MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
  • MagJ_
    • Oct 2024
    • 5
    Hello Everybody,
    I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
    Has someone experience with exchanging these two chips? What do you think about it? Are there any plans available from the board?
    Thanks in advance and best regards,
    MagJ_
  • cheebster
    • May 2008
    • 376
    Hello, i have done this on the M1 2021 macbook pro and it worked fine, should be the same for this one.. You have located the 2 chips?
    • 1centchips
      • Feb 2016
      • 41
      Originally posted by MagJ_
      Hello Everybody,
      MagJ_
      The serialized part is on the board next to the camera. I usually do the lcd only repair. WARNING! It's an extensively involved repair
      • MagJ_
        • Oct 2024
        • 5
        So TrueTone is working? I have to admit, that I have difficulties localizing the chips in the video as well. They seem to be below the LCD. But at position 0:29 of the video, I cannot see the chips anymore. I've found this video on youtube. At position 18:25 or 19:51 you can see the lower part of the LCD. Though, here as well, I cannot really see the position of the chips.
        Overall, I am just sceptical. For me, it seems easier to just exchange both chips, then exchanging the whole LCD and having to fear that dust particles get between diffuser and LCD panel. Though, everyone is exchanging the complete LCD - why?
        Additionally to that, I could not find the guide to do that for the MBA A2337. So I have no idea where these chips lay and whether it is enough the exchange them. Do you have a guide or hints for me?
        • MagJ_
          • Oct 2024
          • 5
          I've heard, that it is difficult. Why don't you exchange the chips?
          I could sell the computer in its current state to a shop for about 300€. But my overall idea was to learn something, fix it, exchange the battery and sell it refurbished for approximately 1100€.
          • 1centchips
            • Feb 2016
            • 41
            A2337 has thicker, wider and stickier glue. It is time consuming to cut the double sided tape. One can easily damage the the backlight sheets or even worse damage the camera flex in the process. I didn't know you still can get 1100 for a2337. Complete lcd shell replacement is easiest and quickest for sure but you lose true tone. If one were to run the built in diagnostic after the full lcd assembly replacement, one will be greeted with issue with display and ALS for sure vs. only issue with display (for lcd only). You will need to separate the lcd on few before actually trying on the one you are trying to resell. Good luck on your journey.
            • piernov
              • Jan 2016
              • 4439
              • France
              You can also check Apple's Self Service Repair program.
              • MagJ_
                • Oct 2024
                • 5
                The shops that sell refurbished products offer it for even 1500€ in my configuration. When I deduct the price because I would not offer any warranty, I guess I can ask for 1100€. That is why I wanted to make my life easier by just swapping both chips. I did have a look at the official apple repair guide. However, they completely change the display and not just the LCD or both chips. If I would do it, I would lose TrueTone. So that is no solution for me.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Apple's Self Service Repair will allow you to run their calibration software at the end of the repair.
                  But without getting the replacement display assembly from the Self Service Repair program I don't think it's possible.
                  • perryalice
                    • Jun 2025
                    When it comes to MacBook Air screen replacement, especially for the M1 A2337 model, one of the biggest concerns is retaining TrueTone functionality after the repair. TrueTone adjusts your display's color temperature based on ambient lighting, and losing it can impact your viewing experience significantly.
                    TrueTone data is stored on a chip within the original display assembly. During a screen replacement, this calibration data needs to be transferred to the new screen in order to keep TrueTone working. Unfortunately, most third-party repair shops don’t have access to Apple’s proprietary calibration tools, which means TrueTone is often lost after non-authorized repairs.
                    If you're replacing the screen yourself or through a third-party technician, it's likely the new display will work perfectly—but without TrueTone. You’ll still get full resolution, brightness, and performance, but TrueTone and auto-brightness may be disabled unless the original screen’s EEPROM data is cloned.
                    Your best option to preserve full functionality—including TrueTone—is to have the repair done by Apple or an Apple Authorized Service Provider. They have the tools to calibrate the new display and pair it with your Mac’s system firmware.
                    In summary, if keeping TrueTone is important to you, it's worth considering an official repair route. If you're okay with losing that feature, third-party replacements can still provide excellent results visually and functionally.
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      🛠 Original Issue
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • obelix24
                      Macbook Air M1 a2337 - 820-02016
                      by obelix24
                      I'm working on Macbook air a2337
                      It's stuck on 5V.
                      I've replaced both CD3217B12 IC's and U8100
                      When i connect USB-C ampmeter i'm getting 5V 0.01 - 0.4a and restart ampmeter and again ....
                      I tried to connect to another mac and i'm not able to get it to DFU.
                      history is that this macbook just died randomly and owner was not able to start it again.
                      PPBUS_AON is 12.3V
                      i'm missing PP5V_S2 - 0V
                      According to repair wiki i've checked https://repair.wiki/w/MacBook_Air_A2...current_draw_c...
                      11-07-2025, 07:13 AM
                    • mkdj
                      MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                      by mkdj
                      About me, my goal and the equipment I (don't) have:
                      I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                      About my issue and my goal:
                      A friend of mine has a MacBook Air M1 A2337 that does not...
                      04-03-2025, 08:28 AM
