A2159 will not boot past Apple Logo
This topic has been answered.
  • Logix_UK
    • Jan 2021
    • 22
    • United Kingdom
    Hi Everyone. I have a Mac for a topcase replacement. I have completed the job however the Mac will boot and I get the startup chimes but not pass the Apple Logo, not even a progress bar. After a few seconds the fan spins fast. The board is 820-01598-A. I have disconnected everything except the USB ports and display and the issue persists. I am drawing 20.42v and .461A with just the screen connected so it looks like it is booting. I have looked over the board with a scope and I do not see anything that appears wrong. I can not get into diagnostics, NVRAM reset or DFU. The only issue is the topcase is used, but excellent condition however the Trackpad cable was damaged on the connector and stupidly I did not notice until I tried to connect it. I had not power or battery attached atthe time of course and the connector on the Logicboard is perfect. if anyone has any ideas that would be good and I appreciate your help.
  • Answer selected by Logix_UK at 10-17-2024, 06:16 AM.
    Logix_UK
    • Jan 2021
    • 22
    • United Kingdom
    Originally posted by reformatt
    Touchbar would be my first suspect.
    Hi, thank you however the issue happens even if the touchbar is not connected.
    • reformatt
      • Feb 2020
      • 1529
      • Logix_UK
        • Jan 2021
        • 22
        • United Kingdom
        • mon2
          • Dec 2019
          • 14698
          Review the trackpad and trackpad cabling. Be sure the trackpad cable contact pitch is suitable for this model’s connector. There are sensors in the trackpad assembly that must be visible during the OS boot using smbus communication. If absent, there will be a high fan spin.
          Measure the voltage to ground of each smbus pin on the trackpad cable.
          Respectively, the trackpad must be connected and working to boot.
          • Logix_UK
            • Jan 2021
            • 22
            • United Kingdom
            OK thank you, I have replaced the trackpad cable and reassembled and it now boots, thank you all for your support. Great forum, great techs
            • Axis937
              • Jun 2024
              • 12
              • Singapore
              Out of curisoity, what is the relation between the trackpad cable and stuck Apple logo. Whats happening behind the scene?
              • mon2
                • Dec 2019
                • 14698
                This reminds me of a very involved case with XMOS (UK) Semiconductor (multicore processors - mainly for audio when we were considering it for new designs). Long winded story but is as follows. The multicore processor would emulate the USB handshakes using 'bit banged code' to offer a USB audio device. Respectively, USB is a very time sensitive interface. If too much time is invested in one core vs. another, the USB interface will suffer and die. The other cores were handling the audio processing. A large audio OEM company invested almost 9 months I was told on attempting to fix this failed new audio design - attempting numerous new PCB layouts, etc. Then they sent in the latest design to us for a review. After a review of the firmware, the root cause was...drumroll...a missing I2C / SMBUS slave device. The code loop was repeatedly attempting to ping a SMBUS slave node that was absent on THEIR design but was on the reference board design from the factory. While stuck in this phantom device hunt loop, the USB interface would suffer and would die over time.
                Same case here with the trackpad. The sensors are low cost I2C / SMBUS nodes that must be found or enumerated by the logic board else the logic board assumes the worst and believes that the CPU temp is out of range so blast the fan into hyper speed and throttle the CPU speed.
                  SMDFlea commented
                  Editing a comment
                  Its a good explanation of the fault, nice.
              • Logix_UK
                • Jan 2021
                • 22
                • United Kingdom
                The job was a topcase replacement. I sourced a used by good condition topcase but as I was re assembling I noticed the track pad cable was damaged, see attached. I put the Mac back together minus the trackpad and it would not boot. I did not realise that the trackpad needed to be connected until mon2 told me. As soon as I replaced the trackpad cable it booted.
                • Logix_UK
                  • Jan 2021
                  • 22
                  • United Kingdom
                  mon2 Thank you for your help and the explanation.
                  • Axis937
                    • Jun 2024
                    • 12
                    • Singapore
                    WOW!!! i bet no one would have thought about this.
                    • Teban1306
                      [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                      by Teban1306
                      Hello everyone!
                      I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                      System Information:
                      • Model: Lenovo ThinkPad T14 Gen 1
                      • Machine Type: 20S1S4E600 (Intel i7 variant)
                      • Current BIOS: N2XET42W (1.33) - Latest version
                      • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                      What I'm trying to achieve:
                      Replace the default "LENOVO" boot logo with a custom image during POST.
                      🔧 What I've tried:
                      09-14-2025, 11:49 AM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • irepair559
                      Is my bios ok? HP Envy x360 won't boot past hp logo tried everything
                      by irepair559
                      hello guys , ok i tried everyhting and all that was left was to check bios, ch341 says bios is good? not sure here is the dump.. TIA!...
                      01-08-2024, 07:03 PM
                    • JaquesPratt
                      Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                      by JaquesPratt
                      I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                      This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                      07-16-2024, 01:04 AM
                    • taslan
                      Surface 7 Pro wont boot, shows Logo and immediately turns off
                      by taslan
                      as stated in the title, my surface 7 pro wont boot anymore.
                      When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                      I dont even have a chance to get into bios or boot from usb.
                      While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                      I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                      Bought it directly from microsoft and used it now and then and only...
                      01-16-2025, 01:25 AM
