Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
  • mon2
    • Dec 2019
    • 14256
    So U6000 is the ovp device that may have triggered.
    What is the voltage to ground of the removed resistor, pin #2? Measure the voltage at the pcb pad.
    • zaurus81
      • Feb 2021
      • 67
      • Italy
      #42
      pin #2 of the resistor has 0.009 V
      • mon2
        • Dec 2019
        • 14256
        Flux and carefully remove capacitor C60018. Test again without this part onboard.
        • zaurus81
          • Feb 2021
          • 67
          • Italy
          #44
          do I put everything back (sense resistor, transistor, resistor) except the capacitor C60018?
          • mon2
            • Dec 2019
            • 14256
            For now - leave the others off as well since the voltage on ACN continues to be present. Suspecting the leak is from this capacitor that bridges across pins #1 & #2.
            • zaurus81
              • Feb 2021
              • 67
              • Italy
              #46
              with c60018 removed i always have this fu***ng 4.3 volt on main
              • mon2
                • Dec 2019
                • 14256
                Unbelievable. With the current sense resistor (and this removed cap) off the board, what is the resistance between pin #1 and #2 on the charger IC?
                • zaurus81
                  • Feb 2021
                  • 67
                  • Italy
                  #48
                  I thought about something. Tell me if it makes sense. The main power line that has 4.3 volts is called PVBAT. If I analyze the boardview I see that it is connected to a series of other lines via pads (PAD6110, PAD6160, PAD6110 and so on). These pads can be separated because they are made of tin. If I separate all the pads I can see if I remove these 4.3v. If they disappear, I reunite all the pads one at a time testing from time to time until I find the responsible sector. What do you think?
                  • zaurus81
                    • Feb 2021
                    • 67
                    • Italy
                    #49
                    10.87M ohm
                    • mon2
                      • Dec 2019
                      • 14256
                      Test the resistance between these referenced points (PVBAT) to ACN. Do they appear as a short?
                      • zaurus81
                        • Feb 2021
                        • 67
                        • Italy
                        #51
                        No, they have all the same resistance, 13M ohm
                        • mon2
                          • Dec 2019
                          • 14256
                          Suggest to remove the charger IC off the board to confirm if there is an external leak or is it that this charger IC is linked to this mystery voltage. If the current sense resistor is removed, you should have 0v on ACN.
                          • zaurus81
                            • Feb 2021
                            • 67
                            • Italy
                            #53
                            With Charger IC and sense resistor removed from the board, i always have 4.3 volt on ACN
                            • mon2
                              • Dec 2019
                              • 14256
                              Test if this voltage is present on each inductor on the board. Also test if you see this voltage on any of the mosfets linked to the battery charger. A p-channel mosfet will enable under these conditions.
                              • zaurus81
                                • Feb 2021
                                • 67
                                • Italy
                                #55
                                the voltage is absent on each inductor except the one that charges the battery. I write the voltages in a photo. I don't see any p-channel mosfets, they are all n-channel. See boardview
                                these 2.4 volts, with time (a few minutes), drop to 0.8v
                                all these values are strange since the n-channel gates are at 0V (board without sense resistor and bq24800)
                                • mon2
                                  • Dec 2019
                                  • 14256
                                  Flux and remove the 2 mosfets that are showing the 4v2 measurement. Test again. Does the 4v2 on ACN halt?
                                  PS: This board needs an exorcism.
                                  • zaurus81
                                    • Feb 2021
                                    • 67
                                    • Italy
                                    #57
                                    maybe an "avada kedavra"🤣
                                    same story.....4.3 present
                                    is it normal to have prochot# at 0v on bq? something releted to absence of original charger??
                                    • mon2
                                      • Dec 2019
                                      • 14256
                                      Can you confirm the wiring of your power supply to this board is of the correct polarity?
                                      • zaurus81
                                        • Feb 2021
                                        • 67
                                        • Italy
                                        #59
                                        i don't understand the question. see photo
                                        • rogfanther
                                          • Jul 2006
                                          • 458
                                          • Brazil
                                          #60
                                          Just a veeery long shot, but isn´t this one of those boards that have a tiny switch inside the power jack, that is activated when the psu cable is inserted ? Can you try with a psu, even disconnected from mains, and see if the voltages change ?
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • Ghostalker
                                            Zephyrus G14 GA401QM dead
                                            by Ghostalker
                                            Hello I have an ASUS Zephyrus Laptop (Model GA401QM), bought on ebay and the previous owner claims he was using and the laptop stopped, He then tried to change battery and broke the connector on the battery and also on ripped a GND pad on the MB.
                                            I was searching on internet and found two posts on this forum about a similar problem “ASUS ROG G14 (GA401) battery spark, dead.” and “Dead ASUS ROG G14 (GA401)” both by the user jacobtc.
                                            I already made some measurements based on the “Dead ASUS ROG G14 (GA401)” post using GA401QM schematic provided here and Boardview provided...
                                            09-06-2023, 03:20 PM
                                          • Mcfeetroy
                                            Fishing bite alarm drains battery
                                            by Mcfeetroy
                                            Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                            08-01-2025, 03:52 AM
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
                                            MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                                            by sam_sam_sam
                                            I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                                            I open it up to find non brands name capacitors in it
                                            I am not sure how this switching power supply is set up
                                            Could someone please explain how this power supply works
                                            Here is the capacitor ESR results
                                            (1) 47uf@50 volts 0.46
                                            (2) 47uf@50 volts 0.45
                                            New 47uf@50 volts 0.35
                                            (1) 100uf@25 volts 0.34
                                            (2) 100uf@25 volts 0.35
                                            New 120uf@50 volts 0.08
                                            (1) 220@25 volts 0.13...
                                            10-21-2018, 10:02 AM
