[help] 820-01958 dead: 20v not switching
  • phantomEVO
    • Mar 2013
    • 505
    i'm going crazy, now both ports are dead!!
    my power meter doesn't power on at all on both!​
    • phantomEVO
      • Mar 2013
      • 505
      i have anything on PPDCIN_G3H/PP20V_USBC_T_VBUS, both ports...how is it posisble??
      • phantomEVO
        • Mar 2013
        • 505
        what can i do?^
        • mon2
          • 14590
          There must be a short or bridge somewhere. Test each exposed pin on the cd321x parts in diode mode.
          If OL, the point is not soldered. If low value, point is shorted. Thermal camera reveal any issues?
          • phantomEVO
            • Mar 2013
            • 505
            i've check the usb connector...ALL PINS...AND NO SHORTS.
            now i will try what you said
            • phantomEVO
              • Mar 2013
              • 505
              i don't find anything....where should i find 5v from usb?
              • mon2
                • 14590
                5 volt is the power on default from your external PD adapter. This same voltage should appear on each mated ACE controller on the VBUS pin. Suggest to confirm the USB connector themselves are not without damage -> confirm the mating connectors on the logic board. Test the mating connectors on the logic board in diode mode.
                Essentially what this tool is doing - testing each pin in DIODE mode:
                https://www.youtube.com/watch?v=VtPuu-tDSto
                • phantomEVO
                  • Mar 2013
                  • 505
                  already tested...seems all ok...i'm going crazy...
                  • mon2
                    • 14590
                    Seems all ok = 'means that each diode mode measurement matches the screen from the YT video'?
                    What is the voltage of VBUS from your adapter on the logic board? It should not be zero unless there is a short on the board.
                    • phantomEVO
                      • Mar 2013
                      • 505
                      yes all values are good...
                      PP20V_USBC_T_VBUS is 0v on both ports...
                      i've done a small experiment, soldering a wire on PP20V_USBC_T_VBUS line and injecting 1v...i can read without problem 1v on the connector...so the line from the motherboard connector to the opposite site of the connector is ok,..
                      but when i insert the cable, there is no voltage at all, power meter doesn't power on, neither by-3200s that show 0v @ 0a
                      • phantomEVO
                        • Mar 2013
                        • 505
                        nothing on PP20V_USBC_X_VBUS/PP20V_USBC_T_VBUS
                        cc1/cc2 of both ports are 0,570mv in diode mode...
                        i've no voltge at all neither on cc1/cc2​
                        • phantomEVO
                          • Mar 2013
                          • 505
                          i really don't understando how is it possible
                          • mon2
                            • 14590
                            What is the resistance to ground of:
                            PP20V_USBC_T_VBUS
                            PP20V_USBC_X_VBUS
                            • phantomEVO
                              • Mar 2013
                              • 505
                              if i connect the usb of u3100 directly here
                              [URL unfurl="true"]https://www.joom.com/en/products/63fed274263dda01a452a45f[/URL]
                              i have 5v on both usb ic fuses
                              if i connect the usb of u3200 i have no voltage on both fuses: HOW THE HELL IS IT POSSIBLE?
                              • phantomEVO
                                • Mar 2013
                                • 505
                                Ok, new port installed! now i have 5v, and now?
                                PPBUS_G3H 12,28
                                PP3V3_G3h loop from 2,52 to 2,66
                                i have on usb meter 5v@0,046 on both port​
                                • phantomEVO
                                  • Mar 2013
                                  • 505
                                  here you can see a sospicious (for me) behaviour of the 2 cd3217...
                                  https://www.dropbox.com/scl/fi/jhcvd...=qib4m213&dl=0
                                  • phantomEVO
                                    • Mar 2013
                                    • 505
                                    i've removed both cd31217 but i have not shorts under them
                                    • mon2
                                      • 14590
                                      Connect the power adapter without the CD3217s installed. Do you have 5 volts?
                                      • phantomEVO
                                        • Mar 2013
                                        • 505
                                        no i haven't. on both fuses...i have on vbus lines
                                        the problem of not having them with cd3217 was bad usb port
                                        • mon2
                                          • 14590
                                          Good discovery. The USB-C paddle boards are inexpensive and simple to replace. In the USA / Canada, there is Mobile Sentrix and Aliexpress otherwise or donor boards.
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
