MacBook Air A2337 820-02016 No Power at 5V-0.42Amp
  • saisoni20
    • Feb 2022
    • 111
    I've got an A2337 820-02016 that has no power. No sign of liquid damage and no obviously damaged components.
    U8100 is getting HOT.
    What could be the issue? Is it bad u8100 or any other specious component which is causing U8100 to fail?
  • mon2
    • Dec 2019
    • 13850
    What is the voltage to ground of PPBUS_AON @ F5200?
    • saisoni20
      • Feb 2022
      • 111
      mon2
      PPBUS_AO​ is 12.30V
      • mon2
        • Dec 2019
        • 13850
        What is the voltage to ground for the following?
        I2C_SMC_PWR_3V3_SDA
        I2C_SMC_PWR_3V3_SCL
        • saisoni20
          • Feb 2022
          • 111
          I2C_SMC_PWR_3V3_SDA - 0V / 350K respect to ground
          I2C_SMC_PWR_3V3_SCL - 0V / 350K respect to ground​
          • mon2
            • Dec 2019
            • 13850
            No short on these SMBUS 3v3 pins but also no pull-up voltage to park these open-drain lines.
            See attached.
            Confirm if you have a Vin and also the ENABLE (VEN) pin voltage on this LDO.
            • saisoni20
              • Feb 2022
              • 111
              PP3V3_AON - OV
              PP3V8_AON_VDDMAIN - 3.7V
              • mon2
                • Dec 2019
                • 13850
                Check if there is a voltage on PP1V8_AON_MPMU. If not, remove all power, measure the resistance to ground of PP1V8_AON_MPMU.
                • saisoni20
                  • Feb 2022
                  • 111
                  PP1V8_AON_MPMU​ -0V and 0.8ohm respect to ground.
                  • mon2
                    • Dec 2019
                    • 13850
                    Something is wrong here. If you have an adjustable power supply, consider to inject 1v (not higher) onto this same rail. Then hunt for who is heating up. If you do not have a thermal camera, the pharmacy grade alcohol from Costco works well. We use that primarily for cleaning but also works to test for heat signatures.
                    • saisoni20
                      • Feb 2022
                      • 111
                      I have checked by injecting 1V. U8100 is getting hot.
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • federicoc
                        MacBook Air A2337 820-02016 no power 5v
                        by federicoc
                        macbook air a2337 was brought to me dead, no power
                        The type c meter is stuck on 5v with low absorption and after a while it restarts.
                        I changed the two cd3217 because there was a low resistance to ground, the resistance is now ok but the problem persists.
                        These are the lines I measured
                        PPBUS AON: 11.98-12.25V
                        PPDCIN_AON_CHGR_R: 5.12V
                        PP1V5_UPC0_LDO_CORE: 1.58V
                        PP3V3_UPC0_LDO: 3.3V
                        PP3V3_S2_UPC: 3.3V
                        PP1V5_UPC1_LDO_CORE: 1.58V
                        PP3V3_UPC1_LDO: 3.3V
                        PP1V8_AON: 1.8V
                        PP3V8_AON_VDDMAIN: 3.8V
                        PP3V3_S2:...
                        06-24-2025, 07:09 AM
                      • madjid911
                        MACBOOK A2337 NO POWER
                        by madjid911
                        Hello, I'm trying to repair my MacBook Air A2337 820-0216-A, which does not start. It's stuck on 5V, the motherboard is not drawing power, and there's no liquid damage or shorts found.
                        Since I had PPBUS_AON but not PP1V8_AON, I replaced the U710 PMIC chip with one from a working donor motherboard (iCloud). The result is the same. Here are the measurement :
                        3V8_AON : 3V8
                        PPBUS_AON : 12V28
                        PP3V3_S2_UPC : 0V5
                        PP3V3_S2 : 0V
                        PP1V8_AON : 0V no short
                        PP3V8_AON :3V8
                        P3V8AON_PWR_EN_R : 5V
                        the trackpad does not click
                        I can't...
                        04-30-2025, 12:36 PM
