Mobo in coma
  • g0rak
    • May 2014
    • 10
    • Czech Republic
    Mobo in coma
    I would like to ask all of you, experienced eli doctors, for little advice with my faint mobo. Ima just regular home user with DMM and courage.
    so in galaxy far aw.......
    Ive cleaned and re-pasted my notebook. Was stupid enough to use 10+ years old silver-based paste and possibly spilled something on gfx/cpu parts on their dye. Ive cleaned it as hard as I could.
    (acer aspire 5552G) s1s4 socket, phenom cpu, on Rs880m north bridge , dedicated gfx hd5650.
    mobo shema
    Now mobo switches on for like 3s , diodes shining, fan goin , then it dies. If its cold first-time start it takes like 5 seconds.
    It does not get into POST unfortunately (got POST card), therefore bad power is my suspision.
    *So Ive tested every rail, for bad voltage levels, found nothing.
    *All PowerGood signals are there.
    *Ive tryed to push hard BGA chips towards mobo for cold contact, no change.
    *None of the caps under cpu/gfx seems shorted.
    *Ive found litle trick in manual, when you press some combo on keyboard while pluging power, it enters different BIOS execute branch , where BIOS reads flash drive and re-flashes itself from file. While this "mode" is executed (without flash drive offcourse, dont wanna mess BIOS) , motherboard does not shutoff itself after 3secs , and stays ON untill I pull the plug. Even in this "mode" I didnt found faulty power rail or anything, however NorhtBridge gets hot quite fast , waayyy faster then gfx or cpu (Ive mounted cooling for this).
    *Ive soldered out "power jumper" off NB_CORE power rail (heard that Rs880m is shiz), to see if anything changes, dies in 3secs again.
    Im courious about some signals, there is logic AND that reads SB_PWRGD (is 1) and strange "LDT_RST" (reads 0V, but inverted output from SB). Dont understand the whole "LDT" / "HDT" abreviation, anyone know?
    Unfortunately dont have any logic analyzer or scope , so there I am =S.
    Hopefully with little trick , that plugs small diode and capacitor together I would be capable of spoting quick positive signals off rails that could escape DMM. Dunno how would that helped me, but thats it , exhausted and looking for heads up =)
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Mobo in coma
    AMD processors use HyperTransport technology for processor-memory communication. Under HT technology, the communication device (bus) is effectively within the CPU itself; this is known as the HT bus. There are two types of buses in this system, known as LDT (Lightning Data Transport) bus and HT bus; LDT connects with the motherboard chipset, and HT bus communicates with the system memory.
    • spleenharvester
      • Mar 2010
      • 908
      Re: Mobo in coma
      This sounds sort of like a CPU problem. Do you know if you got any compound on the little components on the top-side of the CPU? Also try booting it without the CPU, does the same thing happen?
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • g0rak
        • May 2014
        • 10
        • Czech Republic
        Re: Mobo in coma
        Thx for answers.
        Yea both my gfx and cpu got some paste "under" those tiny fagot parts on them. Does not matter in case of CPU, because mobo should start to POST without it right ?
        Spilled GPU might seem bad, but Ive actualy tested those tiny parts , and they seem fine , I mean they usualy form some groups with same resistance (like 75 / 30)... and none off them are shorted. Actualy Ive tryed to measure resistance of that silver compound and found that Im unable to measure anything, even with 2Mohm range , and like half milimeter distance for probes.
        • g0rak
          • May 2014
          • 10
          • Czech Republic
          Re: Mobo in coma
          Out of curiosity, can bad northbridge cause mobo not-POST ?
          I mean If it (NB) would be unsoldered from mobo , would the "working" mobo POST ? Or it depends... (on bios etc..)?
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Re: Mobo in coma
            No. If the CPU is not working it will not POST. The BIOS contains code, it is program in memory, not a processor, the CPU has to be there to execute the code.
            • g0rak
              • May 2014
              • 10
              • Czech Republic
              Re: Mobo in coma
              That is the word on the table ! Thank you sir ! I did not realized that
              For another thing , how usualy mobos act when turned on without CPU ? Is possible that Im simply hunting ghost, with "just" dead cpu ?
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                Re: Mobo in coma
                You're welcome. I don't think it would do anything at all without the processor. I suppose it could depend on the MB though. I haven't fired up a MB without the CPU that I recall.
                • lefos
                  • Nov 2013
                  • 321
                  • Greece
                  Re: Mobo in coma
                  If you power it on without cpu usually the power on leds light for nearly 5 secs and then shuts down immediately.
                  • g0rak
                    • May 2014
                    • 10
                    • Czech Republic
                    Re: Mobo in coma
                    Hmm that is some heavy weight info too =). Didnt find that anywhere and its actualy quite crucial behavior imho. Thank you sir !
                    That kinda vouches for my conclusion ... dead cpu, since the silver paste spilling incident
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • Cerberuska
                      Mobo MSI B550-A PRO password popup
                      by Cerberuska
                      Hello guys,
                      I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                      BIOS I updated to last one.
                      any suggestions?
                      And same thing for two different 5600G, and yes, MoBo supposed to support it.
                      Thank you...
                      11-10-2024, 01:23 PM
                    • Ibod
                      Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                      by Ibod
                      HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                      With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                      Not sure where to go from here ?
                      Is the PSU at fault or is the mobo causing the problem
                      Look forward to any help :-)
                      If I plug the 24...
                      02-08-2023, 11:00 AM
                    • Felipe_Serra_83
                      Dell Inspiron 14-5448 - fan turns off and mobo keeps running
                      by Felipe_Serra_83
                      Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
                      So I got this Dell Inspiron to play with.
                      No charger, so I connected to my bench PSU.
                      The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
                      ------What it did (and didn't do)------
                      1) I turned it on and it powered on. Powered down in 2 seconds by itself.
                      2) Removed RAM, changed slot. Same...
                      04-04-2024, 12:39 PM
                    • tartuf
                      FSP-350GLN(80) not booting mobo properly
                      by tartuf
                      Greetings
                      My old 350W FSP-350GLN(80) PSU was working fine with my current computer for few years(and previously with few other computers as well). Nothing has changed in setup but since last few months I am getting problems while trying to boot PC.
                      What happens, is that PSU starts and I can hear fans, both PSU, CPU, MOBO and GPU. I can also hear HDD scratching and normal starting sounds. But DVI monitor claims that there is "no signal". Moreover, neither USB mouse nor PS2 keyboard does flash leds like it should do upon boot.
                      I have to turn PSU switch...
                      12-23-2022, 10:54 AM
