[help] 820-01958 dead: 20v not switching
  • phantomEVO
    • Mar 2013
    • 505
    I've check also about u7800 ldo..
    LDO_CORE 1,49
    PP0V8_SLPS2R 0v
    PP3V_G3H 0v
    PP1V2_AWAKE 0v
    PMU_LDO3_OUT 1,79v
    PP1V1_SLPS2R 0v
    PP3V3_G3H 2.4v
    PP1V8_SLPS2R 0v
    LDO_RTC 1.67​
    • phantomEVO
      • Mar 2013
      • 505
      i think that the power supply for pm is PP3V3_G3H_PMU_VDDMAIN
      how can i pretend to have ldos if PP3V3_G3H_PMU_VDDMAIN is 2,4v????
      so i think that before pp3v3 i should have PPBUS_G3H
      but PPBUS_G3H is 12,28v!!
      and like i read here
      https://repair.wiki/w/MacBook_Air_A2...w_at_5V_repair
      PPBUS_G3H is created by the Intersil/Renesas ISL9240 (U7000)
      If you are getting 5 V on PPDCIN_G3H, the ISL9240 is likely the cause of the problem
      i have already check the current sensors....
      so i think i should change u7000 what do you think?|
      • mon2
        • 14588
        No. You are confusing ppbus_g3h with PP3V3_G3h.
        Post #5 has a valid voltage for the initial value of ppbus_g3h.
        (Back to my beauty sleep)
        • phantomEVO
          • Mar 2013
          • 505
          mon, ppbus_g3h is 12,28 ! i should have 12,6!
          ps goodnight
          • mon2
            • 14588
            Test the voltage to ground of the smbus scl and sda lines used by the ISL9240.
            Test the same on the battery connector.
            • phantomEVO
              • Mar 2013
              • 505
              on r5240 0v
              on r5241 0v
              0,v
              SMBUS_3V3_BATT_SCL
              SMBUS_3V3_BATT_SDA
              measured on d6950
              • mon2
                • 14588
                Remove all power. Measure the resistance to ground of:
                SMBUS_3V3_BATT_SCL
                SMBUS_3V3_BATT_SDA
                • phantomEVO
                  • Mar 2013
                  • 505
                  30k both
                  pardon: on
                  SMBUS_3V3_BATT_SCL
                  SMBUS_3V3_BATT_SDA
                  I HAVE 2,4V (for me strange, because i soon as i connect usb power, i find only 0,98 that increase slow until 2,4)
                  • phantomEVO
                    • Mar 2013
                    • 505
                    is it possible that all problems are generated from PP3V3_G3H LOW ???!??!?! (2,6V INSTEAD OF 3,3?)
                    • mon2
                      • 14588
                      What is the voltage to ground of PP3V3_TBT_X_S0?
                      • phantomEVO
                        • Mar 2013
                        • 505
                        0v
                        • mon2
                          • 14588
                          What is the voltage to ground of PP3V3_TBT_X_SX?
                          Test with external power adapter on each USB C port.
                          • phantomEVO
                            • Mar 2013
                            • 505
                            i've discovered something (i think ) interesting
                            if i connect the usb port corresponding to u3200, i have this
                            https://www.dropbox.com/scl/fi/jpbth...=cffslxna&dl=0
                            you see? half of u3100 become hotter and a quarter of u 3200 flash...
                            this trange thing doesn't happen if i connect the cable to u3100
                            PP3V3_TBT_X_SX 0v
                            • mon2
                              • 14588
                              I don't see the issue in the posted video. Confirm if you have the power rail (post #32) using one of the USB-C ports. This is important as the CD321x create this LDO rail.
                              • phantomEVO
                                • Mar 2013
                                • 505
                                try to rewatch the video...at minute 0.05 you can see what i say...
                                PP3V3_TBT_X_SX​ not presente like i said before
                                • mon2
                                  • 14588
                                  1) Are you testing the above power rail with each USB-C port?
                                  2) With no power to the board - What is the resistance to ground of PP3V3_TBT_X_SX? Also test in diode mode. Red meter probe to ground. Black meter lead to PP3V3_TBT_X_SX​. What is the measurement?
                                  3) This case goes back to the CD3215 20V article. Need to be sure each LDO rail is functional.
                                  https://logi.wiki/index.php/CD3215_Bootup_Sequence
                                  * follow this power sequence and post details of what is failing
                                  • phantomEVO
                                    • Mar 2013
                                    • 505
                                    1,47k
                                    0,440
                                    i have no shorts around those chips
                                    • mon2
                                      • 14588
                                      Similar logic flow in debugging.
                                      Search for 'LDO_3V3' and this should land onto the CD3217 balls that create this rail. Be sure to test each USB-C connector to test each ACE controller.
                                      • phantomEVO
                                        • Mar 2013
                                        • 505
                                        on u3200
                                        PP3V3_G3H_RTC 3,3v
                                        PP3V3_UPC_X_LDO 3,3v
                                        PP1V5_UPC_X_LDO_CORE 1,5v
                                        on u3100 all are 0v
                                        • phantomEVO
                                          • Mar 2013
                                          • 505
                                          same diode mode values on all lines...
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
