MacBook Air M2 A2681 no Trackpad
  • rynr
    • Jun 2024
    • 4
    I have been following the posts in the forum for some time now and have learned a lot. I would first like to thank you for this and hope that it will continue for a long time.
    I received the MacBook in DFU. The recovery always failed with error 1. After some search, I was able to find a defective inductor (LT202).
    After replacing the component, I was able to successfully complete the DFU restore. Unfortunately, the trackpad and keyboard where still without function.
    So i measured all voltages and diodereadings on the JT400 connector.
    JT400
    41 GND d 0 42 GND d 0
    1 I2C_SMC_IPD_SCL_CONN v 3.2 2 SPI_IPD_MOSI_CONN v 3.2
    3 I2C_SMC_IPD_SDA_CONN v 3.2 4 SPI_IPD_MCU_CS_CONN_L v 3.2
    5 I2C_KBD_SCL v 3.2 6 SPI_IPD_MISO_CONN d 0.432
    7 GND d 0 8 IPD_SYS_AWAKE_CONN v 0.086 → 3.2
    9 I2C_KBD_SDA v 3.2 10 GND d 0
    11 KBD_INT_L v 3.2 12 SPI_IPD_CLK_CONN d 0.438
    13 IPD_TOUCH_CLK_CONN d 0 14 IPD_MCU_RESET_CONN_L v 3.2
    15 SPI_IPD_TOUCH_CS_CONN_L v 3.2 16 IPD_TOUCH_RESET_CONN_L v 3.2
    17 GND d 0 18 SWD_IPD_DATA_CONN OL
    19 IPD_TOUCH_INT_CONN_L v 3.2 20 SWD_IPD_CLK_CONN OL
    21 IPD_LID_OPEN_1V8 v 1.7 22 IPD_MTP_FUNC_1_CONN d 0.513; v 3.2
    23 TPAD_KBD_WAKE_CONN_L v 3.2 24 GND d 0
    25 IPD_MCU_INT_CONN_L v 3.2 26 PP3V3_S2SW_IPD_F v 3.2
    27 GND d 0 28 PP3V3_S2SW_IPD_F v 3.2
    29 PP5V_S2_IPD_F v 5.1 30 PP3V3_S2SW_IPD_F v 3.2
    31 PPBUS_AONSW_IPD_F v 12 32 PPBUS_AONSW_IPD_F v 12
    33 PPBUS_AONSW_IPD_F v 12 34 PPBUS_AONSW_IPD_F v 12
    35 PPBUS_AONSW_IPD_F v 12 36 PPBUS_AONSW_IPD_F v 12
    37 PPBUS_AONSW_IPD_F v 12 38 PPBUS_AONSW_IPD_F v 12
    39 PPBUS_AONSW_IPD_F v 12 40 PPBUS_AONSW_IPD_F v 12
    43 ACT_GND d 0 44 ACT_GND d 0
    Pin 8 only had a voltage of 0.086 V. After replacing UT360, the voltage is now 3.2 V.
    Now when the old trackpad is connected, the keyboard works. However, the trackpad has no function.
    Neither can the mouse pointer be moved nor can the pad be clicked. If I connect a replacement trackpad, the keyboard also has no function.
    I have also tested two different connection cables. Both with the same result.
    Does anyone have any idea what I could check next?
  • mon2
    • Dec 2019
    • 14630
    Review the cables linked to each component. Any sharp bends in the cable? May mean that conductor is defective.
    https://boards.rossmanngroup.com/thr...sue-lid.64702/
    • rynr
      • Jun 2024
      • 4
      Hi mon2,
      thanks for the reply.
      You mean connector, right?
      • mon2
        • Dec 2019
        • 14630
        Cables as well. Often they are the first defect. Be sure also of the # of contacts on the cables being deployed. Does the pin-pin pitch of each contact match the mating connectors? Have done this here and installed a similar width TP cable but the total # of contacts were different than the OEM. Wasted time on that one. Best to count the # of contacts under a good microscope. Be sure the orientation (bottom side / top side - check which is proper for your model - YT is good for this) of the cable is correct and well inserted inside the blade connectors.
        • rynr
          • Jun 2024
          • 4
          Hi mon2,
          thank you for the reply. Yesterday a donor board arrived and I could test. The trackpad is working fine with this board.
          In system preferences and in settings tab the trackpad and keyboard are shown..
          But on the other board it is not listed.
          Also, I found that SPI_IPD_MOSI_R, SPI_IPD_CLK_R & SPI_IPD_MISO on the working board have low voltages. But on the defective one I'm measuring 0.
          For me it seems as the SPI communication isn't enabled. Or could this part of the CPU be defective?​
          • mon2
            • Dec 2019
            • 14630
            Review the details of the level shifter used by the trackpad interface @ UT360. This part may be defective if you are measuring 0v on each SPI pin.
            • vins3433
              • Jun 2020
              • 3
              • France
              I'm experiencing the same issue as described in this thread with a MacBook Air M2 (A2681) – the trackpad is completely non-functional, while the keyboard works fine.
              I have already performed several checks:
              • Replaced UT360 (SPI Level Shifter) – no change.
              • Checked trackpad power lines – all voltages seem correct.
              • SPI lines analysis (MOSI is active, but MISO and CLK remain at 0V).
              • SMC reset performed – no effect.
              • Checked continuity of SPI lines between UT360 and the trackpad connector – all connections seem fine.
              • Tried another trackpad – same result.
              I was wondering if you managed to find a solution to your issue, or if anyone on the forum has additional troubleshooting ideas.
              Thanks in advance for your help!
