Interesting thread. Would you not have a whatsapp contact at Seven Puppy? If not, can share one.
					Macbook Pro A2442 820-02098 No image but has backlight
 my fault about apple's flex - spi_tcon_clk_conn has infinite resistance to ground
 but on seller-s flex -it is clearly shorted to ground. it is 4-th pin from left. =pin 28 and pin 30 both beeps on seller's flex, pin30 only beeps on apple's flex
 flex is DISCONNECTED when measuringComment
 see picture 1 - this pin (marked black line) is shorted to ground on seller's flex
 picture 2 - this pin on seller's flex (red color) has 1.5 Om resistance to groundComment
 a316 alright interesting, wonder what I could do. Just got info that switching ic:s was not advised from them. Weird though. You didn't say though before, what part gets hot?Comment
 here is analysis of SUBJ issue: (need testing, pls contribute)
 1. M1 can turn off image creation if spi_tcon_clk_conn is not ground (this is why seller's flex shorted)
 2. such way if screen lcd has some (!!temporary) failure (mainly lcd <->tcon connection problems/ short) then M1 senses it and stops sending imagd to LCD even backlight exists
 3. on earlier T2 after glitch LCD was recoveryng automatically (continue to show image), on M1 - no more, :-(
 so solution is to make some button which shorts spi_tcon_clk_conn to ground and try to play with it. because after reboot M1 restores image creation (until spi_tcon_clk_conn is good), but reboot is not solution
 any ideas?Comment
 a316 seller let me return those ones, as I never received the flex. I got my money back from ali anyway. Now the seller will send two new units to me, as well as I found an original screen super cheap that I will test with also. No more news than that for me at the moment. But good research progress. Makes sense they would bypass any protection circuits.Comment
 yes, it is linked to original display (ALS in chasis) and you have to replace ALS and dissasemble whole original display to have true toneComment
 Hey,a316 I just recieved new displays, both work with included flex. Somehow they even retained true tone?!?! Without swapping IC:s??? I am extremely confused
 Could you send me link to seller store or Whatsapp/Wechat. I have ordered over 20 LCDs from China for A2442 and until now only 3 worked with IC chip swapComment
 I have the same issue. at some point the screen started working again for a whole week with no issues. It was working so well I brought it on a 2 week trip. halfway through the trip the screen went out again. but I noticed that when I open the lid, the lcd turns on for a split second before turning off again (all the while, the backlight stays on and is adjustable) so then I noticed that if I keep opening and closing the lid, at some point, the lcd stays on! so I used it for the rest of the trip like this. playing with the lid until the lcd remains on. actually once it stays on, it will stay on indefinitely until I close the lid. very odd. Only after the trip did it start going dark again. Now I haven't been able to get the lcd to stay on any more. VERY odd symptoms.Comment
			I'm working on a MacBook Pro A2442, board 820-0298-A. This device was liquid damaged and had no power. After I repaired the liquid damage, I find the device powers on and works with external video, but backlight is not working.
 Anyway, I really want to improve my fault tracing skills, instead of having to rely on others to always tell me where to look and what to check. In this case, I have a question about navigating schematics. If I wanted to trace the backlight power circuit, how do I find where that circuit begins? If I search for "lcd" in the schamtic, it is listed...
			by RoccoladeHi! I'm a bit new to this whole repair world. But this is what i'm working on:
 A Macbook Pro A1990 (820-01814) from 2018. It has no image – or backlight for that matter.
 No history of liquid spills or anything. It's fully functional on external monitor - and the webcam works.. But it doesn't seem like the internal display is even detected.
 Sometimes the backlight lights up, when booting into recovery mode. (No image still)
 That's the only progress I've gotten.
 I tested the panel on another Macbook, and the display worked perfectly....
			by arevutHi all! MacBook Air A2337. There are no traces of liquid or obvious damage, the motherboard is visually in perfect condition. The image is displayed on the external screen, but only the backlight works on the internal screen. There is no image, and the camera on the built-in screen does not work. How to exclude during diagnostics that it is the screen that is broken and not the motherboard? What signals should be present on the connector with the screen removed and connected?02-07-2024, 08:07 AM
			by Comp_ProHello all,
 Am trying to figure out this backlight issue with this A1990 Macbook Pro.
 Tests performed:
 There is no backlight even with a good screen.
 Backlight IC is receiving the correct support voltages.
 Fuse F8400 ok
 Current sense resistor R8400 ok
 Backlight IC is receiving 3.3V on enable pin.
 Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
 Backlight IC receiving 5V from PP5V_G3S
 Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
 I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
			by imcoolHello,
 On this Macbook Air A1466 with 820-00165
 I have only 8V on backlight line but no high voltage in boost circuit, I have checked all components like caps and diode and they seems to be ok.
 I have noticed that when macbook chimes after turning on there is no image at all even with flash light,
 I have tried 2 different OEM LCD and still there is no image,
 I see the LCD fades out when i remove power or turn off the macbook.
 I have 2 problems
 1 No image
 2 No backlight, but i have 8VDC on backlight circuit.
- Loading...
