Advice on reflowing boards (I know there's hundreds of these!)
  • artois7
    • Mar 2011
    • 159
    I appreciate there are plenty of threads like this, but stick with it.
    I've been doing a lot of thinking over the last couple of days with regards to reflowing, reballing etc. I have around 120 faulty laptops in stock here, and probably 70-80 of them could benefit from a reflow/reball.
    Reballing is way beyond my capabilities at the moment, so I'm mostly thinking about how to get into accurate reflowing.
    My problem with reflowing has always been reliability; can a reflow be done in a way that I can confidently sell a laptop to a customer and called it refurbished? I've had success with a PS3 in the oven which lasted 18 months before selling it on, but with the laptops I'm more thinking about purchasing a hot air station with an appropriate nozzle (A post from The Unique suggests a 41mm x 41mm nozzle?), temperature probes and a lot of flux.
    Do any of you reflow boards and are happy with the repair as a result? Happy enough to move the boards on as working?
    If there's enough positive feedback that reflowing is a serious method of repair, then I'll be looking into investing in a hot air & soldering all in one station hopefully, and I'll then need to find a way to make a pre heater / bottom heater.
  • cephei328
    sparky
    • Feb 2014
    • 49
    • NewZealand
    Re: Advice on reflowing boards (I know there's hundreds of these!)
    Hi artois7, Well you cannot sell laptops with confidence with re-flowed BGA chips for sure: It can fail anytime. Re-balled BGA chips can last little longer than re-flowed ones but still it can fail too. The best way is to replace with new Chip with recommended heat profile. But if you want to experiment a bit and want to train yourself in re-balling (its little time consuming and need hands on skills: which you may get through practice) and learn more about it.
    Cheers
      • 31265
      oven?
      and you cant do BGA with a handheld unit - you need a pre-heater under the board.
      • dj_ricoh
        • 2073
        • uk
        The infamous "OVEN"
        You better believe it that you need a BGA Station.
        Even if the oven got a bad reputation you can still manage to do basic work so you can get work and money for a BGA.
        If you think that you can only use small tool and air stations and ovens , bla bla bla NO!
        You actually need a BGA Station if you go with this type of work.
        Think of it like this. After work you surf FleeBAy and you want to make some side money.
        there is a auction for a notebook with video problems and the only person who bid on it its the guys who own a BGA station or have access to it because they need to change that chip. TAM TAM. they win the aucion with 70 GBP and they sell it after with 200 with "seller refurbished" Name.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          or u can build your own ;-)
          top heater - ebay 30$
          bottom heater - halogen light 200w - 8$
          2x pid controllers with thermocouple ebay - 27$
          a little work and u have it
          • artois7
            • Mar 2011
            • 159
            What would you suggest for a top heater?
            • dj_ricoh
              • 2073
              • uk
              i think he is referring to air station.
              • trebo
                • 514
                • Wales, UK
                more like a heat gun at 30$ maybe???
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5084
                  • New Zealand
                  That would certainly have enough power... but you need to be able to accurately control it, otherwise you'll toast everything.
                  -David VanHorn
                  • trebo
                    • 514
                    • Wales, UK
                    I was only assuming, that was what ktmmotocross in his post was using, as I don't think you can get a hot air station on ebay for 30$.
                    I have a heat gun and a hot air station, but have never attempted even a reflow yet, I acquire many laptops with graphics problems but have to break them up for parts etc
                    will have to bite the bullet one day
                    • dj_ricoh
                      • 2073
                      • uk
                      the secret it's in the wrist
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3628
                        • slovakia
                        a dont recomend hot air for reballing
                        top heater i mean is ashi/scotle ir stations top heater
                        on ebay can buy top and bootom heaters from this stations, cheap and good quality
                        ricoh> buy 2-3 bad boards and test
                        the magic is in slow heating and good flux.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3628
                          • slovakia
                          i cannot find that low price now but it looks like this
                          http://www.ebay.com/itm/Top-Bottom-H...item2a2a76191e
                          • Ady2017
                            SMD fuse soldering advice please
                            by Ady2017
                            Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
                            Yesterday, 12:03 PM
                          • chazzo
                            CH341 programmer advice, including jumpers seemingly reversed
                            by chazzo
                            I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
                            [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
                            I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
                            10-12-2025, 08:15 AM
                          • Jidis
                            Need T-Con Advice (Vizio P602ui-B3)
                            by Jidis
                            I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                            He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                            09-22-2025, 05:10 PM
                          • zlr8r
                            Advice on newer EC chip programming eg. MEC5107-LJ BGA
                            by zlr8r
                            Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                            i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                            09-16-2025, 09:54 AM
                          • Borse2008
                            by Borse2008
                            • There’s
                            07-15-2025, 04:55 AM
