i have problem with my lenovo ideapad 3
  • Elrayyaan
    • Dec 2024
    • Nigeria
    Hi good day please i have problem with my lenovo ideapad 3, when plugged in without battery the laptop doest come up, and when plugged in with battery the orange light stays steady and the battery will be discharging. Any help thanks
  • mon2
    • 14657
    Would you have test tools like a multimeter? Start with a known good power adapter. If the power adapter is not working, you will see this fault.
    Orange light means the battery is weak and is not charging.
    If necessary, you can measure the power path from the external power adapter to the charger IC to determine if there is a fault there. If the power adapter is OK, then other tests needs to be made.
    • Elrayyaan
      • Dec 2024
      • Nigeria
      Thanks, I will try and test the power adapter using multimeter, though before now my brother got the same lenovo so when mine didn't come up I used his own to charge my battery the battery is now 100% charged to ruled out issues of battery and charger.
      • Elrayyaan
        • Dec 2024
        • Nigeria
        Also I used his own power adapter the same thing infact u used my own adapter on his laptop to charge my battery
        • NConstantinou
          LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
          by NConstantinou
          Dear all,
          i have the above laptop which had a problem with battery. i replaced it with a compatible one..
          the laptop DOES NOT POWER ON..
          with it old battery it does power on.
          i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
          when i shutdown the laptop does not power on.
          does anyone have any solution!
          when is not power on the usb c voltage tester shows 5v 1.3A
          when i disconnect battery and power on and then connect battery the tester...
          12-10-2024, 04:52 AM
        • GabrielS24
          Lenovo E540 battery problem
          by GabrielS24
          Hello! I'm here to look for solutions to reset the EEPROM memory of a Lenovo E540 battery of 62Wh and 540mAh. I even bought a new one on the market (aftermarket BTIBM30) because I couldn't find an original one but it doesn't work. The laptop sees the percentage but blocks the battery charging probably because of the Chinese BMS. In the bios I don't have an option for the battery and I didn't find an older version (v1.57). I replaced the Lenovo BMS with Chinese cells but in windows it doesn't read the battery percentage and says it needs to be changed. I have 12v between D and the red wire....
          04-16-2025, 05:23 AM
        • jared101
          Lenovo Ideapad 320-15IKA NM-B452 not charging battery
          by jared101
          NM-B452
          Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
          On the BQ24780SRUYR charging ic
          VCC 20V
          SMBUS lines
          SDA 3.3V
          SCL 3.3V
          Current Sensing lines
          ACP/ACN 2.3 ohms
          SRP/SRN 21.2 ohms
          REGEN line 6V
          PHASE .84V with no battery installed(this may be normal)
          08-03-2022, 09:19 PM
        • code share
          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
          by code share
          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
          Here's what I've tried so far:
          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
          • Booted successfully on AC power only with the battery disconnected
          • Visual inspection of the battery — no swelling, burn marks, or connector damage
          • Battery
          04-21-2025, 12:50 PM
        • ZixuTech
          Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
          by ZixuTech
          Hi Guys, a weird case here.
          This laptop came with damaged hinges, but no liquid signs.
          It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
          I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
          I have replaced bq24780S battery charging chip, no difference.
          With a connected new battery,...
          04-03-2022, 04:03 AM
