Macbook Pro A2442 820-02098 No image but has backlight
  • mon2
    • Dec 2019
    • 14320
    Interesting thread. Would you not have a whatsapp contact at Seven Puppy? If not, can share one.
    • mon2
      • Dec 2019
      • 14320
      Got censored on the post again. I would love to personally low level wipe the server software and with multpile over writes.
        SMDFlea commented
        Editing a comment
        Sorry about that.
    • a316
      • Oct 2024
      • 24
      • Georgia
      not understand sarcasm?
      • a316
        • Oct 2024
        • 24
        • Georgia
        Originally posted by a316
        found seller's flex has spi_tcon_clk_conn shorted to ground, on JP600 side. apple's flex has 4,5Om same pin to ground, flex disconnected
        my fault about apple's flex - spi_tcon_clk_conn has infinite resistance to ground
        but on seller-s flex -it is clearly shorted to ground. it is 4-th pin from left. =pin 28 and pin 30 both beeps on seller's flex, pin30 only beeps on apple's flex
        flex is DISCONNECTED when measuring
        • a316
          • Oct 2024
          • 24
          • Georgia
          see picture 1 - this pin (marked black line) is shorted to ground on seller's flex
          picture 2 - this pin on seller's flex (red color) has 1.5 Om resistance to ground
          • MartZisto
            • Dec 2024
            • 11
            • Sweden
            #26
            it is like not flex, it likes has some parts inside
            let me know if this helps
            ps. spi_tcon_clk_conn connected to M1, be careful
            a316 alright interesting, wonder what I could do. Just got info that switching ic:s was not advised from them. Weird though. You didn't say though before, what part gets hot?
            • a316
              • Oct 2024
              • 24
              • Georgia
              #27
              glass, up to 100 celsius, see photo I attached with screwdriver points there
              • MartZisto
                • Dec 2024
                • 11
                • Sweden
                #28
                a316 trying to talk to them about sending me a flex so I can try reseating the original ic:s and see if that works. Truly terrible that they are not included from the get go
                • a316
                  • Oct 2024
                  • 24
                  • Georgia
                  #29
                  any result?
                  • a316
                    • Oct 2024
                    • 24
                    • Georgia
                    #30
                    here is analysis of SUBJ issue: (need testing, pls contribute)
                    1. M1 can turn off image creation if spi_tcon_clk_conn is not ground (this is why seller's flex shorted)
                    2. such way if screen lcd has some (!!temporary) failure (mainly lcd <->tcon connection problems/ short) then M1 senses it and stops sending imagd to LCD even backlight exists
                    3. on earlier T2 after glitch LCD was recoveryng automatically (continue to show image), on M1 - no more, :-(
                    so solution is to make some button which shorts spi_tcon_clk_conn to ground and try to play with it. because after reboot M1 restores image creation (until spi_tcon_clk_conn is good), but reboot is not solution
                    any ideas?
                    • a316
                      • Oct 2024
                      • 24
                      • Georgia
                      #31
                      other solution may be power off/on TCON board to restore image
                      • MartZisto
                        • Dec 2024
                        • 11
                        • Sweden
                        #32
                        a316 seller let me return those ones, as I never received the flex. I got my money back from ali anyway. Now the seller will send two new units to me, as well as I found an original screen super cheap that I will test with also. No more news than that for me at the moment. But good research progress. Makes sense they would bypass any protection circuits.
                        • MartZisto
                          • Dec 2024
                          • 11
                          • Sweden
                          #33
                          a316 I just recieved new displays, both work with included flex. Somehow they even retained true tone?!?! Without swapping IC:s??? I am extremely confused
                          • a316
                            • Oct 2024
                            • 24
                            • Georgia
                            #34
                            true tone comes from original camera, not lcd
                            this is why lcd replace is good
                            • mon2
                              • Dec 2019
                              • 14320
                              True tone is linked to the ALS (ambient light sensor) which is separate from the camera. There is a local level shifter involved in this communication path onboard. Do review this level shifter if the ALS is a suspect.
