MacBook Air A2337 display
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    the picture disappears from the display after a few seconds. How to fix it? Who has encountered this? Tell me how to fix it?
    https://youtube.com/shorts/RL7Sd6B5I4I?feature=shared
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Having the same mac where display is perfectly fine for 2-5 minutes after user login and then it starts flickering and after continuing this way for 30sec-1 min it goes dark.
    capslock can be still toggled. Some kind of vertical lines appear(in different patterns each time) before going dark.
    Is this a screen issue/flexgate issue or logic board issue? Dont have a spare screen to test.
    Posted this here just to get confirmation whether its screen issue as customer dont want to pay for screen replacement.
    Anyone knows?
    PSisplay fine on external monitor.
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      Anyone knows?
      This is only a replacement of the LCD. Even replacing the T-con with cables did not change the situation.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Thanks friend for confirming it's a bad screen. Will return it back to customer.
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ledbylight
          M1 A2337 Macbook - No Display, likely due to logic board
          by ledbylight
          Hi all!
          This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
          I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
          11-04-2024, 06:36 PM
        • veedo
          Macbook A2442 820-02098 boot and display issue
          by veedo
          Hi All
          I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
          Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
          I found component UD290 ( SF0101-I2C) little...
          04-01-2024, 06:06 AM
        • saisoni20
          MacBook Air A2337 820-02016-07 No sound ISSUE
          by saisoni20
          I have A2337 MacBook Air no sound issue.
          I have replaced new Audio Board but still same issue. I went through repair wiki and checked critical voltages.
          In terms of voltages, I have following voltages,
          1 PP1V25_AWAKE_IO - 1.2V
          2 PP1V25_AWAKE_IO - 1.8V
          3 SPKRAMP_A_OUTP_R - 0V
          ​4 SPKRAMP_A_OUTN_R - 0V
          Am I missing any other critical voltages?
          07-28-2024, 05:53 PM
        • drlarsen
          MacBook Air M1 A2337 battery/charging issue
          by drlarsen
          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
          After some hours, the battery status did not improve. Restore via DFU did not help.
          I connected the power adapter to a Kill-a-Watt...
          07-17-2025, 02:35 PM
