Surface Pro 7+ battery dead
  • SuperAman
    • Dec 2018
    • 119
    Hey guys, I had a surface 7+ pro come in for a cracked screen that held a charge. After replacing the screen the battery refuses to charge. I tried to use a dc supply to wake the battery up but it takes no current at all. Tablet is working fine on charger / usb c. The only thing I can think is the heat from the hot plate did something to the battery during the screen removal.
  • mon2
    • 14161
    Rule out the battery by sourcing another from Mobile Sentrix or Amazon.
    • SuperAman
      • Dec 2018
      • 119
      Yeah, it was the battery, interestingly Sentrix was out of the battery. My guess is I had used a new hot plate to remove the screen and it killed the battery, had it on 80° C.
      • mon2
        • 14161
        Good stuff. Thanks for the update.
        On the removal, try dipping your plastic cards / plastic tools into a bit of alcohol while carving out the lcd. It helps a great deal to dissolve the glue. We do this for the imacs with the glued screen and their wheel tool. Expedites the process.
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
        • mferna14
          MacBook Air A2681 battery problem after Screen Replacement
          by mferna14
          Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
          12-06-2024, 08:10 PM
        • mkdj
          by mkdj
          Mark and model: ASUS X571
          Tests already made:
          - I have removed...
          07-14-2025, 09:16 AM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • huzo
          HP ELITE X2 1013 G3 weird battery issue
          by huzo
          Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
          01-31-2025, 12:09 AM
