dell la-9413p only work on battary
  • doctormasry
    • 108
    • giza
    hello
    i have laptop dell la-9413p
    laptop ve short on i capacty
    i changed it and there is no short
    but laptop now work on battary only . no charging
    and no work on adapter
    i changed pu700 ( BQ24717) no new
    changed pu800 no new
    pq4 = 19v in and out 19
    measure on photo
    thanks
  • mon2
    • 14657
    What does the BIOS report when you attach the power adapter (and battery)?
    Measure the voltage to ground of PL4 - used by the PSID signal from the power adapter. This 1-wire communiction line must be working to identify the power rating of the adapter.
    On the charger IC (PU700), measure the voltage to ground of:
    (remove the battery but connect the power adapter)
    ACOK ; pin 5
    ACDET ; pin 6
    VCC ; pin 20
    REGN ; pin 16
    • doctormasry
      • 108
      • giza
      THNKS MON2 FOR REPLAY
      LAPTOP WORK GOOD WITH BATTRY ONLY AND GET DISPLAY
      BUT WHEN I USE ADAPTOR NO CHARGING BATT AND WHEN REMOVE BATT NOT WORKING BY ADAPTOR
      I CHANGED PU700 BUT I LL MEASURE AND REPAORT
        SMDFlea commented
        Editing a comment
        Do you have a problem with your caps lock, you`re posting in UPPER CASE all of a sudden..
    • mon2
      • 14657
      No problem. Yes, please carefully measure the requested voltages. The VCC pin is a critical one and is based on the dual diode. This part will power through power adapter OR battery - whichever voltage is higher. Sometimes, this part becomes defective and raises similar issues.
      Reply when you are well rested. Now, you should be sleeping
      • piernov
        • Jan 2016
        • 4439
        • France
        https://www.badcaps.net/forum/troubl...arging-circuit
        Will be the same issue as usual…
        • doctormasry
          • 108
          • giza
          thanks for all
          mon2
          ACOK ; pin 5 = 6 v
          ACDET ; pin 6 = 2.5 v
          VCC ; pin 20 = 18 v
          REGN ; pin 16 =12 v
          piernov
          i put measure here ​
          • mon2
            • 14657
            REGN ; pin 16 =12 v
            Can you double check this measurement? It should be ~6 volts.​
            • doctormasry
              • 108
              • giza
              yes it's 5.5 v sorry
              • mon2
                • 14657
                Ok.
                From post #2 - when you connect the battery AND the power adapter, the laptop boots so check the BIOS to confirm the power rating of the attached power adapter. If the power adapter rating is not correct, then the issue is with the PSID communication line which is the 1-wire interface to extract the details of the external power adapter. This line must work else the power adapter will not be detected and/or not be detected correctly and then battery charging will stop AND the CPU will be throttled (slow down).
                Share the voltage to ground of:
                Charger IC PU700
                ACP ; pin 2
                ACN ; pin 1
                SRN ; pin 12
                SRP ; pin 13
                source (1-2-3)
                gate (4)
                drain (5-6-7-8)
                on PQ700 DCin mosfet.
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                  Dell Thunderbolt Firmware
                  by SMDFlea
                  Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                  Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                  The SKU is in brackets (****)
                  EDIT: NVM65...
                  01-26-2025, 06:22 AM
                • Ferimonka
                  Dell Latitude 7420, 7320 voltage changed
                  by Ferimonka
                  Hi there,
                  I got 2 Dell laptops with a locked bios (dell management protection).
                  When I sent the dumps to this forum I got unlocked .bin files.
                  The issue I am getting the voltage on the bios chip pins has changed once I soldered the chip back (with the unlocked even original bios file) and doesn't turn on anymore.
                  Before I started to re-program the chip the voltage on the pins were 3.3V almost on each pin. Once I soldered the chip, voltage changed to 1.9V or 1.3V on few pins. No 3.3V anymore.
                  I appreciate any help to get me this...
                  07-18-2022, 02:11 AM
                • capoplays
                  Help with BIOS update on Dell G15 5515 after chip replacement
                  by capoplays
                  Hey everyone,
                  I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                  The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                  When I check the BIOS using the F12 menu Flash...
                  Yesterday, 06:53 AM
