Had this one in a few days ago. Lenovo Y560 with Core i7-740QM and ATi HD5730. No longer installed the display driver and showed artifacts when moved around too much.
First of all, i immediately noticed that the hinges were broken and had a lot of play. The guy who brought it in (friend of the owner not the actual owner) assured me that wasn't a problem, as it's been like that for over 2 years because it's been dropped then. Well, as it turns out, that wasn't a problem in itself, but it was the CAUSE that led to all the problems...
When i started to take the thing apart i was inspired enough to hold the display, otherwise i wouldn't be here talking about this. The hinge supports had cracked from the base and the hinge feet were pretty much wobbling freely inside the bottom case. Turns out the left hinge sits under the edge of the mainboard where four of the VRAM chips are, and not too far from the GPU. If i would not have held the display, without the top cover to support it, the hinge foot would have broken the board in two! What you see in the pictures with the two VRAM chips that look like they've been a little scuffed is the result of the hinge foot pushing into them.
It was now immediately obvious why this board started having video issues - on each display opening, the left hinge would flex the board near the GPU. If you keep flexing and flexing and flexing, the soldering will give way someday, right? That's exactly what happened.
Also due to the very weird board shape i had to get creative when supporting the board... And if you haven't seen it thus far, that's my ghetto BGA station.
Let me not mention that i didn't have the right stencil and had to reball the chip by hand... that took bloody ages. My new pack of stencils is still on its merry way from China. I'm somehow missing a picture of the solder side of the chip - when i got done with it, i guess i was more curious whether it's actually going to work, not in the mood for taking pictures...
But in the end, it all went fine. Before assembling the thing back together, i glued the hinge feet to the bottom case with more 2-part epoxy than required to fix a shovel.
That should keep them in their place.
The laptop passed the highest load i could possibly throw at it (IBT + FurMark) and while temperatures were very high in this scenario, the cooling system was also spitting out very hot air, indicating there is good thermal transfer. With normal workloads it didn't break a sweat. This laptop is not used for games anyway, it is used for creating and showing multimedia presentations so it's gonna be fine.
Let me not mention that i didn't have the right stencil and had to reball the chip by hand... that took bloody ages. My new pack of stencils is still on its merry way from China. I'm somehow missing a picture of the solder side of the chip - when i got done with it, i guess i was more curious whether it's actually going to work, not in the mood for taking pictures...But in the end, it all went fine. Before assembling the thing back together, i glued the hinge feet to the bottom case with more 2-part epoxy than required to fix a shovel.
That should keep them in their place. The laptop passed the highest load i could possibly throw at it (IBT + FurMark) and while temperatures were very high in this scenario, the cooling system was also spitting out very hot air, indicating there is good thermal transfer. With normal workloads it didn't break a sweat. This laptop is not used for games anyway, it is used for creating and showing multimedia presentations so it's gonna be fine.
Now, i'm not exactly using $10 DMMs to measure temperature, but i bet they'd still be better than some of the stations out there, and i'm absolutely not kidding.
. I was there at one point (trying to reflow with a heatgun) so I know. It's not that you can't... you can, but it's not proper (although, if you are creative and working on leaded hardware, you can get good results). And in some other cases, you are completely right - bad uneven heat from a cheap Chinese IR machine can be even worse than anything.
