Macbook a1707 820-00281 Battery no Power
  • leonemax81
    • Nov 2015
    • 57
    • italia
    Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
  • leonemax81
    • Nov 2015
    • 57
    • italia
    Parts already replaced without success: Battery. U7800. Q7030. Q7040. Q7065. D6950. D6902. U7000.
    • mon2
      • Dec 2019
      • 14575
      Connect the battery and the USB Type C adapter.
      Measure the voltage to ground of:
      SMBUS_SMC_5_G3_SCL
      SMBUS_SMC_5_G3_SDA
      at battery connector J6951.
      • leonemax81
        • Nov 2015
        • 57
        • italia
        yes already done, I have no shorts and the voltage goes up to 2.95V and goes in loop, without battery connected I have stable voltage 3.34, I suspect it is the SMC chip.​
        • mon2
          • Dec 2019
          • 14575
          Remove all power. Meter in lowest resistance scale.
          Measure the resisance across C7020. We are interested in the full resistance path of the battery leg current sense circuit. What is the resistance in ohms?
          • leonemax81
            • Nov 2015
            • 57
            • italia
            C7020, with black lead to GND and red lead to PIN 1 and then PIN 2, resistance 470 KOHM, while if I put black lead to PIN 2 and red lead to PIN 1, I measure 3.7 OHM, which compared to other working motherboards is too low.​
            • mon2
              • Dec 2019
              • 14575
              Short your meter probes by touching them together. What is the resistance? That is your 0 ohm baseline measurement.
              Then when you measure the resistance across pins 1 & 2 of C7020 - the true resistance is the value on the meter - baseline value. There are 3 resistors in the measured path @ R7061, R7060, R7062. We know from the schematics that R7061 = R7062 = 1 ohms each. So your measurement should be ~2 ohms since R7060 = 5 milliohms = 5/1000 ohms.
              If you have a working motherboard of the same, measure at the same points of interest. Compare the measurements.
              • leonemax81
                • Nov 2015
                • 57
                • italia
                if I put the tip and the tip has a tolerance of 0.03 ohm, R7061 = R7062 = they are 1 ohm, I don't have an identical motherboard, I take reference from a motherboard of a macbook pro 13.​
                • mon2
                  • Dec 2019
                  • 14575
                  measure the resistance across pins 1 & 2 of C7020 - this should be very close to 2 ohms (not 3R7). Can you confirm this measurement again?
                  • leonemax81
                    • Nov 2015
                    • 57
                    • italia
                    measures 3.7 ohm
                    • leonemax81
                      • Nov 2015
                      • 57
                      • italia
                      I also replaced the R7060 resistor without success.
                      • leonemax81
                        • Nov 2015
                        • 57
                        • italia
                        also replaced the resistors R7061 = R7062 and also u7000 once again, without success.
                        • mon2
                          • Dec 2019
                          • 14575
                          Remove the battery mosfet off the board and test again with the power adapter and battery attached. Does the power cycling stop and the board boots?
                          Are the batteries the same as the original and recommended for use in this machine?
                          • leonemax81
                            • Nov 2015
                            • 57
                            • italia
                            which mosfet should i remove?, the batteries are working on other mocbooks, i noticed that with the battery connected i have no voltage on PPBUS.
                            • leonemax81
                              • Nov 2015
                              • 57
                              • italia
                              I remove the q7065 mosfet, same defect, 5v in loop on USBC.
                              • mon2
                                • Dec 2019
                                • 14575
                                Flux and remove carefully the dual diode @ D6950. Test again.
                                • leonemax81
                                  • Nov 2015
                                  • 57
                                  • italia
                                  removed D6950, nothing usual defect, I'm going crazy!
                                  • mon2
                                    • Dec 2019
                                    • 14575
                                    Remove all power. Meter in diode mode. Black (yes black) meter probe on PPVBAT_G3H_CONN (because this line is also mating with the ISL9239). Red meter probe to ground. What is the measurement?
                                    How confident do you feel about the soldering of U7000? Perhaps consider to flux it and reflow this part to be sure there are no underside shorts.
                                    The fact that you lose PPBUS_G3H means there is a conflict raised when the battery is connected. SMBUS lines are a common factor and you could be shunting those lines. Maybe both batteries have a defective BMS board but you have mentioned they work in other macbooks? Which battery pack are you testing? What is the part #? 100% confirmed to be compatible with this macbook?
                                    An I2C / SMBUS analyzer would help to reveal the traffic on the SMBUS SDA/SCL lines.
                                    • leonemax81
                                      • Nov 2015
                                      • 57
                                      • italia
                                      PPVBAT_G3H_CONN diode mode measures 0.623V, I have already tested two batteries that work on other macbooks, U7000 replaced twice without success, I have an oscilloscope can it help?
                                      • leonemax81
                                        • Nov 2015
                                        • 57
                                        • italia
                                        I don't think the PPVBAT_G3H_CONN line is the culprit, because even if I don't put the battery screw but just connect the black battery cable to the J6951 connector without inserting the screw the MacBook doesn't turn on.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • PITERPENY
                                          Macbook A1707 820-00928 battery replacement
                                          by PITERPENY
                                          brought in a working MacBook for battery replacement (swelled up). After replacing the battery it stopped turning on. tried connecting the old battery without changes. consumption with the battery connected and without the battery is the same 5v\0.200a on all 4 ports. replacing 9239 did not help
                                          04-20-2025, 03:22 PM
                                        • AdrenalinTL
                                          Macbook Pro A1707 - Dead - Battery 'popped'
                                          by AdrenalinTL
                                          Hi Peeps.
                                          Just a quick question please as I am by no means an Apple fundi at all.
                                          Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
                                          Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
                                          Don't want to go buy a battery for no reason.
                                          Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
                                          07-18-2024, 09:52 AM
                                        • gboone
                                          820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                                          by gboone
                                          Hi, I was given this laptop by my uncle who said:
                                          • It would occasionally shutdown if not plugged in
                                          • battery had been replaced
                                          • touchbar would "strobe"
                                          I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                                          After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                                          BUT
                                          When powered off, it would at some point have a...
                                          01-27-2025, 09:12 AM
                                        • kurland
                                          MacBook A1707 - low batt sign displayed then shutdown - but battery voltage is ok!?
                                          by kurland
                                          Hi fellow repair gurus,
                                          Liquid damaged A1707 was stuck on 5V. I replaced corroded CD3215 and SMC now successfully raises voltage to 20v.
                                          The fans spin, the screen comes on and displays a "low battery" sign before the machine shuts down.
                                          After that the screen and fan stays off but PPBUS_G3H continue to toggle every 4-5 secs between
                                          • 11.4v (and 170mA current draw on usb-c power meter)
                                          • 12.6v (zero current draw)
                                          The toggeling occurs when battery is connected but regardless if external usb-c is connected or not. It seems...
                                          10-21-2022, 02:04 PM
