Dell E5500 stuck at config screen
  • spleenharvester
    • Mar 2010
    • 901
    Bought another E5500, was advertised as dead. Turned out it powers fine off both AC and battery but it has a strange problem.
    Basically, at first, it would give "The amount of system memory has changed" message. Except where there's meant to be "strike F1 to continue" - there isn't. No option to do anything, it's just stuck there with a blinking cursor.
    Tried different RAM, then a BIOS reset. Now it loads up to "Invalid System Configuration - please run SETUP program". Again, no options, just a blinking cursor.
    I'd have thought a BIOS flash would be the needed fix, but I have no means of doing so, unless there's some way of doing it before POST (the same way some Aspire Ones with Insyde BIOSes do)
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Re: Dell E5500 stuck at config screen
    try turning UEFI off and set to legacy boot ????
    check for internal battery too...
    • spleenharvester
      • Mar 2010
      • 901
      Fixed, as I suspected, the DVD drive was stalling the boot process
      Cheers!
      • spleenharvester
        • Mar 2010
        • 901
        Okay the situation deepens. Turns out it won't boot from ANY HDD or ANY DVD. It just hangs at the same place.
        Internal battery reads in at 3.1v so seems to be okay. Will try what you suggested
        • spleenharvester
          • Mar 2010
          • 901
          Nope still no dice. Dell diagnostic and logs show nothing either.
          Anyone know how to do BIOS recovery on these? Another site suggests a method involving extracting the BIOS file to .bin, .rom and .hdr files, and then inserting the AC while holding the end key. It gets part way through it, the battery LED flashes red as expected, and then just goes onto a normal boot.
          Do I have to format the drive a certain way for it to detect the files?
          EDIT: If the "module bay" option is disabled, it doesn't hang with the DVD drive installed - the DVD drive still gets power but obviously the BIOS does not detect it. So I assume we aren't looking at a voltage issue here.
          • 3d0
            • Jan 2014
            • 159
            • BiH
            Originally posted by spleenharvester
            Do I have to format the drive a certain way for it to detect the files?.
            I used rufus a couple of times to make a bootable usb drive, then flash the BIOS. That was of course for desktop machines, never tried it for laptops.
            Code:
            http://www.howtogeek.com/136987/how-to-create-a-bootable-dos-usb-drive/
            • spleenharvester
              • Mar 2010
              • 901
              Will try in a sec, it doesn't seem to be hanging with a USB drive plugged in so I may indeed be able to do it that way.
              If that doesn't work, I think I'll start testing the resistance of the bad board compared to my good one on the SATA ports.
              • spleenharvester
                • Mar 2010
                • 901
                Flashed BIOS to A19 from DOS (typed E5500A19.exe /force it and hit enter) and amazingly everything works a treat now! I'm typing from it at this moment!
                Also came with a WXGA+ screen which I can sell and basically pay the laptop off
                Cheers Badcaps, great help as always!
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  glad to hear u have fixed it!!!!
                  • 3d0
                    • Jan 2014
                    • 159
                    • BiH
                    Awesome, nice to hear it works!
                    Btw. did you use rufus to format the usb drive, had any trouble?
                    • spleenharvester
                      • Mar 2010
                      • 901
                      Didn't use Rufus in the end but 'cause I already had Win98 system files installed on a flash drive to use it with.
                      Success really I only bought it for the hinges and upper plastics because the ones on mine were snapped, got a lot more than I bargained for.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        The blinking cursor is often the result of boot loader crud on the HDD. When the HDD isn't wiped correctly, at least the first sector, that issue can occur.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • spleenharvester
                          • Mar 2010
                          • 901
                          Indeed, it often seems to happen when it's trying to access a storage device and gets stuck for whatever reason.
                          • HTR-Informatique
                            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                            by HTR-Informatique
                            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                            I also changed the screen because the PC fell and the screen was broken.
                            I changed the battery with a new and original battery.
                            I also had corrosion/oxidation on the...
                            02-09-2025, 06:51 AM
                          • javivi
                            Dell 15 5584 stuck at BIOS/Dell welcome screen
                            by javivi
                            Hi I have a dell 15 5584, it worked fine, but after disable secure boot in bios, now is stuck at BIOS/Dell welcome screen. If press F2 appear "Preparing to enter bios Setup" but never ending...
                            I was triying with another bios but always same problem.
                            Please can you help me?...
                            10-26-2023, 12:12 PM
                          • Swedishpower
                            Dell G3 15 3500 black screen
                            by Swedishpower
                            Hello
                            I have search everywhere for a solution for my problem, but cant find it anywhere.
                            When I was away to trow some garbage i always look in the electronic bin.
                            and this time i find a laptop.
                            Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                            the lamp for charmig is white.
                            Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                            but no Dell logo.
                            I tryed with a hdmi cable to another screen, still black.
                            I started to search solution and tryed...
                            07-06-2025, 06:18 AM
                          • jake-b
                            dell e6540 boots to black screen (no dell logo)
                            by jake-b
                            good morning all,
                            i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                            01-08-2024, 10:29 AM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
