Asus K53SD - no power
  • cephei328
    sparky
    • Feb 2014
    • 49
    • NewZealand
    Hi guys!
    Need help with this
    Asus K53SD motherboard - No power
    Charger controller tested OK
    System power DC/DC - is the problem
    3.3 Volts OK but no 5 Volts from the RT8206A chip
    RT8206A has 2 EN signals (for 3.3 and 5 Volts resp) When tested 3.3 Volts EN signal on pin 27 is OK but no EN signal at pin 14 (Which is EN for 5 volts). Don't have the Schematics to trace the signal path
    Help would be much appreciated!
  • dj_ricoh
    • 2073
    • uk
    Re: Asus K53SD - no power
    we need the mobo code so we can point where to look and check.
    you mobo code its Compal LA-....?
    • atsio
      • Oct 2013
      • 819
      • Greece
      Asus uses only Asus boards
      • dj_ricoh
        • 2073
        • uk
        but i saw a K53; i dont remeber if it was F or T but i did had compal board
        i swear
        • atsio
          • Oct 2013
          • 819
          • Greece
          i swear
          Yes, you are right, I am sorry
          • cephei328
            sparky
            • Feb 2014
            • 49
            • NewZealand
            Well, Its a Asus Motherboard K53SJ. For me finding Schematics is hard.
            • hansie55
              • Dec 2013
              • 254
              • Netherlands
              The onliest thing I could find for the K53SJ (=mobo K53SV) up till now is the board view.
              Anybody found the schematics already?
              Is there a unlocked Bios for this machine? I only can find the Slic2.1.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                im not a memeber, thay have it
                http://www.elvikom.pl/viewtopic.php?...016&hilit=x53s
                Im Back... sort of...
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • ShadowAi
                  ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                  by ShadowAi
                  Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                  Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                  After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                  03-15-2024, 10:46 AM
                • meraklinetx
                  Asus Z97-a power cycle, no boot no cpu voltage
                  by meraklinetx
                  Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                  05-10-2023, 06:08 AM
                • Duranitron
                  Asus x512dk rev 2.1 power on problem
                  by Duranitron
                  When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                  Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                  11-26-2024, 10:22 PM
