dell la-9413p only work on battary
  • doctormasry
    • Dec 2019
    • 98
    • giza
    hello
    i have laptop dell la-9413p
    laptop ve short on i capacty
    i changed it and there is no short
    but laptop now work on battary only . no charging
    and no work on adapter
    i changed pu700 ( BQ24717) no new
    changed pu800 no new
    pq4 = 19v in and out 19
    measure on photo
    thanks
  • mon2
    • Dec 2019
    • 14108
    What does the BIOS report when you attach the power adapter (and battery)?
    Measure the voltage to ground of PL4 - used by the PSID signal from the power adapter. This 1-wire communiction line must be working to identify the power rating of the adapter.
    On the charger IC (PU700), measure the voltage to ground of:
    (remove the battery but connect the power adapter)
    ACOK ; pin 5
    ACDET ; pin 6
    VCC ; pin 20
    REGN ; pin 16
    • doctormasry
      • Dec 2019
      • 98
      • giza
      THNKS MON2 FOR REPLAY
      LAPTOP WORK GOOD WITH BATTRY ONLY AND GET DISPLAY
      BUT WHEN I USE ADAPTOR NO CHARGING BATT AND WHEN REMOVE BATT NOT WORKING BY ADAPTOR
      I CHANGED PU700 BUT I LL MEASURE AND REPAORT
        SMDFlea commented
        Editing a comment
        Do you have a problem with your caps lock, you`re posting in UPPER CASE all of a sudden..
    • mon2
      • Dec 2019
      • 14108
      No problem. Yes, please carefully measure the requested voltages. The VCC pin is a critical one and is based on the dual diode. This part will power through power adapter OR battery - whichever voltage is higher. Sometimes, this part becomes defective and raises similar issues.
      Reply when you are well rested. Now, you should be sleeping
      • piernov
        • Jan 2016
        • 4435
        • France
        https://www.badcaps.net/forum/troubl...arging-circuit
        Will be the same issue as usual…
        • doctormasry
          • Dec 2019
          • 98
          • giza
          thanks for all
          mon2
          ACOK ; pin 5 = 6 v
          ACDET ; pin 6 = 2.5 v
          VCC ; pin 20 = 18 v
          REGN ; pin 16 =12 v
          piernov
          i put measure here ​
          • mon2
            • Dec 2019
            • 14108
            REGN ; pin 16 =12 v
            Can you double check this measurement? It should be ~6 volts.​
            • doctormasry
              • Dec 2019
              • 98
              • giza
              yes it's 5.5 v sorry
              • mon2
                • Dec 2019
                • 14108
                Ok.
                From post #2 - when you connect the battery AND the power adapter, the laptop boots so check the BIOS to confirm the power rating of the attached power adapter. If the power adapter rating is not correct, then the issue is with the PSID communication line which is the 1-wire interface to extract the details of the external power adapter. This line must work else the power adapter will not be detected and/or not be detected correctly and then battery charging will stop AND the CPU will be throttled (slow down).
                Share the voltage to ground of:
                Charger IC PU700
                ACP ; pin 2
                ACN ; pin 1
                SRN ; pin 12
                SRP ; pin 13
                source (1-2-3)
                gate (4)
                drain (5-6-7-8)
                on PQ700 DCin mosfet.
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Ferimonka
                  Dell Latitude 7420, 7320 voltage changed
                  by Ferimonka
                  Hi there,
                  I got 2 Dell laptops with a locked bios (dell management protection).
                  When I sent the dumps to this forum I got unlocked .bin files.
                  The issue I am getting the voltage on the bios chip pins has changed once I soldered the chip back (with the unlocked even original bios file) and doesn't turn on anymore.
                  Before I started to re-program the chip the voltage on the pins were 3.3V almost on each pin. Once I soldered the chip, voltage changed to 1.9V or 1.3V on few pins. No 3.3V anymore.
                  I appreciate any help to get me this...
                  07-18-2022, 02:11 AM
                • diamon
                  Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                  by diamon
                  I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                  Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                  Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                  Pictures of these boards:
                  Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                  Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                  Dell...
                  02-28-2024, 12:51 PM
                • OntarioTL
                  Dell 5410 greyed out BT
                  by OntarioTL
                  Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                  If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                  Dell Lattitude 5410
                  Service Tag...
                  07-25-2025, 01:28 PM
                • lalle-
                  Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                  by lalle-
                  Hello!
                  I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                  [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                  I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                  The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                  I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                  08-11-2024, 02:01 PM
