MacBook Air A2337 820-02016 no power 5v
  • federicoc
    • Feb 2022
    • 5
    • Italy
    macbook air a2337 was brought to me dead, no power
    The type c meter is stuck on 5v with low absorption and after a while it restarts.
    I changed the two cd3217 because there was a low resistance to ground, the resistance is now ok but the problem persists.
    These are the lines I measured
    PPBUS AON: 11.98-12.25V
    PPDCIN_AON_CHGR_R: 5.12V
    PP1V5_UPC0_LDO_CORE: 1.58V
    PP3V3_UPC0_LDO: 3.3V
    PP3V3_S2_UPC: 3.3V
    PP1V5_UPC1_LDO_CORE: 1.58V
    PP3V3_UPC1_LDO: 3.3V
    PP1V8_AON: 1.8V
    PP3V8_AON_VDDMAIN: 3.8V
    PP3V3_S2: 3.3V
    PP2V5_AWAKE_NAND: 2.5V
    PP1V25_S2: 1.22V (resistance to ground 0.252, is it low?)
    Thanks for your help and interest
  • mon2
    • 14660
    From where did you source the pd controllers? That may be the fault.
    • federicoc
      • Feb 2022
      • 5
      • Italy
      From a macbook pro a2141 motherboard
      They have the big dot, while the original ones had the small dot.
      Are they not compatible?
      • hopkok
        • Oct 2014
        • 179
        • Slovakia
        Hi, I have same problem, customer said, forgot MAC on direct sun, when he came back, was off. Put on charger, charging icon came on, but from this time was not able to turn it on anymore. I checked board and found faulty UF400, low resistand and under thermal camere there was heating spot. I took UF400 from exatly same board and now have same issu like you.
        Found this informations: " Check voltage on PPBUS_AON
        • Measure voltage on PPBUS_AON by placing your multimeter in DC mode, black probe on ground, and red probe on PPBUS_AON. A suitable measuring point on the 820-02016 logic board is C5960 (Figure 1). Normal voltage should be around 12.60-13.1V.
        • If the voltage is approximately 12.28-12.35V, it may indicate a communication issue between the SOC and PMICs, or corrupt firmware.
        • If the voltage is 0V, proceed to the repair steps for shorted or absent PPBUS_AON voltage.
        So there should be "communication issue between the SOC and PMICs, or corrupt firmware."
        Did you solve your issue?
        • hopkok
          • Oct 2014
          • 179
          • Slovakia
          Hi Mon2, if I take PD controller from exactly same board that should be working, right?
          • mon2
            • 14660
            Review this:
            https://logi.wiki/index.php/M1_MacBooks#CD3217_Repair
            Also suggest to use a part from the same physical location on the donor board as the internal SMBUS address for the controller may be different.
            • hopkok
              • Oct 2014
              • 179
              • Slovakia
              I used exactly the same PD controler, UF400 replaced with UF400...
              I need to dig out customer data from this board, is any way to start it from charged battery?
              • mon2
                • 14660
                What does the USB-C meter report for voltage and current draw?
                • hopkok
                  • Oct 2014
                  • 179
                  • Slovakia
                  5V, 0,44Amps, restart every 5-6 seconds...
                  • mon2
                    • 14660
                    If you have a restart, the board is power cycling. Would you have a USB-C port tester? Like Qianli tail bridge? Very handy tool to quickly gauge if the USB-C port pins are mating properly to the PD controllers. Also is able to test the Lightning port. We paid ~20$ (Canadian).
                    Would you have a thermal camera? Check the SPI flash for voltages.
                    • hopkok
                      • Oct 2014
                      • 179
                      • Slovakia
                      Unfortunately, I do not have USB-C tester. I have thermal camera. SPI mean U1970 or UF260?
                      • mon2
                        • 14660
                        Check both.
                        UF260 = TBT / PD controller ROM.
                        U1970 = SOC ROM.
                        Both should show activity. In the event that there is ROM corruption, the dumps of each should be available. Have you attempted a DFU to see if the unit is able to connect?
                        • hopkok
                          • Oct 2014
                          • 179
                          • Slovakia
                          NO DFU attempt yet. I ordered USB-C port tester and new stencil for PD controllers, will reball both PD controllers and test, data are the most important. Thanks for help, will post my update later on.