              • mon2
                • Dec 2019
                • 14630
                Confirm the VCCA and VCCB power rails on the SPI level shifter.
                Confirm the resistance to ground of MISO and CLK of the SPI lines. You may also do the same in diode mode (red meter probe to ground; black meter probe to point to test; no power to the board).
                • vins3433
                  • Jun 2020
                  • 3
                  • France
                  Thanks for your reply! I've taken all the measurements you asked for (Voltage, Resistance, and Diode Mode) on the UT360-related lines. To make it easier, I've attached three screenshots with all the values clearly marked. Repair History & Issue Background:
                  This MacBook Air M2 originally came in for a screen replacement at another repair shop.
                  • The screen was broken, and they attempted to replace it.
                  • However, after the screen replacement, both the keyboard and trackpad stopped working.
                  • The customer canceled the repair, asked them to put the original broken screen back, and took the laptop.
                  • When I received the device, it still had a broken screen, and neither the keyboard nor the trackpad were working.
                  What I've Done So Far:
                  1. Found a short circuit on UT360 → I replaced UT360, but the keyboard and trackpad were still not working.
                  2. Found another short circuit on UT320 → I replaced UT320, and the keyboard started working again, but the trackpad still does not work.
                  3. Bought a brand new trackpad with a new trackpad flex cable → Same issue.
                  4. Swapped the cables between the old and new trackpad → Same result.
                  At this point, the keyboard is fully functional, but the trackpad remains unresponsive.
                  I've attached the requested measurements. Let me know if you have any further suggestions or tests I should perform.
                  Thanks again for your help!
                  • mon2
                    • Dec 2019
                    • 14630
                    How are you observing the details? Using an external monitor over HDMI?
                    Post clear pics of the replaced level shifter parts region for a review. The cables are firmly seated inside the FFC/FPC connectors? Deep enough that they are mating with the contacts?
                    In the inventory screens, is it the MT-version that is missing from your reworked board = trackpad? Personally have not reviewed this screen in the past.
                    • vins3433
                      • Jun 2020
                      • 3
                      • France
                      Screen replacement – I'm using a brand-new screen now, so I can see everything clearly. The original broken screen was still working (except for the bottom part), but I tested with it again, and same issue. So, the screen isn't the problem.
                      MT version missing – I checked System Information, and the trackpad isn't detected. I've attached a screenshot.
                      Photos of UT360 & UT320 – Here are the pics of the replaced components, let me know if anything looks off.
                      Cables – Double-checked, they're fully seated and properly inserted.
                      UT320 replacements – I've actually replaced UT320 three times already:
                      • First, I ordered the same part from AliExpress and replaced it.
                      • Since that didn't work, I took the equivalent component from a 2018 MacBook Air board and swapped it in.
                      • Later, I replaced it again with a new one from AliExpress, just to be sure.
                      • The keyboard started working again after replacing UT320, but the trackpad is still dead.
                      Next step: replacing UT350 – I read on other forums that a short on UT360 can also damage UT320 and UT350. My measurements on UT350 show that it's working fine, but I'll probably replace it anyway, just in case. I don't expect this to fix the issue, but I'll do it as a precaution.
                      Let me know if you have any other ideas. Thanks!
                      • rivskiano1
                        • Aug 2024
                        https://www.bilibili.com/video/BV1VV...4f287d2cb5c94f
                        Hello, maybe that's would be helpfull
                        • Lloydz
                          • Apr 2015
                          • 24
                          • Portugal
                          Hi, just would like to thank you for the information, just had a A2681 with the same anomaly. UT350 was sending 3.25V, but was causing anomalies with the trackpad, after replacement trackpad has worked OK.
                          BTW PP3V3_S2SW_IPD should have about 7kohm. thats how I found the culprit.
                          • tommy97
                            MacBook A2681 - Problem with trackpad
                            by tommy97
                            I do have problem with MacBook A2681 every time i close the lid, when re-open trackpad does not work, i need to close it again and the re-open and it's come back to normal, i've tried software reset, inspected the board, replaced screen angle sensor (from Apple), nothing changed, any ideas?
                            04-06-2024, 04:16 AM
                          • mitchw
                            MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
                            by mitchw
                            Hello
                            I got this MacBook Pro M4 Pro to have a look at.
                            It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
                            Since it was liquid damaged, warranty does not apply anymore.
                            Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
                            The main issue was that the screen remained black.
                            Anyways I cleaned the liquid damaged area, put the machine back...
                            09-06-2025, 07:19 AM
                          • No Lan
                            [Macbook pro A1708] [Boot loop] [Trackpad ?]
                            by No Lan
                            Hey everyone,
                            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                            05-24-2025, 03:09 PM
                          • Skrndelj
                            Apple Macbook Air M1 A2337 Trackpad problem
                            by Skrndelj
                            Hello all,
                            I am repairing a Macbook A2337 and i have a problem
                            The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                            When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                            I inspected the whole board and everything seems fine.
                            Can anyone help me as i didn't fiddle with trackpad...
                            06-11-2024, 04:26 AM
                          • kuba2102
                            Macbook Air M2 A2681 Keyboard and trackpad not working with certain LCD
                            by kuba2102
                            Hello. As in description, TP and KB are not working when connected to the OEM display (working one). The angle sensor was damaged by a water, other than that I cannot find any more liquid damage or even stains. I took the bezel off the LCD to inspect but it looks intact. when I connect a spare LCD it works like a charm. I never seen before a laptop where KB and TP would work due to a display that is displaying without any issue. Any idea?
                            05-14-2025, 04:47 PM
