Lenovo 17IIl05 NM-D031 Shorted 1.8 rail
  • Sofian75
    • Aug 2023
    • 85
    • France
    Resistance at all the coils seem fine except for the 1.8V coil (PL9800) which reads 0 ohm.
    The 3.3V coil has also a very low resistance of 11 ohm, after trying to disconnect some components and isolate the problem it appears that the problem comes from +3VALW_PCH (unsoldered the PJ4602 bridge).
    I have little hope but I am a beginner so I would like your advice before considering the motherboard dead.
    Link to schematic - https://www.badcaps.net/forum/troubl...31-motherboard
  • mon2
    • 14108
    To clarify, remove all power. Meter in resistance mode. Measure the resistance to ground for each coil. Do not measure the resistance across the coil itself which is nothing more than a long piece of wire so it will report a low resistance.
    Can you confirm this is how you are measuring the resistance for a short?
    • Sofian75
      • Aug 2023
      • 85
      • France
      Yes this is how I measure them.
      • mon2
        • 14108
        This is a dead short. Flux and lift up one leg of PL9800. Then test again. Which side of this leg of the voltage rail is shorted? Is it the inductor side (producer) or the downstream (consumer) side?
        PS: You may be able to test the same by removing the solder blob @ PJ9803 (if present). Essentially we are attempting to isolate the producer and consumer sides of this shorted power rail.
        • Sofian75
          • Aug 2023
          • 85
          • France
          The downstream side I guess (the side on the right, toward the ddr slot)
          • mon2
            • 14108
            Would you have an adjustable power supply? If yes, dial it up to 1 volt (to be safe) and inject onto the side showing this short. Then monitor who heats up from this injection. Hoping it is a local capacitor onboard.
            • Sofian75
              • Aug 2023
              • 85
              • France
              Only thing heating up is the PCH, not even hot but still...
              It's over?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Dont waste your tome bro on this unit. A short to ground on 1.8V coupled with 3.3V rail is absolute guarantee of shorted SOC.
                • Sofian75
                  • Aug 2023
                  • 85
                  • France
                  I thought so, to the graveyard it goes.
                  Thanks.
