How to check short in power rail
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3575
    • slovakia
    Hello i need to know how to check short in power rails. I have some short in power rails and i check resistance but on processor, VGA or chipset i get resistence under 1ohm.
    anybody know how to chceck that short?
  • loser18
    • Nov 2013
    • 274
    Re: How to check short in power rail
    Take out the CPU...check again...should have some resistance now...GPU & GMCH have sometimes low resistance eg. 10-15ohms...
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3575
      • slovakia
      yes i know that i take out processor i have some resistance but in GPU or chipset i get resistance less then ohm about 0.2ohm.
      • loser18
        • Nov 2013
        • 274
        What's the mobo model number...
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3575
          • slovakia
          its HP dv6700 with nvidia GPU, it shuts right after power switch. its so fast that i cannot check power on power rails and resistance dont show enything
          • loser18
            • Nov 2013
            • 274
            Here's schematic if it's AT3...
            Which coils are shorted?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3575
              • slovakia
              not mine board. i have Nvidia MCP chipset and Turion processor.
              PL3 - 0.2ohm
              PL11 - 0.2ohm
              PQ25 - output - 0.3ohm
              here is diagram
              https://cdn.badcaps-static.com/pdfs/...f1d82042d0.pdf
              • loser18
                • Nov 2013
                • 274
                If you don't have lab PSU it's a pain in the arse to look for shorted components...
                Desolder PL3 & PL11 and check which pin/side is shorted...
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3575
                  • slovakia
                  How can PSU help me to detect vhere i have short?
                  • loser18
                    • Nov 2013
                    • 274
                    You will inject voltage to shorted rail & look for components which are heating up...
                    Need a proper lab PSU with voltage & current regulator...
                    • khaahk
                      • Dec 2013
                      • 751
                      • Estonia
                      What do you mean by PL3 - 0.2 ohm ?
                      Are you measuring resistance across PL3 or measuring from PL3 relative to GND?
                      PL3 - 0.2ohm
                      PL11 - 0.2ohm
                      here is diagram
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3575
                        • slovakia
                        To ground of course.
                        • khaahk
                          • Dec 2013
                          • 751
                          • Estonia
                          Sorry, just checking...
                          Then lab PSU is the easiest way.
                          Way too many shorts for one mainboard (or do they all end in nvidia mcp67)?
                          • loser18
                            • Nov 2013
                            • 274
                            Had shorted 19V rail...
                            Found 2 shorted FETs today (without PSU)...
                            Didn't take more than 15min...
                            Also had to use boardview file as no markings on board itself...
                            Was like schematic-boardview-mobo-desolder lol
                            Possible, if you following schematics...(but still pain in the arse)
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3575
                              • slovakia
                              i think its that mcp, because it have 1,2 and 3v and all this power rails is shorted. removed pl3 and pl11 and short is on chips side. gpu uses only 1.2v so i think MCP is shorted.
                              • loser18
                                • Nov 2013
                                • 274
                                Need to reball...or try reflow if You don't have bga machine...
                                Also did you check PC43, 44, 45, 113, 19, 111, 13, 109 and PU1?
                                They're most likely ok, but you never know...
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3575
                                  • slovakia
                                  damn have a bad luck. Unsolder MCP > nochange still short 1.2v and 3v
                                  so i desoldered GPU and all shorts is gone.
                                  I dont have a knowledge that GPU uses 3V rail
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3575
                                    • slovakia
                                    I forget the vga rams, it uses 3v
                                    • Nagy Daniel
                                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                                      by Nagy Daniel
                                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                      So, I generated a table with AI so I can...
                                      03-04-2025, 08:24 AM
                                    • Geeker007
                                      9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                      by Geeker007
                                      Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                      I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                      So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                      01-28-2025, 03:31 PM
                                    • playit
                                      450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                      by playit
                                      hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                      09-02-2023, 02:43 AM
                                    • femin
                                      Lenovo LOQ 15IRH8D2 RAM power rail short
                                      by femin
                                      Could you help me to find the Voltage rail IC PU301 model
                                      Multimeter continuity model shows short after the PU301 IC and to the whole ram slot is short to ground
                                      07-10-2025, 03:34 AM
