MacBook A2681 - Problem with trackpad
  • tommy97
    • Mar 2023
    • 167
    I do have problem with MacBook A2681 every time i close the lid, when re-open trackpad does not work, i need to close it again and the re-open and it's come back to normal, i've tried software reset, inspected the board, replaced screen angle sensor (from Apple), nothing changed, any ideas?
  • Skrndelj
    Apple Macbook Air M1 A2337 Trackpad problem
    by Skrndelj
    Hello all,
    I am repairing a Macbook A2337 and i have a problem
    The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
    When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
    I inspected the whole board and everything seems fine.
    Can anyone help me as i didn't fiddle with trackpad...
    06-11-2024, 04:26 AM
  • rynr
    MacBook Air M2 A2681 no Trackpad
    by rynr
    I have been following the posts in the forum for some time now and have learned a lot. I would first like to thank you for this and hope that it will continue for a long time.
    I received the MacBook in DFU. The recovery always failed with error 1. After some search, I was able to find a defective inductor (LT202).
    After replacing the component, I was able to successfully complete the DFU restore. Unfortunately, the trackpad and keyboard where still without function.
    So i measured all voltages and diodereadings on the JT400 connector. ...
    11-04-2024, 09:56 AM
  • mferna14
    MacBook Air A2681 battery problem after Screen Replacement
    by mferna14
    Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
    12-06-2024, 08:10 PM
  • daltonjr.
    MacBook Air A2681 with no image and no trackpad
    by daltonjr.
    Hi,,
    I have replaced the screen on this machine, then suddenly there was no more image and the trackpad click stopped working. I can still hear the chim at start up. I have tried another motherboard in this machine and it works normally.
    I think the screen and the trackpad are not e​ve​n on the same power line.
    Any idea?
    10-28-2025, 07:05 AM
  • mitchw
    MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
    by mitchw
    Hello
    I got this MacBook Pro M4 Pro to have a look at.
    It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
    Since it was liquid damaged, warranty does not apply anymore.
    Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
    The main issue was that the screen remained black.
    Anyways I cleaned the liquid damaged area, put the machine back...
    09-06-2025, 07:19 AM
