? Malformed tracks within the plastic board? Or are you thinking something internal to some component?
          • mon2
            • 14728
            Most likely it will be a shorted component. What is known at this time is that the inductor that is in series of this load is the inductor @ PL1301. It is now defective / burnt from the excessive current draw. Now, this part must be fluxed and removed with tweezers. Then with no power to the board, test the resistance to ground on each side of the PCB pads. Need to know if the low resistance that caused to burn out this inductor is on the producer side (regulator side) or the consumer side (load / downstream). Post the exact, measurements in ohms for your tests.
            • wraster
              • Jan 2025
              • 18
              I understand, thank you!
              My summary is attached.
              I removed the part and measured resistance to ground on both pads:
              1. Upstream pad: 1.5M Ω
              2. Downstream pad (connects to IC): more Ω than my multimeter can measure
              I discovered that one of the nearest capacitors, closer to the power source, was completely missing. I used hot air to remove the inductor and while this missing capacitor should have been on the other side of the board, it's not right underneath and I wasn't blasting that area with hot air directly, so while it's possible that it fell off while I was desoldering the other component, I don't think it was. I measured resistance to ground of both pads where this capacitor would be and:
              1. 170k Ω
              2. 10 Ω
              That side of the capacitor connects to ground in the figure so that makes sense, right?
              So is the 1.5M Ω to ground from the inductor less than expected?
              • wraster
                • Jan 2025
                • 18
                Hi mon2 or mcplslg123 can you share your insights on the measurements from my board? Does it indicate to you whether there is a short on one side or another? Thank you!
                Any thoughts on the apparent missing capacitor and it's possible contribution to the source of the problem?
                • mon2
                  • 14728
                  Is your meter manual or automatic scaling for the resistance mode? If manual, switch to a higher scale to take a measurement on the pad that is reporting 'OL' = over limit on most meters.
                  What is the resistance across the coil PL1301 that was removed? Place the meter probes on each end of this removed component. The burn marks indicate that high current has passed through this part or someone with a high temp soldering iron has touched each of the ends of this part. If no one has worked on this board, then recommend to replace this part. Technically the part is not required but is acting like an EMI noise filter. In a pinch, the pads could just be shorted to allow for the 20V to travel to the IC. Otherwise, Digikey / Mouser should offer a replacement for the component.
                  https://www.digikey.com/en/products/...KgHIoAiIAugL5A
                  * order a few extras
                  Share the meter face pic of your meter for a quick review for the setting that is reporting a high resistance to ground on the IC side. That is, perhaps you will need to order other parts so wait till more is known about this board.
                  • Instafixx
                    Macbook A2179 820-01958
                    by Instafixx
                    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                    I checked the Power Sequences below and found this -
                    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                    05-20-2023, 05:19 AM
                  • Fernon@Repair
                    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                    by Fernon@Repair
                    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                    VCCIO voltage ok
                    VCCSA Voltage OK
                    VCCPLL Voltage OK
                    Ram Voltage ok
                    RamVTT OK
                    VPP 2.5 OK
                    But No Core Voltage
                    and i want to this vrm ic datasheet or pinout (ISL69269)
                    anyone have this ic pinout voltages?...
                    06-25-2025, 07:19 AM
                  • bogosort
                    Asus FX505GT, voltage reading after minor liquid damage
                    by bogosort
                    TLDR:
                    Are these voltage readings normal? What should I do next?
                    Long story:
                    I have an Asus FX505GT laptop that received a small amount of liquid.
                    Since then, installing the Intel GPU drivers causes a black screen, then an infinite Windows loading until I uninstall the driver using safe mode.
                    The laptop still works when using the default Microsoft display driver, but the video memory shows as unknown in hwinfo.
                    Installing the GTX 1650 max-q drivers works, but there does not seem to be any acceleration....
                    12-07-2022, 02:54 PM
                    Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                    I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                    The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                    Now...
                    06-09-2024, 10:57 AM
                  • electron_jj
                    Panasonic TH-L42D25A checking the PSU output voltage
                    by electron_jj
                    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                    08-29-2021, 08:13 AM
