Hello, I can't read anything in pin 3 (VCC) of RT8206B, I can read 3.3V but not 5V. What does this usually indicate? Is problem with RT8206B or is it something else?
Missing 5V and can't read VCC of RT8206B
Tags: None
Re: Missing 5V and can't read VCC of RT8206B
I swapped with another RT8206B, I'm getting 5V in some pins, however pin 3 is 5V and pin 6 is 19V. BIOS and EC chip have no V readings. -
It's a Dell N4110 (DA0V02MB6E1). After I flashed EC, laptop was able to turn on, but wouldn't post, so I went to flash BIOS, however, the traces came up and I had to do trace repair, then PQ19 was smoking, so I replaced it.
Now I'm measuring RT8206B and it has 3.3V and 5V, now BIOS lost 3V. I was so close to repairing this, any ideas?Comment
Is it weird I'm getting 3.3V in pin 3,7,8 of the EC chip and 3.3V in all pins of BIOS chip but pin 4?Comment
Since you have a lot of problem with 3.3 and 5 volts line , and now you mention you have lost voltage for the spi bios , have you checked the correct signal incoming from KB controller ? also if you can share here the schematic will be more easy to tell you some stuff to chek .
which are the values for LDO on the main Step controller ? also for the EN1 and EN2 pins , you should get around 5 volts ..
another things im curious its practically impossible having 3.3 volts on all pins of any of the bios SPI or EC . so double cheek with schematic if you are reading the correct chip.
Let us know and share here the schematic for we can help you out solving thisComment
Hello, I don't have schematic of this board.
EC chip has 3.3V in pins: 3, 7, 8 and BIOS chip in pins: 1,2,3,5,6,7,8.
In RT8206B: LDO is pin7(5V), EN1 is pin14(3.3V) and EN2 is pin27(5V).Last edited by orientalsniper; 03-06-2014, 03:43 PM.Comment
I think this is the schematic:
http://kythuatphancung.com/download/...chematics.htmlComment
ok opening the schematic now , i will re edit this post with a possible solution , let me chek
Tell me which is the identification for each bios chip ? Uxx??
chek voltages on U1 and U12 , its impossible you having on pin 4 of U12 voltage at all ..chek also if the U12 is the MX25L3205D...
Also the 3.3 volts on this PCH bios chip are 3.3 Run meaning that this voltage can only be present when you turn on machine and pass S5 state
Also you mention pq19 was burned, this is a controller to make 1.5v-sus to 1.5V_runLast edited by highpulse; 03-06-2014, 04:35 PM.Comment
Hello, U12 is a W25Q32, U1 is a W25X80 (originally a W25X40).
The voltages are EC (U1) chip has 3.3V in pins: 3, 7, 8 and BIOS (U12) chip in pins: 1,2,3,5,6,7,8.
Sometimes when I replug DC adapter, BIOS loses all voltages. (0V)Comment
For EC rom pins with 3.3V_alw pin 3 7 and 8 .. for PCH rom , you will have only voltages when you turn on the machine .
Do you notice PCH to get hot in any way ? or any place on board with hot temp ?
checking the schematic there is really nonsense , in having voltages on all pins of PCH bios ..alltough the PCH bios its different than the one mentioned on the schematic but even like this its impossible having voltage on pin 4 . so PCH might be dead . (attention PCH bios you can't reflash it with rom found on the brand site . you must find a good DUMP ROM site were you can get this rom you need to ref lash pch bios , but in any case , if you have 3.3 volts on the SPI part of the PCH bios , then its like PCH is sending you does values .REplace PCH and let us knowComment
I notice no heat in the motherboard
Also, I downloaded BIOS from Dell website, it was a 5MB rom, so I dumped my EC and BIOS and used HxD to find starting offset and flashed with eeprom programmer. I don't think Dell BIOS'es are encrypted unlike HP, because I found relevant patterns.Comment
The only weird thing is the laptop turned on when I flashed the EC chip just not POSTing, shit hit the fan when the traces of BIOS pin 2, 5, 6 were damaged, so I retraced it after BIOS reprogramming.Last edited by orientalsniper; 03-06-2014, 05:11 PM.Comment
nooooooooo , SPI KBC ROM flash info , its entirely not the same as PCH bios . so if you flashed it with what you have found on website brand , than you must find the correct rom on a good bios dump SITE.
the bios we usually find on website brand like hp , dell toshiba etc , are for KBC ONLY . never for PCH or VIDEO CARD.Comment
n4110 biosAttached FilesComment
by ugamazingBoard had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),... -
by jprezaHi everyone,
I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
Looking at the card, it appears to be missing the following:
1x 1.0uH inductor - orange square
2x...1 Photo -
by gurj1979Hey guys.
Need help with this one.
Fan not spinning due to missing PWN Fan signal.
Also 5 seconds from powering up it freezes, unless in BIOS.
But as soon as Windows starts to load, it will freeze.
CPU is COLD / Room temp when it freezes.
I've replaced the CPU, same problem.
Replaced SIO/KBC IT8987e and reprogrammed - same problem.
Replaced fan - same problem.
Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
Checked the Thermal sensors around CPU and Board to the SIO/KBC and...08-19-2024, 05:22 PM -
by salopianHello. I would need some advice please.
My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
I have already replaced the logic board with another... -
by reessiHello,
I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
I have checked these lines in diode mode and they seam normal -> 600.
I have checked to see if they come on for even a fraction of a second... - Loading...
