Hello all! I need Schematic&Boardview Quanta G7HA. Thanks for help.
I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
I havent found any shorts on the board.
I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p... -
by lpraderiHello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
In some cases to use LVDS screen PCB use converter IC RTD2132/6
Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
...11-25-2023, 09:31 AM -
by Francisco.sHello, I'm trying to repair an HP 27 Quanta N76 (DA0N76MB6E0 Rev E).
I only get 3.3V, 5V, and 1.05V; no other voltages.
I tried the BIOS and changed the KBC. The KBC self-programmed upon power-up after changing it.
The VR-On is missing for NCP81220, but 1.2V is also missing for DDR4, so 1P2V_PWRGD is low. SUSON or DDR_VTT_EN are not present on the DDR4 voltage regulator (RT8231BGQW). It seems the KBC isn't triggering these signals.
I'm using the Quanta N91 schematic, but there are too many changes that make it nearly impossible to measure signal...07-14-2025, 02:20 PM -
by pleomax1110Hello, everyone!
I need schematics of this board:
Model: Dell Inspiron 14z-N411z
Board No: DA0R05MB8D2
REV: D
Quanta project: R05
I have already seen the file ''quanta R02_UMA.pdf'' in this thread:
https://www.badcaps.net/forum/showth...dell+14z-n411z
but it is differ from R05_UMA and it can't help me in my case.
The main problem of the laptop is as follows:
LED backlight is absent in the screen and appropriate 36's contact of the LVDS 40pin 1ch connector is shorted...-
by sevazI search the boardview or schematic for Quanta H9R DA0H9RMBAF0 Rev F BoardView
pls-
- Loading...