                              • a316
                                • Oct 2024
                                • 24
                                • Georgia
                                #36
                                yes, it is linked to original display (ALS in chasis) and you have to replace ALS and dissasemble whole original display to have true tone
                                • MartZisto
                                  • Dec 2024
                                  • 11
                                  • Sweden
                                  #37
                                  a316
                                  I only replaced the lcd's, and all works as it should. Havent had that work before I think. I am happy.
                                  • a316
                                    • Oct 2024
                                    • 24
                                    • Georgia
                                    #38
                                    a316
                                    if it not worked before, maybe assembly is not paired to current MoBo (it is paired to its old original MoBo)
                                    • Jilanov
                                      • Nov 2022
                                      • 17
                                      • Bulgaria
                                      #39
                                      Hey,
                                      Could you send me link to seller store or Whatsapp/Wechat. I have ordered over 20 LCDs from China for A2442 and until now only 3 worked with IC chip swap
                                      • moophus
                                        • Feb 2017
                                        • 12
                                        • England
                                        #40
                                        I have the same issue. at some point the screen started working again for a whole week with no issues. It was working so well I brought it on a 2 week trip. halfway through the trip the screen went out again. but I noticed that when I open the lid, the lcd turns on for a split second before turning off again (all the while, the backlight stays on and is adjustable) so then I noticed that if I keep opening and closing the lid, at some point, the lcd stays on! so I used it for the rest of the trip like this. playing with the lid until the lcd remains on. actually once it stays on, it will stay on indefinitely until I close the lid. very odd. Only after the trip did it start going dark again. Now I haven't been able to get the lcd to stay on any more. VERY odd symptoms.
                                        • survivalbloke
                                          MacBook Pro A2442, board 820-0298-A, no backlight
                                          by survivalbloke
                                          I'm working on a MacBook Pro A2442, board 820-0298-A. This device was liquid damaged and had no power. After I repaired the liquid damage, I find the device powers on and works with external video, but backlight is not working.
                                          Anyway, I really want to improve my fault tracing skills, instead of having to rely on others to always tell me where to look and what to check. In this case, I have a question about navigating schematics. If I wanted to trace the backlight power circuit, how do I find where that circuit begins? If I search for "lcd" in the schamtic, it is listed...
                                          11-21-2024, 10:46 AM
                                        • Roccolade
                                          Macbook Pro 820-01814 no image or backlight
                                          by Roccolade
                                          Hi! I'm a bit new to this whole repair world. But this is what i'm working on:
                                          A Macbook Pro A1990 (820-01814) from 2018. It has no image – or backlight for that matter.
                                          No history of liquid spills or anything. It's fully functional on external monitor - and the webcam works.. But it doesn't seem like the internal display is even detected.
                                          Sometimes the backlight lights up, when booting into recovery mode. (No image still)
                                          That's the only progress I've gotten.
                                          I tested the panel on another Macbook, and the display worked perfectly....
                                          03-07-2023, 05:29 AM
                                        • arevut
                                          Macbook Air 2020 13” model: A2337 backlight is on but no image
                                          by arevut
                                          Hi all! MacBook Air A2337. There are no traces of liquid or obvious damage, the motherboard is visually in perfect condition. The image is displayed on the external screen, but only the backlight works on the internal screen. There is no image, and the camera on the built-in screen does not work. How to exclude during diagnostics that it is the screen that is broken and not the motherboard? What signals should be present on the connector with the screen removed and connected?
                                          02-07-2024, 08:07 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • imcool
                                          Macbook Air A1466 no backlight no image
                                          by imcool
                                          On this Macbook Air A1466 with 820-00165
                                          I have only 8V on backlight line but no high voltage in boost circuit, I have checked all components like caps and diode and they seems to be ok.
                                          I have noticed that when macbook chimes after turning on there is no image at all even with flash light,
                                          I have tried 2 different OEM LCD and still there is no image,
                                          I see the LCD fades out when i remove power or turn off the macbook.
                                          I have 2 problems
                                          1 No image
                                          2 No backlight, but i have 8VDC on backlight circuit.
                                          12-14-2020, 02:18 PM
