Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
A2159 will not boot past Apple Logo
This topic has been answered.
The job was a topcase replacement. I sourced a used by good condition topcase but as I was re assembling I noticed the track pad cable was damaged, see attached. I put the Mac back together minus the trackpad and it would not boot. I did not realise that the trackpad needed to be connected until mon2 told me. As soon as I replaced the trackpad cable it booted.Leave a comment:
This reminds me of a very involved case with XMOS (UK) Semiconductor (multicore processors - mainly for audio when we were considering it for new designs). Long winded story but is as follows. The multicore processor would emulate the USB handshakes using 'bit banged code' to offer a USB audio device. Respectively, USB is a very time sensitive interface. If too much time is invested in one core vs. another, the USB interface will suffer and die. The other cores were handling the audio processing. A large audio OEM company invested almost 9 months I was told on attempting to fix this failed new audio design - attempting numerous new PCB layouts, etc. Then they sent in the latest design to us for a review. After a review of the firmware, the root cause was...drumroll...a missing I2C / SMBUS slave device. The code loop was repeatedly attempting to ping a SMBUS slave node that was absent on THEIR design but was on the reference board design from the factory. While stuck in this phantom device hunt loop, the USB interface would suffer and would die over time.
Same case here with the trackpad. The sensors are low cost I2C / SMBUS nodes that must be found or enumerated by the logic board else the logic board assumes the worst and believes that the CPU temp is out of range so blast the fan into hyper speed and throttle the CPU speed.Leave a comment:
Out of curisoity, what is the relation between the trackpad cable and stuck Apple logo. Whats happening behind the scene?Leave a comment:
OK thank you, I have replaced the trackpad cable and reassembled and it now boots, thank you all for your support. Great forum, great techsReview the trackpad and trackpad cabling. Be sure the trackpad cable contact pitch is suitable for this model’s connector. There are sensors in the trackpad assembly that must be visible during the OS boot using smbus communication. If absent, there will be a high fan spin.
Measure the voltage to ground of each smbus pin on the trackpad cable.
Respectively, the trackpad must be connected and working to boot.
Respectively, the trackpad must be connected and working to boot.Leave a comment:
Hi Everyone. I have a Mac for a topcase replacement. I have completed the job however the Mac will boot and I get the startup chimes but not pass the Apple Logo, not even a progress bar. After a few seconds the fan spins fast. The board is 820-01598-A. I have disconnected everything except the USB ports and display and the issue persists. I am drawing 20.42v and .461A with just the screen connected so it looks like it is booting. I have looked over the board with a scope and I do not see anything that appears wrong. I can not get into diagnostics, NVRAM reset or DFU. The only issue is the topcase is used, but excellent condition however the Trackpad cable was damaged on the connector and stupidly I did not notice until I tried to connect it. I had not power or battery attached atthe time of course and the connector on the Logicboard is perfect. if anyone has any ideas that would be good and I appreciate your help.Tags: None
by 1centchipsGoes to recovery when plugged in with another Mac, shows in finder with a question mark and serial number. When revived fails at error 9 (the laptop turns off and on?) In the Apple Configurator when in dfu, gives error restores device removed before restore completed 0xFAA (4010). Tried in intel and m1 based Macs.
History, came in with severe liquid damage and bubbly motherboard
Transplanted t2/ recalled ram, u4730, all 4 nands and u4770.
Below is the log from console, the usb meter negotiates at 19v and goes as high as 2.4A
Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]:...04-01-2026, 11:38 AM -
by Teban1306[REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
Hello everyone!
I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
System Information:- Model: Lenovo ThinkPad T14 Gen 1
- Machine Type: 20S1S4E600 (Intel i7 variant)
- Current BIOS: N2XET42W (1.33) - Latest version
- BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
Replace the default "LENOVO" boot logo with a custom image during POST.
🔧 What I've tried:- [
Channel: BIOS Requests ONLY!
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by irepair559hello guys , ok i tried everyhting and all that was left was to check bios, ch341 says bios is good? not sure here is the dump.. TIA!...
by blazie151TLDR; LCD panel with weird display, apparent boot lock right before home screen, total GPU reflow showed no change.
Title pretty much says it all. Sometimes the screen looks fine, other times its yellow lines, completely green, blue with flashing areas, etc. I tried pretty much everything I could think of. I tried a clean install to Ventura off of an OCLP USB I made just for it, and it gets all the way to where you would expect the home screen to appear before it goes full black screen and locks up. I tried putting in a disc or USB or anything I could think of to make noise or show... - Loading...
