La-501P does not charge the battery
  • Varon23
    • May 2018
    • 19
    • Poland
    Hey!. The La-501P motherboard does not charge the battery.
    It shows, for example, 30% and stands still. on different batteries. I changed and reprogrammed the BIOS and KBC. I replaced isl88739a. Further the same. I noticed that on "Amon" (6 PIN of the ISL system) there is a voltage of 4V and it should not.
    No voltage at Comp_ChG (10 PIN)
    and therefore there is no PQB1, PQB2 control
    Someone can help me? Why does ISL generate an Amon signal?
  • mon2
    • Dec 2019
    • 14262
    What is the voltage to ground of the following pins on the charger IC?
    ACIN
    DCIN
    ACOK
    CSIP
    CSIN
    • Varon23
      • May 2018
      • 19
      • Poland
      ACIN-2V
      DCIN- 19v
      (Sometimes after connecting the power supply, the voltage jumps and the ticking is heard in the power supply):
      ACOK-3V
      CSiP-19V
      CSIN-19V​
      • mon2
        • Dec 2019
        • 14262
        ACIN is too low if truly at 2v with the adapter. This voltage should be 2v4 or higher to be able to announce that a suitable power adapter is attached.
        Be sure the power adapter is the original and suitable power rated unit. If yes, check the resistors that are on this ACIN pin.
        • Varon23
          • May 2018
          • 19
          • Poland
          I have a second efficient motherboard for comparison. There is an identical voltage on Acin. 2.2v. Official resistors.
          The voltage is identical on the tilted batteries, but the damaged is accompanied by AMON.
          What is this signal caused? Why did he appear?
          In addition, I forgot to write that after starting the processor works on 0.78 GHz. Regardless of whether the power supply is connected or not.
          • mon2
            • Dec 2019
            • 14262
            See attached.
            Measure the voltage to ground on each leg of resistor @ PRB12. The high side pin of PRB12 should be @ 5v.
            Based on this voltage, the ACIN voltage should be @ ~3v. If the voltage is too low, the logic board is assuming that the power adapter is not suitable and then charging of the battery will halt. The CPU will also be throttled to save power.
            • Varon23
              • May 2018
              • 19
              • Poland
              Acin- 3.2v
              vdd_chg 5.2v
              It is identical on an efficient motherboard.​
              • mon2
                • Dec 2019
                • 14262
                Acin- 3.2v
                Review post # 3.
                • Varon23
                  • May 2018
                  • 19
                  • Poland
                  I see. In the Acin diagram he is as 1 pin in Boardview 1 pin to acin_chg a 2 pin is acin.
                  Acin- 3.2v
                  Acin_chg- 2v.
                  Sorry for oversight.​
                  • techfreak9356
                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                    by techfreak9356
                    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                    09-14-2023, 11:10 PM
                  • razenxd
                    How can I charge that battery pack?
                    by razenxd
                    it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                    At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                    Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                    Now, I have noticed a few things.
                    The "dead" battery, while connected to charger and NOT Charging will...
                    12-05-2024, 06:11 AM
                  • ruletero
                    Acer a515-43 low battery charge voltage
                    by ruletero
                    Hi
                    Acer A515-43
                    LA-H801P
                    Fail: Does not charge battery, has low voltaje on connector.
                    Laptop didn't want to turn on, only charge led blinked.
                    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                    10-24-2022, 02:31 PM
                  • Klevjetack
                    Charge a L19D3PDA battery externally from the laptop
                    by Klevjetack
                    Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                    03-05-2024, 07:26 AM
                  • dclass-pro
                    Latitude 3301 not charge battery
                    by dclass-pro
                    Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                    I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                    I noticed 2 things:
                    1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                    2) if I try to turn it on without the battery...
                    05-06-2025, 06:19 AM
