A305-S6825 Plug tip size?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I need an inner and outer diameter measurement for a tip dc plug for Toshiba A305-S6825 3.95A 19v charger.
    I got an aftermarket charger with interchangeable tips for repair, owner lost first tip that came with it. I had one on hand, gave that to him after I replaced nec OE907 cap and few weeks later, he broke that tip, pin broke off.
    I was looking online it seems to be 2.5mm inner and 5.5mm outer, but for some reason I don't think this is correct.
    Anyone have a charger and A305 series laptop could confirm measurement for me please?
  • dj_ricoh
    • 2073
    Re: A305-S6825 Plug tip size?
    I got like 3 chargers with me but I use a universal with interchangeable tips.
    do you believe me I got nothing to measure with?
    maybe you know the size of the jack or something.
    P.s. its good for A100 Toshiba
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      What kind of tech are you that doesn't have a caliper to measure with?????!!!!!1111 J/king.
      I think it may be the one on the right. I asked him last night if he had the broken tip and he did. I measured it today it's 5mm outer and 2.5 inner.
      • dj_ricoh
        • 2073
        i`m sorry :| i repair notebooks not walls and roofs. i sold the makita box.
          • 30950
          several clone charger company's say it's 5.5 / 2.5
          the trick may be getting one at a reasonable price.
          http://www.rapidonline.com/cables-co...-2-5mm-50-1347
          http://www.rapidonline.com/cables-co...-2-5mm-50-1356
          so now you have a make and product code.
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
            Narrow VDC applications where the system power source is
            either the battery pack or the regulated output of the charger.
            This makes the max voltage to the system equal to the max
            battery voltage instead of the max adapter voltage. Operating
            at lower system voltage can improve...
            11-05-2024, 04:43 PM
          • exerion5000
            DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
            by exerion5000
            Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
            below normal, as if it were operating in an extreme energy...
            10-15-2023, 02:12 PM
          • RWS93
            Apple A1990 / Board number: 820-01041
            by RWS93
            Brand: Apple
            Model: A1990
            Problem: I am not an Apple kind of guy to start with. But I am quite experienced with motherboard repairs in general. So the laptop is stuck with 5v 0.250A and does not negotiate 20v. Same symptom on all 4 USB C ports. When charger is plugged the amps start at around 0.060 then go trough: 0.100 - 0.180 - 0.230 - 0.244 and stay like this. Laptop responds to the power button: once I hold it long enough current goes down to 0.060A and then up to previous levels.
            Board clean, no liquid damage, no corrosion....
            04-11-2024, 03:43 PM
