[help] 820-01958 dead: 20v not switching
  • phantomEVO
    • Mar 2013
    • 505
    LDO_CORE 1,49
    PP0V8_SLPS2R 0v
    PP3V_G3H 0v
    PP1V2_AWAKE 0v
    PMU_LDO3_OUT 1,79v
    PP1V1_SLPS2R 0v
    PP3V3_G3H 2.4v
    PP1V8_SLPS2R 0v
    LDO_RTC 1.50
    • phantomEVO
      • Mar 2013
      • 505
      i don't know if it is a good part...i can try to buy a brand new u7650..
      • phantomEVO
        • Mar 2013
        • 505
        i've check each pin...there no shorts....i'm going crazy....
        • phantomEVO
          • Mar 2013
          • 505
          PP3V3_G3H_RTC and PP3V3_G3H RTC_R are 3,3v
          PP3V3_G3H is 2,6v
          • mon2
            • 14588
            This voltage is defined by the feedback resistors on pin P3V3G3H_VFB2 of U7650. Assuming this power rail is not shorted, remove all power, measure each resistor between this pin # 16 and the output of the same power rail. Each resistor must be 1% accurate to properly output this voltage.
            So test the resistance (without power) of:
            R7655
            R7691
            R7697
            R7698
            R7699
            • phantomEVO
              • Mar 2013
              • 505
              ALL OK EXCEPT R7698
              R7699
              BOTH MEASURE 35K...
              but i have a "semi-donor board" (820-1521) and they have the same value
              • phantomEVO
                • Mar 2013
                • 505
                edit
                • phantomEVO
                  • Mar 2013
                  • 505
                  can we start from the beginning? following some power sequence flow chart????
                  • phantomEVO
                    • Mar 2013
                    • 505
                    i've ppbus_g3h @12,31
                    now ? which voltage must i have?​
                    • mon2
                      • 14588
                      https://logi.wiki/index.php/PPBus_G3H
                      • phantomEVO
                        • Mar 2013
                        • 505
                        ??! ppbus is ok...
                        • mon2
                          • 14588
                          https://boards.rossmanngroup.com/thr...k-at-5v.62436/
                          • phantomEVO
                            • Mar 2013
                            • 505
                            mon2...i really don't understand....the board you linked me is totally different from mine
                            and i have pp3v3_g3h_rtc
                            • mon2
                              • 14588
                              You are not working with the 820-01958 board?
                              The takeaway from the shared link is:
                              We have the main power rail PPBUS_G3H - 12.28v (should be 12.60v). But it should be 12.60v.
                              • phantomEVO
                                • Mar 2013
                                • 505
                                i don't undersdtand......is mine ppbus wrong?!??!
                                according to this
                                https://repair.wiki/w/MacBook_Air_A2...w_at_5V_repair
                                you are right!!!
                                A good spot to measure from on the 820-01958 is C6482.
                                • ā‰ˆ12.60–12.65 V = Normal, ā‰ˆ12.28–12.35 V = T2 communication issue with the ISL9240. The likely cause for this is the device is stuck in DFU mode due to corrupt T2 firmware. Proceed to repair steps below for corrupt T2 firmware.
                                YOU ARE A LEGEND!! so i have to fix ppbus_g3h!!!! how??? diode value is ok
                                • phantomEVO
                                  • Mar 2013
                                  • 505
                                  it is not recognized in dfu....
                                  • phantomEVO
                                    • Mar 2013
                                    • 505
                                    • i've already changed isl9240 some post before...with no luck and R7021, R7022, R7061, R7062 are ok
                                    • mon2
                                      • 14588
                                      A lot has happened in this long thread..so check again:
                                      voltage to ground on
                                      SMBUS_3V3_BATT_SCL
                                      SMBUS_3V3_BATT_SDA
                                      What is the voltage and current draw on the USB-C meter at this time? Is it stable?
                                      • phantomEVO
                                        • Mar 2013
                                        • 505
                                        Yes you are right!
                                        at the moment
                                        i have ppbus_g3h @ 12,31v
                                        pp3v_g3h @ 2,6v
                                        no shorts around usb c controller
                                        no dfu mode (i have no 1V8_SLPS2R)
                                        Ok both ports i have 5v @ 0,046 stable
                                        • phantomEVO
                                          • Mar 2013
                                          • 505
                                          (without battery)
                                          SMBUS_3V3_BATT_SCL
                                          SMBUS_3V3_BATT_SDA
                                          both 2,6 V unstable: it goes from 2,5 to 2,6 in a slow loop
                                          https://www.dropbox.com/scl/fi/53ax3...=37a2qdh0&dl=0
                                          if can be usefull, voltage of pmu
                                          PP1V1_SLPS2R 0v
                                          PP1V8_SLPS2R 0b
                                          LDO_CORE 1,49v
                                          PP0V8_SLPS2R 0v
                                          PP1V2_AWAKE 0v
                                          PMU_LDO3_OUT 1,79v​
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
