Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Macbook Pro A2442 820-02098 No image but has backlight
  • moophus
    • Feb 2017
    • 12
    • England
    #41
    Originally posted by a316
    here is analysis of SUBJ issue: (need testing, pls contribute)
    1. M1 can turn off image creation if spi_tcon_clk_conn is not ground (this is why seller's flex shorted)
    2. such way if screen lcd has some (!!temporary) failure (mainly lcd <->tcon connection problems/ short) then M1 senses it and stops sending imagd to LCD even backlight exists
    3. on earlier T2 after glitch LCD was recoveryng automatically (continue to show image), on M1 - no more, :-(
    so solution is to make some button which shorts spi_tcon_clk_conn to ground and try to play with it. because after reboot M1 restores image creation (until spi_tcon_clk_conn is good), but reboot is not solution
    any ideas?
    So is the screen blanking out due to a bad flex cable? Has anyone been able to remove the lcd without cracking it? If so what is the secret? I've done 4 of these already and have never successfully been able to remove the adhesive without cracking the lcd. I've tried heat as well, it actually made it worse.
    • a316
      • Oct 2024
      • 24
      • Georgia
      #42
      never did it, just buy new chinese lcd ~100$
      • moophus
        • Feb 2017
        • 12
        • England
        #43
        do you have a link? I can't find any that cheap
        I got this screen to come back with the opening and closing dance again....turning promotion down to 47hz helped. it was working for around 5 hours today. then I switched it back to promotion and it went off again after 15 minutes 🤷
        • a316
          • Oct 2024
          • 24
          • Georgia
          #44
          can be liquid damage of TCON board/or motherboard. but you cannot remove LCD without damage. what left? use WD-40, sometimes it helps
          ps. wd-40 can make stain on screen. be aware
          https://www.alibaba.com/product-deta...333383380.html
          • berlincaps
            Macbook Air M1 A2337, no charging and then no backlight
            by berlincaps
            Dear BADCAPS Forum,
            I am happy to have found this place and would love to get some input on my issues with a MacBook Air M1 (A2337).
            A couple of days ago, I was using the MacBook on a low battery, and while running VS Code it shut down due to low battery. I rarely let it reach the point where it turns itself off, and if it does, I usually charge it immediately. This time, however, I left it uncharged until the next evening, and when I plugged it in, nothing happened. I waited until the following day, and still nothing.
            I followed all the recommended troubleshooting...
            01-10-2026, 10:34 AM
          • survivalbloke
            MacBook Pro A2442, board 820-0298-A, no backlight
            by survivalbloke
            I'm working on a MacBook Pro A2442, board 820-0298-A. This device was liquid damaged and had no power. After I repaired the liquid damage, I find the device powers on and works with external video, but backlight is not working.
            Anyway, I really want to improve my fault tracing skills, instead of having to rely on others to always tell me where to look and what to check. In this case, I have a question about navigating schematics. If I wanted to trace the backlight power circuit, how do I find where that circuit begins? If I search for "lcd" in the schamtic, it is listed...
            11-21-2024, 10:46 AM
          • Roccolade
            Macbook Pro 820-01814 no image or backlight
            by Roccolade
            Hi! I'm a bit new to this whole repair world. But this is what i'm working on:
            A Macbook Pro A1990 (820-01814) from 2018. It has no image – or backlight for that matter.
            No history of liquid spills or anything. It's fully functional on external monitor - and the webcam works.. But it doesn't seem like the internal display is even detected.
            Sometimes the backlight lights up, when booting into recovery mode. (No image still)
            That's the only progress I've gotten.
            I tested the panel on another Macbook, and the display worked perfectly....
            03-07-2023, 05:29 AM
          • arevut
            Macbook Air 2020 13” model: A2337 backlight is on but no image
            by arevut
            Hi all! MacBook Air A2337. There are no traces of liquid or obvious damage, the motherboard is visually in perfect condition. The image is displayed on the external screen, but only the backlight works on the internal screen. There is no image, and the camera on the built-in screen does not work. How to exclude during diagnostics that it is the screen that is broken and not the motherboard? What signals should be present on the connector with the screen removed and connected?
            02-07-2024, 08:07 AM
          • gabrielA7
            Macbook pro A1706 / Backlight flex cable compatibility
            by gabrielA7
            Hey guys!!
            I’ve got a question here!
            I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
            Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
            Here’s what the bot told me:
            I said to him: “I’m going to install the 821-01229-A.”
            ChatGPT replied:
            Understood — but before you solder or install the 821-01229-A,
            11-11-2025, 03:26 PM
