Macbook a1706, dead keyboard.
  • saronno
    • Jan 2012
    • 57
    Anyone has experience troubleshooting keyboard on this model?
    From schematics it seems an i2c keyboard, the problem is I can't find a good test point con scl and sda, in order to see if voltage is present (usually i2c works with the 2 rail pulled up with a resistor to a voltage source ... components attached to the two rail communicate pulling the line down.
  • mon2
    • 14662
    Review the cabling. Is the trackpad working? Fan spin is normal or high?
    • saronno
      • Jan 2012
      • 57
      trackpad is working fine. So, my guess is pull up voltage to be present since they seems to be on the same i2c chain. Am I right?
      Cabling seems good, at least before removing the logic board .... maybe tomorrow I will remove the board and check on the other side.
      • saronno
        • Jan 2012
        • 57
        it's trackpad/keyboard replaceable right away? I mean, can emerge anyproblem with ID of trackpad/keyboard? Are they combine by ID? TY
        • mon2
          • 14662
          Yes. A1706 does not have such ID locks. Each part is replaceable. You should test with another known good keyboard/trackpad and cabling. View YT videos on this topic.
          • saronno
            • Jan 2012
            • 57
            Thanks.
            • playit
              ps/2 port keyboard dead ? p5ql pro / ethernet cable light
              by playit
              my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
              my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
              few years back ps2 mouse stopped working, but ps2...
              12-23-2024, 06:05 AM
            • B2L_Repairs
              Macbook A1706 touchpad and keyboard not working. Please help
              by B2L_Repairs
              Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
              10-09-2023, 04:56 AM
            • Rav_tangle
              MacBook Pro 2011 turns on with keyboard light , screen dead
              by Rav_tangle
              Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
              I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
              Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
              is this...
              05-31-2024, 04:09 PM
            • johnbeton
              Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
              by johnbeton
              I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
              Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
              This is what I measure so far:
              Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
              PPBUS_G3H = 0,79v
              PPBUS_HS_CPU = 0,79v
              PPBUS_HS_OTH5V = 0,79v
              PPBUS_HS_OTH3V3...
              05-21-2024, 02:06 PM
            • Arshad alam4659
              macbook a1706 in dead condition
              by Arshad alam4659
              today i received a macbook a1706 in dead condition When I removed the battery the laptop started up i connect the battery again and press power button but laptop not turn on
              I did smc reset and the laptop started . I have to reset the SMC every time to turn it on. It does not turn on without resetting the SMC. Sometimes it starts without resetting the SMC.
              someone guide me what is the problem bad smc or anything
              12-19-2024, 02:41 AM
