820-00875 SSD not recognize
  • Gregormc
    • Sep 2024
    • 11
    • Argentina
    Hi, the pc does not recognize my SSD, I was testing Volt and the SMC_OOB1_D2R_L, and gives 0.03v approx, and it should provide 3.3v I think, what can be the problem? maybe is the resistance (R86101) I cant test it with my multimeter too small, but I don't think that would do the V go to 0.3v, and SMC_OOB1_D2R_L has continuity with the test point. I think all other pins are okay.
    Link to schematic/boardview --> https://www.badcaps.net/forum/troubl...c-and-boarview
  • Gregormc
    • Sep 2024
    • 11
    • Argentina
    Also before the SSD problem the pc auto shutdown in random times.
    • Gregormc
      • Sep 2024
      • 11
      • Argentina
      is not the resistance, if not ssd is connected the resistance is100k, if yes is 8k omh
      • reformatt
        • Feb 2020
        • 1400
        Have you tried another SSD? Apple drives for A1708 fail pretty regularly.
        • Gregormc
          • Sep 2024
          • 11
          • Argentina
          No, is a custom size and the disk here cost like a new board, but i don't think is the SSD because SMC_OOB1_D2R_L is 0V, also the PC before the SSD problem, was working but would shut down at random times (connected and not connected)
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            if 1708 does not see the SSD 99% problem with the SSD as reformat says! I have a lot of them lying around! as an option try it on a good board ...
            • Gregormc
              • Sep 2024
              • 11
              • Argentina
              Thanks, is there any method to know if is the SSD or the board with multimeter ? because I don't have a good board or another ssd to try
              • Gregormc
                • Sep 2024
                • 11
                • Argentina
                A technician said that it was the board (maybe not true). what about the MacBook SSD adapter? (because is cheap and I have SSD nvme)
                • mon2
                  • Dec 2019
                  • 13984
                  Confirm that each of the highlighted AC caps are present on the board. Confirm the EMI filter for the PCIe clock is present on the board. Study each to be sure there is no disconnect or defective part in series with any of these lines. It takes only 1 defective part to cause this SSD to fail to be enumerated.
                  • reformatt
                    • Feb 2020
                    • 1400
                    Well, sometimes people just fob you off when it gets into the too hard basket. I don't take much for gospel these days from other repairers, as with MAC's you need to have a bit more between the ears than your average PC board jockey.
                    The adaptors need a 2230/2242 sized SSD. Haven't played too much in this area on A1708 so can't recommend what 3rd party drives work best. That said, I have found that cheap 3rd party SSD's don't work well with MAC's, especially those that don't have DRAM cache. Also a factor is how the SSD's go in and out of sleep that can affect your battery life etc. You can get an aftermarket vendor such as OWC to supply adaptor and drive as a bundle if you want it just to work.
                    • Gregormc
                      • Sep 2024
                      • 11
                      • Argentina
                      L8630 both low resistances seem fine, AC caps also seems fine
                      • Gregormc
                        • Sep 2024
                        • 11
                        • Argentina
                        I am not from the US, looking for cheap alternative to know if is the SSD or board
                        • PITERPENY
                          • Jul 2023
                          • 455
                          • Ukraine
                          I often use these adapters, they work just great, a little faster than even a regular SSD, and they cost pennies in a local shop! Use any well-known SSD, less than a brand, such as Crucial or Samsung or something like that.
                          • Gregormc
                            • Sep 2024
                            • 11
                            • Argentina
                            Ordered 1 by aliexpress $1.7 (ship 50 days)
                            • PITERPENY
                              • Jul 2023
                              • 455
                              • Ukraine
                              It seems to me that on the local sales site their cost is a little more expensive (I think 5-7$), but you will get it in two days.
                              • cind12
                                GTX 1080 TI Gigabyte Aorus low resistance on vmem
                                by cind12
                                Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                                Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                                The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                                Resistance on 12V 4K ohms (Power present when on)
                                Resistance on 12V PEX 4K ohms...
                                12-08-2023, 09:09 AM
                              • Nagy Daniel
                                Lowest possible resistance on laptop motherboard rail - Guide Table request
                                by Nagy Daniel
                                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                So, I generated a table with AI so I can...
                                03-04-2025, 08:24 AM
                              • Jane
                                What is the lowest acceptable resistance on a coil without considering a short on PCB
                                by Jane
                                I have Asus FA506 ( board DA0BKXMB8D0 Rev: D). Can you please roughly indicate what the lowest resistance I should measure on a coil? I know that a low resistance is allowed on coils in CPU or graphic circuits but can you provide acceptable values of resistance?
                                Thank you.
                                02-27-2024, 01:42 PM
                              • loopster
                                645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
                                by loopster
                                Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
                                This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
                                Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
                                My resistance value is 2.2 Ohms, which doesn't look good to me.
                                Thanks to everyone willing to give a value.​
                                06-05-2025, 02:33 PM
                              • abobek zum
                                Legion 5 15ACH6A powered ON but no display
                                by abobek zum
                                I have a question regarding this laptop. Laptop came from my friend, completely dead. No reaction for power button, Adpater etc. Diagnosis: burned HIS mostfet from VRAMs. After replacing the mosfet, Laptop starts to power up, KB lights up for few second and switch off, laptop remain ON but no display. Vents are switching ON after some time. No Caps Lock or reaction on USB stick. No display also through HDMI. All coils resistance seems to be OK except resistance on VRAMs – 15 Ohm ( as I study the other repairs or diagnostic of that laptop it should be around 90 -...
                                03-03-2025, 04:34 PM