                          • hopkok
                            • Oct 2014
                            • 179
                            • Slovakia
                            Check both.
                            U1970 = SOC ROM.
                            Hi mon2,
                            both SPI have voltages,
                            UF260 - 3,3V
                            U1970 = 1,8V
                            that is O,K
                            I reballed both PD controllers to be sure, tried both controllers from working board, still stuck at 5V and power cycle...
                            Now waiting for USB-C tester.
                            Can this be caused by UF260 firmware? Is a good idea replace UF260 from working board for test?
                            • hopkok
                              • Oct 2014
                              • 179
                              • Slovakia
                              UPDATE, SOLVED with replacing UF400 (shorted), UF500 (red somewhere is good to replace both PD controllres), UF750 (visual damege on corner) and finally started working after UF260 replacement (probably corupted firmware). Mon2, thanks for help, really, really appreciated it.
                              • mon2
                                • 14660
                                Well done! Been stuck on repairing audio equipment lately for a music chain. Not an analog person but learning by tracing devices for which there are no schematics.
                                • hopkok
                                  • Oct 2014
                                  • 179
                                  • Slovakia
                                  Hopefully, finished as well as my MAC ;-)
                                  • pascable
                                    • Feb 2018
                                    • 41
                                    • France
                                    Dear Team
                                    Perhaps you can help me.
                                    Motherboard 820-02016. MacBook M1.
                                    MacBook removed with water damage to the sound card, completely oxidized.
                                    Sound card replaced, the cable too.
                                    Nothing visible on the thermal imaging camera.
                                    CD3217, big point, replaced, both.
                                    When I plug it into its charger, the multimeter shows:
                                    5.190 Volts, amperage from 0.190 to 0.440 continuous.
                                    Can I, with your help and my little knowledge, save this MacBook?
                                    Thank you for reading.
                                    Pascal
                                    • mon2
                                      • 14660
                                      The current draw starts and peaks to this value then repeats? Same if using other usb ports? Flip the cable head by 180 degrees to test each side of the connector.
                                      • pascable
                                        • Feb 2018
                                        • 41
                                        • France
                                        Tests performed. Same error.
                                        Thanks for your reply.
                                        • Adogabriel100
                                          where to get trusted CD3217. Problem with A2337 Macbook Air
                                          by Adogabriel100
                                          Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                                          The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                                          09-06-2024, 12:06 PM
                                        • Skrndelj
                                          Apple Macbook Air M1 A2337 Trackpad problem
                                          by Skrndelj
                                          Hello all,
                                          I am repairing a Macbook A2337 and i have a problem
                                          The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                                          When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                                          I inspected the whole board and everything seems fine.
                                          Can anyone help me as i didn't fiddle with trackpad...
                                          06-11-2024, 04:26 AM
                                        • Patrick501
                                          Macbook Air A2337 dead at 5V/0,00A
                                          by Patrick501
                                          Hey,
                                          I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
                                          USB Tester: 5V / 0,00A
                                          PPBUS_AON: 12,3 V
                                          PP5v_S2: 0 V no short
                                          PP3v3_S2_UPC: 0 V no short
                                          PP1v25_S2: 0 V no short
                                          PPDCIN_AON_CHGR_R: 5 V
                                          no enable signals for the S2 rails by the U8100
                                          both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
                                          PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
                                          PP1v5_UPC0_LDO_CORE:...
                                          11-29-2024, 02:47 PM
                                        • slimmy182
                                          MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
                                          by slimmy182
                                          Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
                                          Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
                                          Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
                                          C81DC PP3V8_AON_VDDMAIN
                                          And
                                          Q5800
                                          What should I test as next step?
                                          Thank you very much!
                                          02-01-2024, 01:08 PM
                                        • PITERPENY
                                          macbook A2337 820-02016
                                          by PITERPENY
                                          Hello! I need help, the MacBook could not boot and rebooted! After examination, I found that the small sound board with a 3.5 mm jack was oxidized! I replaced it and the MacBook no longer boots. Consumption with a battery 20v / 0.000A, without a battery 5v / 0.120-0.470A (not stable). The MacBook is not in DFU!
                                          10-26-2024, 05:10 PM
