A305-S6825 Plug tip size?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I need an inner and outer diameter measurement for a tip dc plug for Toshiba A305-S6825 3.95A 19v charger.
    I got an aftermarket charger with interchangeable tips for repair, owner lost first tip that came with it. I had one on hand, gave that to him after I replaced nec OE907 cap and few weeks later, he broke that tip, pin broke off.
    I was looking online it seems to be 2.5mm inner and 5.5mm outer, but for some reason I don't think this is correct.
    Anyone have a charger and A305 series laptop could confirm measurement for me please?
  • dj_ricoh
    • 2073
    • uk
    Re: A305-S6825 Plug tip size?
    I got like 3 chargers with me but I use a universal with interchangeable tips.
    do you believe me I got nothing to measure with?
    maybe you know the size of the jack or something.
    P.s. its good for A100 Toshiba
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      What kind of tech are you that doesn't have a caliper to measure with?????!!!!!1111 J/king.
      I think it may be the one on the right. I asked him last night if he had the broken tip and he did. I measured it today it's 5mm outer and 2.5 inner.
      • dj_ricoh
        • 2073
        • uk
        i`m sorry :| i repair notebooks not walls and roofs. i sold the makita box.
          • 31248
          several clone charger company's say it's 5.5 / 2.5
          the trick may be getting one at a reasonable price.
          http://www.rapidonline.com/cables-co...-2-5mm-50-1347
          http://www.rapidonline.com/cables-co...-2-5mm-50-1356
          so now you have a make and product code.
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
            Narrow VDC applications where the system power source is
            either the battery pack or the regulated output of the charger.
            This makes the max voltage to the system equal to the max
            battery voltage instead of the max adapter voltage. Operating
            at lower system voltage can improve...
            11-05-2024, 04:43 PM
