Where do you guys buy your 4407?
  • drdyzio
    • Apr 2014
    • 74
    Simple question looking for a good parts distributor in uk for laptop repairs. As ill be doing a lot of these.
    At the moment im looking for 2 x 4407.
    ive checked out ebay, but they are 5 pounds for 2.
    is that right, it seem extraordinarily expensive
    Hope you pros got some good connects
  • loser18
    • Nov 2013
    • 274
    Re: Where do you guys buy your 4407?
    digikey.co.uk
      • 31248
      ouch - £50 minimum order or get screwed for the postage!
      • bammbammfran
        • Apr 2014
        • 476
        IF you are talking about the AO4407
        they are 70cents a piece in the US
          • 31248
          personally i dont care much for chasing down specific fets.
          i just use datasheets to find superior replacements i can get from farnell
          • loser18
            • Nov 2013
            • 274
            Yeah...You need to do bigger order...otherwise 12 quid for shipping but ussually got it within 3days (from States to UK)...that's callled mad shipping management by UPS, lol...also getting SPI's from them...is farnell actually shipping from UK?
              • 31248
              yes, farnell is u.k. warehoused.
              rapid is good too.
              http://www.rapidonline.com/
              not much stuff, but what they have is usually very cheap.
              • dj_ricoh
                • 2073
                • uk
                If you go in to repairing motherboards I'll suggest to buy a job lot from flebay.
                Just once because when you start repairing they will pile up along.
                I saw many base from dell with the motherboard inside.
                I will take a look if I where you.
                Good luck
                • khaahk
                  • Dec 2013
                  • 812
                  • Estonia
                  Most of the FETs i take from scrap mainboards.
                  • drdyzio
                    • Apr 2014
                    • 74
                    COULD I REPLACE THE 4407A(http://www.digikey.co.uk/product-sea...1376381?k=4407)
                    WITH THE 4413 (http://www.digikey.co.uk/product-sea...376381?k=4413a)
                    Just getting the hang of this, will this work as, i do have a macbook board with these in
                    guys its been helpfull, thanks for the replies.
                    • drdyzio
                      • Apr 2014
                      • 74
                      i have hard time reading the datasheets, i know that rds whatever that is and capacitance has to be lower everything else higher.
                      Thanks again. if anyone knows a good post to read regarding reading these datasheets and identifying the right details would be helpfull. thanks
                        • 31248
                        4407 handles twice the wattage - probably better heatsinking.
                        other than that, the 4413 looks better.
                        it has a lower on-resistance, so it should generate less heat.
                        i say give it a try if you have them.
                        • bammbammfran
                          • Apr 2014
                          • 476
                          looks to me like they are both rated at 3.1watts max and the 4413 is rated at 3 amps more and both are 30 volts max
                          so, my question to stj, is what am I missing that has you saying the 4407 will handle twice the wattage ?
                            • 31248
                            http://www.digikey.co.uk/product-det...3TR-ND/1656422
                            left column - maybe it's an error, i'l dl the pdf.
                              • 31248
                              4407 says 3.1w at 25'
                              4413 says 3w at 25' for 10seconds, or 1.5w at 25' continuous.
                              soo - anybody's guess really - the 4407 datasheet makes no mention of it it is continuous or pulsed.
                                • 31248
                                hmm.
                                the 4407 made by diodes inc says 1.45w
                                so the 3w from alpha&omega must be peak.
                                i'd say they are a good match.
                                • drdyzio
                                  • Apr 2014
                                  • 74
                                  hmm.
                                  thanks it helps
                                  • bammbammfran
                                    • Apr 2014
                                    • 476
                                    I was comparing the alpha&omega AO4407 to the alpha&omega AO4413
                                    I did not notice that they were trying to use the Vishay SI4413
                                    that vishay SI4413 looks a bit low
                                    the SI4425 might be better ??
