dv9000 not turning on /no leds
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    I there , received here a dv9000 that client mention computer not turning on , well is right for sure , when pressed the on off button we have the 3.3 source and drop to 0 volts and when release recome to 3.3 volts , main step controler also all good , 3.3 and 5 volts ok . battery charges but still not turning on , well i'm a bit stuck here , this has the old NB chip by intel , its a DA0AT7MB8E7 REV:E .
    any tips will be welcomme .
    best regards
    jonathan
  • sorinac
    • Jul 2013
    • 123
    Re: dv9000 not turning on /no leds
    first write bios from hp website
    • kruuth
      • Mar 2014
      • 5
      • US
      What's the full model number and GPU? HP has had some serious issues with the graphics chip overheating and then not fully booting. I've seen them kick on but have no activity and some that will load the battery and sit dark like the way you're describing.
      • xredhawk
        • Jul 2011
        • 103
        i have the same, reball gpu
        • highpulse
          i hate HP
          • May 2013
          • 1489
          • portugal
          i just receive board , but board model is the one i posted above , gpu is a gf-go7600-h-n-b1
          • lefos
            • Nov 2013
            • 321
            • Greece
            Try to do a light reflow on that gpu. It gets defected quite a lot.
            Hope that the problem is from the gpu.
            • Momad
              • May 2013
              • 24
              • ITALY
              Hi All!
              Controll flat power & flat Multimedia, there are burned pins or change direction.
              controll for short arround the power Botton, replace the power botton PCB with anather for try.
              • highpulse
                i hate HP
                • May 2013
                • 1489
                • portugal
                well this is strange , all seems to be a s3 state problem . changed SB since he could be the problem , since i didnt have some S3 voltages , bios was changed , KB was changed , gpuwas reballed , NB wwas changed . SO pratically all chips are new here .. Power board i have around 100 of does , try with some same result , changed flat , same result , even shorting the KB pin to ground to make the computer turn on , make the same result .... FUCk
                have 3.3 and 5 no problem , but machine dont turn on ..
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  You ruled out pretty much everything else - could be the EC.
                  A working TV? How boring!
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1489
                    • portugal
                    Well but EC was also changed , like i posted , KBC , bios ,NB and SB were changed , just gpu i reballed .
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1489
                      • portugal
                      well removed another KBC from another machihne , its working , the kbs i changed previously was also from a spare board (bad luck was damaged)
                      fixed . took me a lot of hand work hours but ok ,, learning another thing , don't trust used stuff
                      ehehhe
                      thk guys
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        There you go. I would've put my money on the EC/KBC from the start. I keep a lot of boards with removed video chips, but i always check if they still power on before removing any critical parts.
                        • tomodachi
                          • Apr 2012
                          • 610
                          • Turkey
                          Same situation here with absolutely same components changed and still no power , Some help please ?
                          ps EC was new
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1489
                            • portugal
                            well got another one in that situation , indeed there were 2 , but one is solved .. now this one , cheked all seems fine .
                            its charging batery but simply not turning on .replaced cpu , the same . i removed GPU just in case some times this nvidia make this to happen , but even without gpu no light no nothing .
                            replaced KB , since i dont have pratically any S3 signals
                            but still the same issue after KBC replace , replaced SB as well , still the same
                            meanwhile i got 3.3 and 5 ok , and drop to 0 when pressed on .
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1489
                              • portugal
                              ok
                              found problem
                              glad to find the fuck#$%$ problem
                              in the end someone cleaned well this baord ... the bloddy white sockets were the flat cables turn on they were making contact insyde , they were green oxidated .. _!_ bloody sockets made me lost a tons of 4 hours.
                              thk anyway guys
                              • markopolo
                                • Mar 2014
                                • 27
                                • Slovenia
                                best regards
                                jonathan
                                HI !
                                I'd rather start from the scratch. First measure 19V on the mosfet if this is ok then measure 3,3V and 5V on the regulator chip without pressing a power button this voltages should be present always. If this is ok then measure 3,3 V on SIO chip pin marked as BAT reset should have 3.3V and when the power button is pressed the voltage on this pin is dropped almost to 0. After that also when the power button is pressed measure s5_on voltage should increase to 3,3V. If this is ok it means that SIO chip and the BIOS are ok. If not one of the components is failed.
                                Hope this helps!
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1489
                                  • portugal
                                  I there , Markopolo , all this steps i know , but thk anyway for reminding (it will help outher for sure )
                                  there was a conflict on the CN4 , indeed there is still a conflict , i must remove this connector and solder a new one , the pins are still making a bit of contact , when cleaning the contact computer works well , and turn on well . alltought im here with a doubt .
                                  LID_EC should be 3.3 ? i got 1.89 volts is that a normal value ?
                                  that is my only doubt .
                                  • polytek
                                    • Dec 2013
                                    • 496
                                    • TUNISIA
                                    just replace lid pcb
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1489
                                      • portugal
                                      hum , but the LID PCB " the on off PCB" is not attached , im turning it on buy the shunt pins between both sockets ,like i do usually for major toshibas and DV's series .
                                      so since there is no on off pcb attached it shouldn't make this value be low .
                                      my question is , wich is usually the value for LID_EC ?
                                      thk in advance
                                      • polytek
                                        • Dec 2013
                                        • 496
                                        • TUNISIA
                                        LID_EC=3.3V
                                        but in schematic is LID_EC# that mean active low signal so it must be 3.3V as correct value.
                                        lid pcd is not the on/off pcb, it's a separate small pcb linked by to wire to the power pcb on the upper fixed in the cooler
                                        • u666sa
                                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                          by u666sa
                                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                          Platform: ipa32 la-m024p rev 1b
                                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                          I found a short on the other side:
                                          10-04-2025, 05:03 PM
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • Mcfeetroy
                                          Fishing bite alarm drains battery
                                          by Mcfeetroy
                                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                          08-01-2025, 03:52 AM
